What is this sensor...?
Old Jun 4, 2004 | 12:34 PM
gtr_rider's Avatar
Im trying to find out what this sensor is, and what the substance is that is leaking out of it. The pictures are from the passenger end looking at the side of the timing chain cover.
Old Jun 4, 2004 | 12:37 PM
shibbys's Avatar
will u zoom out a lil bit. i think i have an idea.
Old Jun 4, 2004 | 02:16 PM
nostrixoxide's Avatar
I think it's the crank angle sensor. I'm positive it will tell you in a Haynes manuel. My guess is crank angle sensor.
Just checked my manuel it's the crank position sensor!!!
And more then likely its motor oil leaking out of it?
97SEMAXI's Avatar
hmm.....i couldnt tell ya off the top of my head. that little wire just goes off into the rest of the others. best bet is to look into a haynes manual. im at work so i dont have mine with me, but if no one has replied by then ill let ya know.
Old Jun 4, 2004 | 02:48 PM
DAVE Sz's Avatar
Hooooooonda.....
Actually it's the CAMSHAFT position sensor(PHASE).
Old Jun 4, 2004 | 02:52 PM
Big D is correct camshaft position sensor, Crankshaft position sensor looks the same.
Old Jun 4, 2004 | 02:58 PM
DAVE Sz's Avatar
Hooooooonda.....
They look similar but the location is different.
Old Jun 4, 2004 | 03:13 PM
97SEMAXI's Avatar
oh yea.......... looks like oil leakin out
Old Jun 4, 2004 | 07:14 PM
gtr_rider's Avatar
Does that sensor have an o-ring?
Old Jun 4, 2004 | 07:26 PM
Ramius83
Yes, it has an o-ring. Mine leaked in the past on my old motor. Nothing that good old permetex ultra grey can't fix......Or you can go to your local hardware store and "try" to find a right sized o-ring, or you ma be able to order it from Nissan.
BTW, that is oil leaking from the sensor......
Old Jun 4, 2004 | 07:56 PM
gtr_rider's Avatar
I have some permetex left over from my valve cover gasket job.
Is that a problem that it is leaking from the sensor?
Old Jun 4, 2004 | 08:03 PM
DAVE Sz's Avatar
Hooooooonda.....
Probably not but if you're like me, you don't want oil leaking out of anywhere.
Old Jun 4, 2004 | 08:07 PM
gtr_rider's Avatar
Exactly, I notice things that people never know was there.
Old Jun 4, 2004 | 08:09 PM
Ramius83
Nah, you are fine. Just remove the one 10mm head bolt, through a little permatex on it and slap it back in. Remember not to use too much as it may hinder the sensor from actually working.....
D-Twelve
May 1, 2007 07:52 PM
D-Twelve
22
Apr 30, 2007 06:50 PM
KabirUTA13
21
Jul 19, 2006 07:40 PM
salz
Jul 1, 2006 03:26 PM
cefiro8701
Dec 8, 2005 09:09 AM
