Wells Coil Packs?
Old Aug 14, 2005 | 03:06 PM
JwaxMax99's Avatar
Wells Coil Packs?
Has anyone been running Wells coil packs? AutoZone sells them for $64.99. Have used other Wells parts, just wondering how these might hold up in a Maxima...must be better than these OEM Hanshin I have that are failing one at a time....
Old Aug 14, 2005 | 03:22 PM
Kevlo911's Avatar
Kevlo for President
Get some OEM Mitsu coils for 5-10 dolla less.
Old Aug 14, 2005 | 04:17 PM
JwaxMax99's Avatar
I just ran to AutoZone and got 1 coil, installed it, reset SES light, Cyl. 1 misfire is gone, perfectly smooth engine again. I did buy 2 other Mitsu. coils for the previous failures. But, it's Sunday and I wanted the coil NOW, so I got the Wells.
OK, I also did some coil pack testing, Good Vs. Bad coil. I wrote down the values, and will report back to this thread ASAP. I did this because the FSM and Haynes test methods are different, and I have seen some post lately on this testing issue.
Edit: 79 Degrees F. in my garage. I tested all good coil packs, including brand new one. There are 3 pins on the connector.{ IB-G- + } All good coil packs had infinite resistance between + and G. The bad coil pack jumped around from 15 to 28 M Ohms.
(Red lead on + and black lead on G from multimeter)
Old Aug 16, 2005 | 12:45 PM
maxultra's Avatar
Great info. What year is your Max? I take it you had the infamous missfire. I have the same problem that I haven't got around to fixing yet. My car missfires at stop lights and sometimes while driving. It runs perfect in park though. I've been doing a lot of reading. I will try your test to see if I have a coilpack bad.
WES
Old Aug 16, 2005 | 03:08 PM
PTownMax's Avatar
I still miss the max
i too have the infamous misfire cyl #1, guess i might be trying wells as well
PH98I30
20
Mar 25, 2020 03:44 PM
gustavison
Oct 4, 2015 06:50 PM
jerrod99_se-l
Sep 23, 2015 10:29 AM
ballerchris510
Sep 11, 2015 05:29 PM
crazyespn
Sep 3, 2015 01:30 PM
