Some tell me the difference between knock sensor and coil packs..
Old 09-01-2005, 08:56 AM
Cashj2002's Avatar
the knock senor being bad and the coil packs being bad? I had a check engine light and the codes came up knock sensor and Ignition Signal Circuit
code. The car idled at 300 and the car spudders and hestates likes crazy. I put my foot on the gas and it doesn't move the car any faster.
I need to figure out what this could be?
Cashj2002 is offline
Old 09-01-2005, 08:58 AM
Mmmaxx's Avatar
Well that problem is your coil packs...Knock sensor just detects engine knocking....Your coil pack if not mistaken provides power to you spark plugs so they can spark...so if you have a busted coil pack then you will be misfiring, hence the really low idle and spuddering you are receiving.
Mmmaxx is offline
Old 09-01-2005, 09:13 AM
Maxima Owner
MaximaSE96's Avatar
if ur coil packs are not firing and it trips a code...it might trigger the KS code just because of the bad spark.....i would find which coil pack is not firing and have it replaced....check the stickys for the how-to
MaximaSE96 is offline
Old 09-01-2005, 09:57 AM
Blown
cardana24's Avatar
sounds like you have a bad coil Wayne. The KS is not going to make the car run crappy like that, it would just be a little down on power. Just borrow a coil from some one local and figure out which one it is. The KS code is probably just tripping because of how crappy the car is running.
cardana24 is offline
Old 09-02-2005, 05:06 AM
Cashj2002's Avatar
I checked the coil packs last night and they all were fine. So I am guessing it is the knock sensor.
Old 09-02-2005, 07:11 AM
InsneDrmr's Avatar
When my MAF went the car ran like that. Idled at 250-300 and would shut off. It didnt like me I guess. Anyway, fixed that then the car ran fine. I soon after replace my knock sensor to for sh*ts and giggles, just because the code wouldnt go away and now im fine.
InsneDrmr is offline
Old 09-02-2005, 10:21 AM
Maintenance Monster
dgeesaman's Avatar
Very unlikely. The knock sensor code can be tripped by the errors associated with other codes. So don't replace the KS until you've check the codes and found only the code for the KS by itself.
I suggest you double-check the plugs of leads for arcing (remove the plugs - it will leave a small black mark on the white ceramic), and test the ignition coils.
Dave
dgeesaman is offline
Old 09-02-2005, 01:42 PM
1 of few unmodded 4G Maxs
Wills98MaxSE's Avatar
a bad KS will cause hesitation, a failing coil pack (common on '99s) will cause rough idle and/or misfires
Wills98MaxSE is offline
Old 09-02-2005, 05:31 PM
Cashj2002's Avatar
I changed the knock sensor and its not that....
A friend said I should check the compression and some said I should check the MAF too. I really dont know what to check...
Old 09-02-2005, 05:40 PM
rdilemma
anyone have an idea why I would get a MAF code in the ecu, and then test the maf (with ohmeter) according to chitlins manual and the maf tests out fine, car runs fine, just gets 20mpg. (which i doubt has anything to do with the maf?)
Old 09-02-2005, 06:35 PM
tekneekzz's Avatar
this is off topic.. but speaking of one code makin another code show up.. lol i had a intake something something code and a ks code come up one time.. i replaced my fuel filter and both codes disappeared lol
tekneekzz is offline
Old 09-02-2005, 10:59 PM
AGRECORDS
knock sinsors are tricky 1 wire could vibrate it on and off
Old 09-03-2005, 05:42 AM
njmaxseltd's Avatar
Your MAF sensor has quite a bit to do with your gas mileage. Testing it with a meter doesn't simulate real live conditions which your ECU sees.
You have poor gas mileage, an indication something is wrong and a MAF sensor error code.
Geeeee I wonder what could be wrong with your car?
njmaxseltd is offline
Old 09-03-2005, 06:16 AM
SLC I30t's Avatar
Hey wayne-
I would try to trade coil packs out with another orgy to test fire a different set of coil packs. you figure the ones on your car are like 8 or more years old. the wires may be chaffing or corroded. You can always do a visual inspection of the MAF. and using a ohmeter is a fine way to inspect your maf. since all it is heating element testing its resistance is fine. If your car still has problems I would start to look at compression and other things. Did this just suddenly happen or were you running the car hard.
SLC I30t is offline
Old 09-03-2005, 11:40 AM
Cashj2002's Avatar
This just suddenly happend... The night before it was running fine. Then the next morning it started to run crappy. I got a another code this time its a single code 0201 which is that someone Ignition Signal Unit.
bbsitum
09-06-2019 07:31 PM
-ReLLiK-
04-29-2016 06:25 PM
220k+ A32
09-11-2015 02:18 AM
Quick Reply: Some tell me the difference between knock sensor and coil packs..
