99 Max won't start -- help?
Old Sep 5, 2004 | 07:37 AM
Th.'s Avatar
Th.
Just went out to the 99 SE-L, auto, 60K miles, it turns over but won't start...any one out there have any ideas?
Thanks!
T.
Old Sep 5, 2004 | 07:44 AM
NEW2DAGAME's Avatar
Check for crank and camshaft sensors in your codes. These have been going out on a lot of people as of late (myself included).
Old Sep 5, 2004 | 07:46 AM
Th.'s Avatar
Th.
Won't start, not getting any codes....
Old Sep 5, 2004 | 07:48 AM
Kevlo911's Avatar
Kevlo for President
security light on while trying ot start? Or a green key.
Old Sep 5, 2004 | 07:53 AM
Th.'s Avatar
Th.
All lights seem normal, I'll double check the security light.
What acutally happened was I put the key in and the normal chimes didn't come on. The car started but I turned it off to see if the chimes would come on. Then it wouldn't start. Waited a minute, tried again and it started then it turned right off. Waited, waited, won't start but turns over fine. I hear a soft unfamiliar groan when I try to start it which might be something...
Old Sep 5, 2004 | 09:56 AM
a_prince1's Avatar
Now when you say "Not getting any codes" do you mean there are no codes at all? If the system is fine it should still throw a system ok code.
So if you are NOT getting any codes AT ALL your ECU could have gone belly up.
Old Sep 5, 2004 | 01:24 PM
Th.'s Avatar
Th.
That's possible I suppose, but I thought the car has to be running to get a code...
Old Sep 5, 2004 | 02:29 PM
mrglynis's Avatar
Yea, check to see if the security light is on solid. If it is, then your immobilizer has been activated. If so call the dealership and have your car towed there. They'll have to reprogram the keys. Make sure to bring any spare keys with you.
Ps: Its usually not to cheap either. It seems to run anywhere from $40-75/per key. Just a heads up.
Old Sep 5, 2004 | 02:50 PM
T.Maximus's Avatar
thanks, will check it out.
T.
Old Sep 5, 2004 | 05:20 PM
T.Maximus's Avatar
Yes, when cranking the engine the security light is on solid -- does this definitely mean it's the security chip? I have two keys and both don't work (also checked all the fuses). Why would this happen out of the blue?
Anybody have a similar experience?
Thanks,
Th.
Old Sep 5, 2004 | 08:51 PM
a_prince1's Avatar
You can check codes just by turning the key to the ON position without the car running.
But your problem is definitely the chip in the key.
Expect to cough up some good money.
Old Sep 5, 2004 | 08:54 PM
T.Maximus's Avatar
Ouch. Thanks...
Old Sep 7, 2004 | 05:00 PM
maximaman10's Avatar
I had both remotes and both keys programed for $40
Old Sep 7, 2004 | 05:04 PM
fisher01's Avatar
Yep, your immoblizer been activated. Common problem with the 99's. Only dealer can reprogram. Usually runs $110-140.
Old Sep 7, 2004 | 05:28 PM
T.Maximus's Avatar
Common? How common and what causes it? BTW, I have another thread on this <sorry!> that has more details.
Thanks,
T.
kjlouis
Nov 24, 2018 06:09 AM
Btheman80
May 1, 2018 04:03 PM
02PearlSE
Oct 7, 2015 02:12 AM
BobMax
Aug 15, 2015 12:35 PM
Balkins
Aug 12, 2015 06:39 AM
