New CE Tails installed in Black Max
Old Jun 28, 2005 | 11:07 PM
  #121
DR-Max's Avatar
Hmmm......that's weird, that link that I posted is the actual cyrstal clear bumpers I'm going to purchase and the seller specifically said that the fronts are 1156. I wish I can take the lenses to the store however, none of the stores around here carry these clear/silver bulbs that light up amber. I'm getting all the bulbs needed for my red/clear tails and clear bumpers. I wanted to have the bumper lenses light up amber at night and clear in the day. I'm getting the bulbs from an internet source but somehow, they don't seem to carry clear/silver 194 bulbs that light up in amber. Do you know of a source where these can be found?
Originally Posted by TrackSmart
I think they are both 194. Just take the bulb into the store with you! Problem solved. But yeah, it should be 194. I looked it up for myself b/c I got clear bumpers w\ my red/clear order. 95% sure. Was 100% before Dr. Max...
Old Jun 28, 2005 | 11:14 PM
  #122
ewuzh's Avatar
http://www.autolumination.com/
Or you could just spray them yourself with some testors silver/gray spraypaint.
Old Jun 28, 2005 | 11:22 PM
  #123
DR-Max's Avatar
I found them thanks. Dang, I'm buying about $30 worth of bulbs. I wanted to switch out of the PolarG bulbs in my lamp lenses and go with silver/chrome instead. Tired of looking at the blue tint behind my clear corners and I wouldn't want to see it in my new clear bumper and clear tail lenses. The only thing that is not getting replaced are the 1157 bulbs behind the red lenses portion of the tails. I'm even getting a silver/chrome super white bulb for the reverse lenses.
Old Jun 29, 2005 | 04:14 AM
  #124
TrackSmart's Avatar
Originally Posted by DR-Max
Hmmm......that's weird, that link that I posted is the actual cyrstal clear bumpers I'm going to purchase and the seller specifically said that the fronts are 1156. but somehow, they don't seem to carry clear/silver 194 bulbs that light up in amber. Do you know of a source where these can be found?
ARRRRGH! Careful how you read my friend! The guy earlier asked about the LITTLE BULBS - the little ones are 194. These are the ones on the SIDE of the clear bumper lights. The front of the bumper lights use a larger bulb. Those use the 1156 b/c it is a turn signal, just like the rear turn signal which uses 1156!
Good luck man! Don't buy the wrong bulbs! Also, the Superlumination.com link has both 1156 and 194 silvered bulbs. All of them are $3 each. The website is annoying to navigate though. I hope they are a trusted site. I didn't order yet, so I can't recommend or not recommmend them...
Old Jun 29, 2005 | 06:55 AM
  #125
nadir_s's Avatar
vicodin ... gift of life
daaaaaamn
i dunno where i have been, first time i see these taillights. They look GOOD. I'm probably going to jump on the next GD ... hopin the fitment issues will be corrected. My cefiros already don't fit flush so i'm not sure i'm ready for taillights to do the same haha.
good work CE.
Old Jun 29, 2005 | 09:59 AM
  #126
mbandi's Avatar
Da'Burgh, Go Stillers!
Has anyone else received theirs and had a problem with the installation?
Just curious.
Old Jun 29, 2005 | 10:01 AM
  #127
MDeezy's Avatar
there is a thread going on about it. should be at the top or close of the 4th gen page. in short a demel was used to help it sit flush.
Old Jun 29, 2005 | 11:59 AM
  #128
MaxxedOut624's Avatar
Yeh I have a problem with the fitment on mine but just like they said Im gonna unscrew the metal stub and shave down the plastic a few mm and it should be all set....A LITTLE PROBLEM FOR SUCH A BIG ADVANCEMENT Id say.
Old Jun 29, 2005 | 12:14 PM
  #129
86maxima96's Avatar
I Broke OT
here here!!
Old Jun 29, 2005 | 12:20 PM
  #130
TrackSmart's Avatar
Agreed. I also had to shave down the plastic screw-holder. But it was more than a couple of mm. It was more like 5 mm in my case. Hopefully the new models will fit perfect on the first try. Mine look flush now, but after last nights rain-storm I can see that some water seeped in through the two outside tails (the ones in need of filing). I will have to buy some weather-stripping tape and see if that helps.
The rubber stripping around the tails is not very thick, so if it's not a really tight fit all the way around, it won't be water tight. So again, hopefully the new ones will be perfect first time around.
Old Jun 29, 2005 | 09:58 PM
  #131
ßaller's Avatar
Yeah, no video since my boy didn't show up. I had to shave 3-5m off. Now my trunk passenger side light, I have to redo that and get the weather stripping to seat better. I will take pics tomorrow. Overall hotness.
- ßaller
Old Jun 29, 2005 | 11:50 PM
  #132
ac465's Avatar
yea im having the same probs rite now. overall its not bad, but the weatherstripping needs replacing. part of it isnt fitting well.
Old Jun 30, 2005 | 07:56 AM
  #133
ethnic6's Avatar
too bad they don't have it for 97-99, did Custom Enterprise ever say when they will be comming out with a 97-99s?
Old Jun 30, 2005 | 08:23 AM
  #134
TrackSmart's Avatar
They have to order a minimum of 2,000 pieces, so it seems unlikely that they would make this exact type for the 97-99's since they already sell red/clears for those model years!!! I agree that the shiny look of the new ones are nice and give the car an "updated" more modern look. But the other ones are nice, too. Just more understated. Pics from their website:
95/96 [These will be completely clear-looking if you use silvered bulbs in the turn signals - about $6 for a pair]:
97-99
Old Jun 30, 2005 | 07:17 PM
  #135
Mishmosh's Avatar
On my 1995:
Outer tails plastic screw support (inner-upper): 4mm removed.
Inner tails: 1mm removed from all 4 plastic screw supports.
I wish the weatherstripping on the inner tails extended a mm or two more deeper.
Overall, I give props to CE. Nicely done.
Old Jun 30, 2005 | 07:21 PM
  #136
DR-Max's Avatar
So based on various comments regarding the rubber stripping that's on the new red/clear tails, I think a tube of black silicone sealant would be a good for peace of mind.
Old Jul 1, 2005 | 07:14 AM
  #137
mbandi's Avatar
That or some sort of weatherstripping. It is pretty flimsy. I had to stretch mine out because it was way to thick and kept the light from indexing the whole way. Nothing that can't be worked out.
Old Jul 1, 2005 | 07:32 AM
  #138
sdoherty_tjm's Avatar
leave the amber there, it makes you original, not just another set of red clears
Old Jul 1, 2005 | 07:38 AM
  #139
DR-Max's Avatar
Mine will not be just another set of red/clears.
Old Jul 1, 2005 | 08:20 AM
  #140
mbandi's Avatar
I've been waiting for these for 5 years! Everyone else can be original. I'll take the clear!
dank4us
34
Jun 10, 2024 03:45 AM
4doorGTR
Sep 11, 2015 04:09 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
220k+ A32
Aug 17, 2015 03:57 PM
Balkins
Aug 12, 2015 06:39 AM
