How Much to Replace this?? ***PICS***
I wanted to ask how much it would take to replace my left rear quater panel and also does a 95/96 rear quarter panel fitted perfectly on a 97??
This aint my pic, its a pic of Zach95SE car he just fixed
I've had that same type of thing since I got my car....cept mine is right in the corner by the tailight...I needa get it fixed soon and got quotes and it seems cheap but it can't be replaced unfortunately.
to replace will be a pita cause there are alot of spot welds that you have to remove before it comes off. body shops only replace it when it cant be repaired. if you just have a dent, a body shop will bang or pull the dent out, then use plastic filler like Bondo, smooth it out, primer it, then paint it, then clearcoat it. plus they have to color match it and then wet sand it so it will look like the rest of the car.
So its impossible to replace theQuaterpanel? Because i think mine has a 97 Quater Panel on the left side and a 95/96 Quater panel on the right..........because myrear will on the left side is kinda poking out, while my right rear wheel is poking In........ any idea what this could be?
Originally Posted by Makavelidadon
The Pic Is Not My Car, Im Just Using It To Show You What Im Talking About.
Vsamoylov
Quick question, so i all 95-99 maxima rear quater panels are the same? is it expensive to put it back on a frame and pulled back to specs???? please i need a lil bit more info on this .
I have no clu e how much a body shop will charge to put the car on a frame and pull it back to specs. all body shops have a different price. do you have a pics of the car in the rear? what i suspect if there are gaps, the car was hit in the back and somebody did a crappy job fixing it.
dvcamp
09-18-2015 10:17 AM
Maxima30
09-07-2015 06:13 PM
