engine knock/ticking noise!!! WTF
Oct 21, 2004 | 05:38 PM
hey does anyone have a noticable tickign/knockign sound when they put their ears close to the engine????? please respond and i dont think its a bomb
Oct 21, 2004 | 05:46 PM
do you use 93 octane or the cheap stuff???
Oct 21, 2004 | 05:57 PM
it is most likely your injectors, or the IACV.
Oct 21, 2004 | 06:01 PM
on the injectors...
Oct 21, 2004 | 06:14 PM
Quote: do you use 93 octane or the cheap stuff???
If your refering to detonation, it wouldn't be happening while the car is at idle.
Oct 21, 2004 | 06:35 PM
so if it is the injectors how would you go about solving the problem, because i have a similar problem, and gas additives have not helped.
Oct 21, 2004 | 06:39 PM
Quote: so if it is the injectors how would you go about solving the problem, because i have a similar problem, and gas additives have not helped.
Its not a problem - its just a characteristic of the injector design.... nothing you can do about it.
Oct 21, 2004 | 09:38 PM
yeah, this is defenatly NOT a problem ! thats how injectors work.
Oct 21, 2004 | 11:17 PM
yeah i use 93 so jsut dont worry about the sound?????
also where is the Front Left Heated O2 sensor is the the one one the y pipe closest to the cat?
Oct 22, 2004 | 02:19 AM
you are hearing a combination of things which are perfectly normal for the most part, you are hearing lifter and valve noise, spark plug ignition, and injectors pulses....
