1156 or 1157??
Old Apr 4, 2005 | 05:00 PM
MystA RavE's Avatar
1156 or 1157??
What type of light bulbs go into the corner lights without any customizing...1156 or 1157?
What type of bulb goes into the bumper lights?
Old Apr 4, 2005 | 05:03 PM
CleanMAX98's Avatar
1157..................
Old Apr 4, 2005 | 05:56 PM
michaelnyden's Avatar
are you asking for a bulb that will be bright like the second filament of the 1157? then get the 1156...as it's only the high filament of the 1157...so you won't have to cut the nub and do all the customizing...
Old Apr 4, 2005 | 06:02 PM
MystA RavE's Avatar
So its 1156 without customizing for the corners...how about for the bumper lights?
Old Apr 4, 2005 | 06:41 PM
THT's Avatar
THT
Throbbing member
Bumper lights are 1156 and 194
~THT
MystA RavE's Avatar
thanks a lot!
Old Apr 4, 2005 | 08:04 PM
maxiquin's Avatar
which one is the brights lights for the bumbers?
Old Apr 4, 2005 | 08:07 PM
CleanMAX98's Avatar
1157's r the normal brightness with no mods 1156's are the super bright ones
Old Apr 4, 2005 | 08:12 PM
Ceasars Chariot's Avatar
Old Maxima Legend
http://www.cardomain.com/memberpage/341792/5
Old Apr 4, 2005 | 08:19 PM
MystA RavE's Avatar
Wow thanks thats exactly what I was hoping for..i
Old Apr 6, 2005 | 09:36 AM
BLaKtOut's Avatar
okay isnt it the other way around that 1157 wth the 27 watt filement is brigther than the stockk 1156
Old Apr 6, 2005 | 10:50 AM
DAVE Sz's Avatar
Hooooooonda.....
How so since the 1156 still has 2 nubs on it? He'll have to cut one off anyway won't he?
Old Apr 6, 2005 | 11:19 AM
BLaKtOut's Avatar
so if wat im reading is true the 1156 will put out a brighter filment even if there is a 1157 higherfilment in there
Old Apr 6, 2005 | 11:44 AM
RicoSuave98's Avatar
how does 1156s work where 1157s go? am i reading this right? 57s have 2 contact points on the bottom, while 56s have 1. how does that work?
Old Apr 6, 2005 | 12:53 PM
pavelsmax's Avatar
i think the contact that will be made on the 1156 bulbs in the corners will light it up to how bright 1156 bulbs always are
the 1157 bulbs have 2 filaments dim and bright i believe the bright appears to be the same as the 1156
i know this is confusing i have never tried this but i believe it is correct
1157 2nd filament = 1156
Old Apr 6, 2005 | 03:24 PM
if memory serves, that is correct...the 1156 is an 1157 bulb without the dual filaments, and the only reason you cut the nub on the 1157 is so it conacts opposite so the higher filament contact point is always being activated...whereas on the 1156, there is only one to be activated...
Old Apr 7, 2005 | 07:32 AM
BLaKtOut's Avatar
ya i know cause u cant twist it in with the 1157 numbs if you try to invert it but i alwaus thought that an 1157 on the higher filment was brighter than a regular 1156 bulb
Old Apr 7, 2005 | 11:48 AM
it is, but by only 6w....so 27 instead of 21....
Old Apr 7, 2005 | 11:53 AM
SiCkBLaCKMaX99's Avatar
why did nissan even put an 1157 bulb there anyway what were they thinking?? were they goin to make it work with the blinkers and then just gave up??
Old Apr 7, 2005 | 12:46 PM
Kevlo911's Avatar
Kevlo for President
In 95/96 the one side gets bright when you turn on the signal. Why doens't hte 97-99 do it? No idea...
BippuBenji
Aug 22, 2001 10:12 AM
Vudoo1313
Jul 26, 2001 09:31 AM
MJM97MAXSE
Jun 11, 2001 09:42 AM
Ch12i5
Jan 12, 2001 06:56 AM
