hard starting problem
Old Jan 22, 2005 | 10:50 AM
staytuned24's Avatar
I bought my 95 max last year in may the starter was bad i changed it the car give some problem to start up i changed crank position sensor the sub harnest.i fanally tought that the problem was fixed but this morning i went out to start it but it wont start up it just keep cranking. its only really bad when its cold.
Old Jan 22, 2005 | 10:54 AM
MDeezy's Avatar
when last was your fuel filter chaned?
you checked both crank position sensors?
Old Jan 22, 2005 | 11:26 AM
i recently changed the gas filter and i replaced the crank sensor by the front pully
Old Jan 22, 2005 | 11:33 AM
njmaxseltd's Avatar
Crank sensor POS will cause a no start condition. It's located under the car on the transmission bell housing. It looks at the flywheel.
Check the resistance of the engine coolant temp sensor. Make sure it's within specs at the specified temperature. If it's not, change it.
Old Jan 22, 2005 | 11:48 AM
i changed the coolant sensor already. does any one think its a bad ecu harnest.the car also have 167k miles.
Old Jan 22, 2005 | 01:02 PM
abongo's Avatar
Ignition switch might be the problem.Replaced mine 2 yrs ago and never had starting problem again
Old Jan 22, 2005 | 04:13 PM
exit10's Avatar
i have the ssame problem, how do u check the ects?
02PearlSE
Oct 7, 2015 02:12 AM
Tha'-Max
Aug 30, 2015 01:14 AM
305head
Aug 26, 2015 09:03 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Gsantos79
Aug 8, 2015 07:41 AM
