Technosquare ECU revs up to 7100 :)
#81
Originally Posted by I30tMikeD
The impresive part of what Requin6 posted is where you will be in the power band (for a 5spd at least). Look at the two curves, w/o the JWT ECU from 4.5k-6.5K and w/ the JWT ECU from 5K-7K. The average HP for the JWT ECU in that range is 188.43 and the stock ECU is 178.59.
#84
#86
Originally Posted by laylow1988
if i plan on doing fuel pressure regulator, 370cc injectors,and walbro fuel pump should i get these things done first before doing ecu upgrade or does it not matter.
Anyway, back on topic, congrats Deezo. Hope they come out with the 5-speed version by the time my b-day comes around.
#88
Originally Posted by IceY2K1
I don't have an auto, so I'll leave that up to deezo.
However, 5th gens might need this *IF* the TS ECU ever comes out.
Baggy is right about the JWT. I've heard some guys say that they didn't like it.
Thanks Nismo.
#90
Originally Posted by slimer
there are so many probs with the level ten units. i would go with the nrh or the max tuning instead.
#91
yeah, jeff does bulletproofing. dont you already have a vb from him? i thought that i remember you mentioning it a while ago.
he redoes all the gears and t/c. you may want to pm redmax and maybe latinmax, they both have or had nrh trannies.
#96
Originally Posted by SR20DEN
Do we need to get a list of specific part # or build date ECUs for this or have they finally cracked ALL of the '95-'96 ECUs?
#98
#99
Originally Posted by deezo
Brian told me that they are trying to figure out why my ECU works (7100 Rev Limit) and others don't. I would say a specific build dated ECU should work for everyone that has one. I'll have to look at my ECU to see the actual date on it and list it here. It is a 96 ECU though.
#100
hey guys where do i go to buy a ecu for my 1995 se maxima a guy sold me a car that come to find out had been under salt water. it ran 4 3 weekks and then died i might also need a new motor please help!!!
#103
Jet Performance ECU Upgrade
Hello,
Someone please tell me if this is wrong ? I'm pretty sure everyone has heard of Jet Performance. So I called them up like couple days ago. I talked to one of there people and apparantely they are saying for $299.00 thats with shipping you can get
Advanced timing
Better fuel map
Getting rid of the governer
and rasing up your rev limiter . . . didn't exactly said how much more . .
thats the information I got when I called turn around is about 2-3 days max. If anyone knows about this or dealt with them please help ! ! !
Advanced timing
Better fuel map
#105
So I guess what they say is basically BS. Well I appreciate it to be honest with you, so would you know any other place to upgrade an ECU that can actually get it done on 1998 Maxima 5spd. I know this talk is going for Techno Square 95-96 Ecu's and etc.
Thanx .
Thanx .
#106
No one modifies 97-99 ECU's. Your best bet is to get a 1996 ECU and send it to JWT if you want a plug and play solution. If you want to go all out and don't mind tuning, getting a Emanage Ultimate will beat any plug and play ECU on the market. The problem with a plug and play ECU is that it is a generic tune, and every car is different. One program cannot be everything to every car. With an EU, you can adjust anything you want, anytime you want, and customize it all to your car.
#107
^^ Agreed, like, alot.
If you're on a budget though get an afc, fpr, and some dyno time, bump fuel pressure, pull maf voltage = timing advance.
God, this is disgusting, such a beautiful thread has been disgraced.
"hey guys where do i go to buy a ecu for my 1995 se maxima a guy sold me a car that come to find out had been under salt water"
Damn, that's ****ed up. I think you might also need a new car. You should toss that thing back in the ocean, it's probably worse off than the last couple 5-speeds I bought for parts cars.
#108
Apologize for being the PIA , but no I'd rather go all out and get EU OR EUB as long as it gets the job done, which I'm pretty sure it will. Just gotta get it dyno tuned i guess huh .
Thanks !
Thanks !
