DOT3 or DOT4?
Old Dec 25, 2004 | 09:41 PM
joew's Avatar
DOT3 or DOT4?
Are we using DOT3 or DOT4 for our brake fluid?
Old Dec 25, 2004 | 09:47 PM
kcryan's Avatar
i believe that either will work as they are essentially the same but dot 4 has a lower moisture content BUT i could be wrong here i'd wait for conformation or go with the DOT 3
Old Dec 25, 2004 | 09:53 PM
MDeezy's Avatar
They say DOT 3 or DOT 4, but manual says DOT 3.
Old Dec 25, 2004 | 09:56 PM
mm347's Avatar
DOT3
If you're looking to upgrade your brake fluid then I would recommend ATE Super blue (blue color fluid) or TYP 200 (gold color fluid).
http://www.raceshopper.com/brake_fluid.shtml
Some info about brake fluids -->http://www.rpmnet.com/techart/fluid.shtml
Old Dec 25, 2004 | 10:46 PM
joew's Avatar
how many bottles do you need to flush the whole system with Super Blue?
Originally Posted by mm347
DOT3
Old Dec 26, 2004 | 07:57 AM
outsider's Avatar
dont dot 4 have a higher boiling point?
Old Dec 26, 2004 | 08:00 AM
kcryan's Avatar
Actually what i use is Valvoline Synthetic stuff its like a dollar more than the cheap crap its DOT 3 and DOT 4 certified and i trust it enough to use it in my Allanté which has a insanly tempormental and very early Bosch ABS III system so i tend to use what i consider the best stuff. i have had no problems with it and i know it has a higher boiling point that the cheap stuff....i would reccomend it
Old Dec 26, 2004 | 08:45 AM
RI-Max's Avatar
i got a ATE superblue in my brake system and clutch system 2 its nice and blue
Old Dec 26, 2004 | 09:55 AM
Brudaddy's Avatar
I think you can technically use either, but I would just use the DOT 3.....most people do.
Old Dec 26, 2004 | 10:08 AM
A32Matt's Avatar
i just picked up some Valvoline Synthetic brake fluid. I'm gonna flush my brake system soon to see if it improves my braking any because i know the fluid i have in there now is beat.
Old Dec 31, 2004 | 09:56 PM
viet_racer22's Avatar
i believe we're supposed to use DOT 3. it says to use DOT 3 on the cap on my 96 maxima.
talkinghorse
Oct 5, 2013 06:27 AM
deadmax96
Jul 10, 2008 10:08 AM
Nealoc187
May 27, 2007 11:42 AM
Nealoc187
May 25, 2007 07:12 AM
d00df00d
Apr 5, 2007 07:21 PM
