Headlight Removal Issues
Old Jan 13, 2006 | 06:53 PM
  #41
Tatanko's Avatar
Bacon Lover
Originally Posted by Northern Maxima
Wow, that's crazy! My headlights are so crappy...they're covered in road salt so my visibility is way down plus I have to drive about 20km of dark roads to get to work. Maybe I should consider this instead of rims...???
Make sure you keep the receipts for everything just in case you ever have an accident and they're damaged...that way you have proof of how much you spent and hopefully you would be able to get the money back.
Yeah, good idea. Hopefully I can find the old emails.
I would definitely consider them if I were you. They are by far the best mod I've done, and that's even considering all the bad luck I've had
Originally Posted by maximus_96
the bezel and projector glass will not be trapping all the heat in. if you leave the leds on while the hid bulb is on, you will be killing the leds way earlier than their normal lifespan. then you'll have to bake the headlights again to remove and replace them. further more, you won't be able to even see the leds when the hid bulb turns on because the hids are so much brighter.
Alright, alright. Perhaps I'll wire them to a switch or something.
Old Jan 13, 2006 | 07:36 PM
  #42
Tatanko's Avatar
Bacon Lover
Here's what the ruined capsule looks like:
Old Jan 13, 2006 | 08:32 PM
  #43
maximus_96's Avatar
since the capsule is glass, you can actually scrape the melted residu off with a razor blade and clean with alcohol. some people get by with scraping the ceramic coating off D2R bulbs to fit them into D2S projectors so you can easily clean off this bulb.
Old Jan 13, 2006 | 08:45 PM
  #44
Tatanko's Avatar
Bacon Lover
Hmm. Just took a sharp knife to it, and you're right...it comes off. I'll try cleaning it up and installing it tommorrow.
Old Jan 13, 2006 | 09:55 PM
  #45
maximus_96's Avatar
just make double sure there are no traces of the crap on the bulb. it can get real ugly real fast if you turn it on w/o being completely clean.
Old Jan 14, 2006 | 04:31 AM
  #46
maxgtr2000's Avatar
KH3 by popular demand
You might want to let it dangle from somewhere 9attached to the igniter)that won't be touching anything and let it "burn off" any junk for a few minutes. Wipe down with alcohol and let it dry for a couple minutes before initially turning it on.
Old Jan 14, 2006 | 07:19 AM
  #47
Tatanko's Avatar
Bacon Lover
Yeah, when I was scraping the stuff off, I took the knife over it for a good 15 minutes even after all the "visible" stuff was gone and the surface seems completely cleared off to me. I'll still use the alcohol and let it burn for awhile, too, though.
Old Jan 14, 2006 | 09:52 AM
  #48
Tatanko's Avatar
Bacon Lover
Well...one problem fixed, another created. Got the passenger's side bulb all cleaned off and working, thought my troubles were over. Now the driver's side light is out! w00t!
Here's the issue...SOMETHING is messed up with the ground wiring on that side. I set the metal casing of the ballast on the negative terminal of the battery and voila...it works. Can anyone reccomend me a temporary solution to grounding that ballast directly to the negative terminal until I can get the wiring taken care of?
Old Jan 14, 2006 | 12:17 PM
  #49
Tatanko's Avatar
Bacon Lover
...and never mind. Made myself a ground wire from the ballast to the battery, issue solved. New daytime and night pics to come
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
Maxima30
Sep 7, 2015 06:13 PM
sdotcarter
Sep 2, 2015 09:53 PM
