This Might Be A Stupid ?
Old Apr 19, 2001 | 09:55 PM
timby01's Avatar
This is prob a stupid ? but i just bought 17's and am putting them on a 97 SE now if i get a flat can i put my stock donut or do i just have to call a tow Lol
Old Apr 19, 2001 | 11:06 PM
Chunger's Avatar
My other car is a Hybrid
Should be fine unless the diameters (of the tires) differ greatly then you would have to drive slowly to a service station to avoid messing up the drivetrain due to the rotational speed difference between the remaining good tire and the donut.
Old Apr 19, 2001 | 11:11 PM
Matrix's Avatar
well
if you follow the correct upsizing, your 17's should be the same diameter as the stock configuration
So if you didnt have to adjust your speedometer and odometer when changing your rims, they should still be within spec.
Old Apr 20, 2001 | 12:52 AM
BriGuyMax's Avatar
Actually you should NEVER drive very far with a NON-full size spare on either of you drive wheels. Because even though they are near the same diameter...they are still different, and you can mess up your drivetrain. The SMART thing to do, even though it takes more time, is IF you get a flat on one of your front tires.....swap a rear with the front and put the spare on the rear.....you can drive til the spare runs out of tread on the rear...although I don't recommend it.
Old Apr 20, 2001 | 06:19 AM
timby01's Avatar
I have 17's wrapped in 235/45's that is the correct offset so i should be ok thanks for the help
Old Apr 20, 2001 | 07:12 AM
Daniel B. Martin's Avatar
Please elaborate
What do you mean by "mess up your drivetrain"? Would some part wear out? Break? Which part would be damaged, and why? Please elaborate.
CorollaULEV
30
Aug 9, 2021 08:11 PM
pears
Sep 18, 2015 05:25 AM
A32goldylocks
Sep 16, 2015 01:33 PM
carlosvq30
Aug 17, 2015 11:32 AM
edsmax
Nov 10, 2000 05:22 PM
