Power steering pump problem
Old May 3, 2005 | 07:31 PM
Zero9890's Avatar
hey guys
I had to bring my car in a few weeks ago to the dealership for some things and when they were doin a check up, they said that my power steering pump had a tiny leak in it and the fluid was leaking on the belts which caused them to sqweak. They wanted $1000 to fix it!! $500 for the pump and $500 for labor.
I noticed a wet spot on the rubber boot (not sure what its called) thats on (i think) the axel right below the pump and i noticed that the level of fluid in the tank is going down VERY VERY slowly (Although i might just be seeing things). But i never see any spots on the drive way from leaking fluid. I know this problem is minor at the moment but i know that i am not payin the stealership to do this.
Once in a while the belts will sqweak but i have never noticed any problems in the proformance of the power steering and the decrease in fluid has been very very minor, if any.
Should i go to the junk yard and try to pick up a power steering pump and install it myself? Im sure that it isnt too difficult.
OR
Should i just leave it alone since even if there is a leak it is very very minor and hasnt caused any problems?
OR
Is the power steering pump perfectly fine and the stealership is just after my money?
Thanks in advance
-Chris
Old May 3, 2005 | 10:31 PM
Who's Avatar
Who
My cousin's car has an oil leak that seems to be coming from the power steering as well. His mechanic told him that it is a power steering pump leak but when I inspected it, I saw that the oil was actually coming from the rear valve cover and leaking down onto the rear manifold and power steering. I had the same problem with my car about a year ago so check the valve cover before looking for a power steering pump. If it's the valve cover then you would just have to get that resealed with some new silicone.
Old May 4, 2005 | 08:32 PM
Zero9890's Avatar
thanks for the advice, ill be checkin the rear manafold, valve cover and anyother place it could be coming from tomorrow.
Old May 4, 2005 | 08:34 PM
Nismotic's Avatar
Always sunny in philly
power steering is a b!tch to do alone, but any local garage can do it for under 300.
MAXSE5SPD
Sep 17, 2022 04:00 AM
The Frye
Sep 2, 2021 11:03 AM
intimidator
Sep 5, 2015 07:23 PM
sdotcarter
Sep 2, 2015 09:53 PM
coasterswim
Sep 2, 2015 07:43 AM
