Breaks go SQUEEEKK!!! verrryy annoying...help!
Old Jun 22, 2005 | 03:50 PM
monty95's Avatar
Whats up guys. I just had my brakes changed a couple weeks ago and i noticed that when its wet out, they squeek soo loud. This happens probably the first couple times i brake (when the car is cold). I took it back to my mechanic and he said he didnt hear anything and that he checked the breaks and nothing was wrong with them (cuz they're brand new). On a rainy day (like today), they squeek much more often. They didnt squeek at all when it was sunny and dry out...anyone have any ideas on what could be wrong? he did say that he would replace them if they still continue to squeek. Thanks for any help.
EDIT: Im so stupid. BRAKES not BREAKS!
Old Jun 22, 2005 | 03:59 PM
MDeezy's Avatar
What kind of pads are they? Sounds like the pads are retaining water when its wet which is causing the squeeking sounds.
Old Jun 22, 2005 | 04:14 PM
sunten1
My brakes do the same thing. the second the temp drops like below 40 squeeek squeeeeeeeeeeeeeeeeeeeeekkkkkkkkkkkkk!!!!!!!!
But i dunno what pads i have on...
Old Jun 22, 2005 | 04:30 PM
monty95's Avatar
yeah, Im not sure what pads i have either. Yeah..mdeezy i was thinking the same thing. Because whenever there's moisture i think they squeek. Whats the best solution? should i just have him replace them?
Old Jun 22, 2005 | 04:37 PM
Bobo's Avatar
Find out what kind of pads they are and ask him if he put any anti-squeal on them. If he didn't you would think they would squeal on dry days too.
Old Jun 22, 2005 | 07:20 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
tell him to fix the brakes, brakes are not supposed to squeek any time. if the tech was a good one he would of resufaced the rotors, regrease the slid pins and re grease the anti rattle springs. and also regrease the piston to pad area and clean the side shims and grease them up to. only place you do not want to have grease is on pad to rotor area. everywhere else should have some kind of silicone or grease, and should of bled the brakes.
Old Jun 22, 2005 | 07:57 PM
monty95's Avatar
thanks guys....Im gonna have them replaced on friday. the tech is a family friend...so....i dunno....you really cant trust any mechanic these days.
Old Jun 23, 2005 | 06:55 AM
laylow1988's Avatar
ditto and if that doesn't work just do the fred flintstone
Old Jun 23, 2005 | 09:36 AM
rg200amp's Avatar
not the pads
my 97 maxima dose the samething, i put dealer pads on mine, but its not the pads, its the rotors. they have burns on them, and they cant get shaved off. you need new rotors
Old Jun 23, 2005 | 10:48 AM
scrhale's Avatar
OMG I wish mine didn't squeak ... there isn't a time when mine don't. I broke a spring that holds the pad away from the rotor and now whenever I am at like 10 MPH and under I hear this horrible sound. It sounds like glass is about to shatter and it is beyond embarressing. Mechanic says everytime I change my oil/rotate ... he finds nothing wrong and doesn't hear them. Next time I go back I am going to have them take the top part of the caliper off and replace the springs I broke and hopefully this dreaded noice will go away.
James92SE
142
Jan 2, 2024 09:23 AM
D Mason
Jun 21, 2016 04:43 AM
fastcarny
Oct 12, 2015 07:06 AM
Need help
23
Oct 2, 2015 08:56 AM
jchronis2552
Sep 21, 2015 05:52 AM
