imobilizer disable?
Old Jan 20, 2005 | 03:46 PM
joosdawg's Avatar
imobilizer disable?
i cant find info on this just wondering if theres a way to disable the imobilizer so i can use a copied key or somthing? or how about this... how come somone cant figure out what you need to take out of the car in order to use a technosquare or jwt ecu? how about the whole engine ecu ignition WHAT?? i have a 95 ecu here to use hahaha yea right to bad my 99 DOESNT START and it just makes me mad!! i need feedback people what has everyone tried in order to make the ecu's work?
Old Jan 20, 2005 | 06:41 PM
chuckie311's Avatar
you have to swap some pins to make the 95/96 ecu work in the 99s
Old Jan 20, 2005 | 06:44 PM
Ant96GLE's Avatar
99 ECUs have different harnesses and Emissions systems, this is probably like the 10th time I've read something like this and I'll give the same answer. The only example I can give was from my car, I had an issue where my 96 had an ECU from a 98 or 99, the rear 02 sensor for a 96 has only 3 prongs on the plug, 98-99 has 4... obviously its not interchangable. It would give me a CEL immediately even after I cleared it. It took an electric guy to check it out for me.
Old Jan 20, 2005 | 07:10 PM
chuckie311's Avatar
thats impossible you cannot run a 99 ecu in a 96ecu and a 96 ecu in a 99 the pins for the fuel pump and the position camshaft sensor`s are in different places. you car would not start.unless you moved the pins around
Old Jan 20, 2005 | 07:21 PM
joosdawg's Avatar
so what if i switched the pins? why do i not know of anyone that has been able to make a 99 run with any other ecu besides its own if its just switching pins around?
Old Jan 20, 2005 | 07:30 PM
chuckie311's Avatar
you can try switching the pins around. i just havent had the time to do it..i pretty sure if you switch the pins to the correct pinouts of the 96 ecu you can get it to work.i have the picsout for te 96 and 99. but right now my car is been worked on with other problems. by the summer i will get it working. if you want pm me with your email and ill send you the spread sheet i have for the ecu differences
Sport
Jul 3, 2017 05:40 PM
A32goldylocks
Sep 2, 2015 06:39 AM
rbaker100
Aug 31, 2015 11:09 AM
Gildarts
Aug 31, 2015 07:10 AM
JimmyH
Jan 15, 2002 11:42 AM
