~~hid Help Please!
Old Feb 8, 2006 | 05:14 PM
stronium_95se's Avatar
~~hid Help Please!
hey guys,
does this look correct? i plugged everything in, but the hids dont turn on. i even tried switching the black wire to the other side, but still nothing. i did the 9007 conversion, so do i need to do anything else? i bought the helios kit and it comes with two fuses, do i need to use it? any help would be appreciated. Thanks
Old Feb 8, 2006 | 05:28 PM
Mxrider52's Avatar
I support for what?
Well duh the fuse plugs in somewhere there should be an opening but it somewhere i think on the kit you bought
Is there a spot on the small black wire next to the small yellow wire
Old Feb 8, 2006 | 05:37 PM
no there isnt any plugs on the kit itself. :\
Tatanko's Avatar
Bacon Lover
YES, you NEED the fuse. Ask me how I know
Also, the 9007 may factor into it. I've never done the 9007 conversion, but do you switch the low beam wire around at all? If so, the wiring for the ballast is probably set up so that because of your conversion, it's not getting the signal to turn on.
Old Feb 8, 2006 | 05:53 PM
It says "Replace the fuse with the 10A fuse that comes with the package if necessary."
but doesnt say where!
Old Feb 8, 2006 | 05:59 PM
RockfordMax's Avatar
Back from the dead
well for the headlights there are fuses in the stock wiring. Either inside the engine bay, or inside the cabin. Check all of those. If any are blown, replace. They shouldnt blow from this kit however (unless you did something while installing it) because it doesnt draw enough power from the stock harness to blow it. There look to be inline fuse holders between the igniter and the bulb on that harness. Are those fuses in place?
Old Feb 8, 2006 | 06:30 PM
i dont think anything is blown. i plugged my regular bulbs back in and they worked fine.
Old Feb 8, 2006 | 06:46 PM
NCSU_MAX's Avatar
Maximoneypit
lol, nice
Old Feb 8, 2006 | 06:51 PM
n3985's Avatar
大陆弟弟
Ever heard of a fusebox? Like the little plastic thing that houses all the car's fuses? One in the engine bay and one underneath the steering wheel?
You have the fuse supplied because HID kits can draw up to 75W for the first two minute, which could and have fried harnesses on cars as well as blow the fuse. Thus, the supplied fuse is either for replacement or backup. Odd thing is, usually they supply a 20A fuse
Old Feb 8, 2006 | 06:56 PM
Tatanko's Avatar
Bacon Lover
He said the one they supplied is 15A. Don't you think that if his regular lights still work he didn't blow a fuse?
I've been troubleshooting with this guy over AIM and I don't have any more suggestions for him :\
Old Feb 8, 2006 | 09:11 PM
anyone else? really want to get them installed tonight
Old Feb 8, 2006 | 09:24 PM
n3985's Avatar
大陆弟弟
Then convert your headlight back to factory form, prob will work then.
Old Feb 8, 2006 | 09:37 PM
maximabest's Avatar
the fuse is just in case you need it, i recommend you to replace the 10 amp fuse on your car.
Best Regadrs,
Old Feb 8, 2006 | 10:02 PM
Best Regadrs,
the fuses in my car are already 15A. could this possibly be a defective kit?
Old Feb 8, 2006 | 10:04 PM
maximabest's Avatar
hehehe defective kit?? dude that fuse is just an accessories not something that you most install in your car.
Old Feb 8, 2006 | 10:11 PM
ok. so your saying i should replaced the two fuses for my headlights that say (15V) with the two that were supplied in the kit? hahah i was so anxious to install them when i got home at 5pm, but still no luck! :\
Old Feb 8, 2006 | 11:38 PM
fixed!!! thanks to eckohb and everyone else for the help!
Old Feb 9, 2006 | 01:40 AM
ethnic6's Avatar
nice, those are some bright headlights
Old Feb 9, 2006 | 04:31 AM
njmaxseltd's Avatar
Wayyyyyyyyyyy to much glare.......
Old Feb 9, 2006 | 06:45 AM
n3985's Avatar
大陆弟弟
So what was the problem?
Old Feb 9, 2006 | 06:48 AM
maximabest's Avatar
there is no glare, most of the time when you take pictures with some camera you cant take it without it cause the light is very bright. IF you want to take a picture without glare you need a pro camera.
Old Feb 9, 2006 | 08:00 AM
Tatanko's Avatar
Bacon Lover
After all that trouble, I'd like to know what was up
Old Feb 9, 2006 | 08:19 AM
maximabest's Avatar
What trouble??? there is no problem at all. Just one question
Old Feb 9, 2006 | 12:08 PM
Tatanko's Avatar
Bacon Lover
He couldn't get them to turn on. There was trouble.
Old Feb 9, 2006 | 12:14 PM
maximabest's Avatar
yes but the kit was perfect, thats my comment about this.
Old Feb 9, 2006 | 12:28 PM
mbandi's Avatar
Da'Burgh, Go Stillers!
The kit was perfect? Since the kit you sent me had both headlight connectors wired wrong, perfection you are still trying to reach my friend!!
Old Feb 9, 2006 | 01:26 PM
n3985's Avatar
大陆弟弟
Maximabest, I did not want to say this at first, but I feel like I should for the HID n00bies. An HID kit in a halogen housing WILL glare, saying it won't glare is blatantly false and can be proven false.
Old Feb 9, 2006 | 01:31 PM
maximabest's Avatar
well there is a lot of comments there about it, also test, proofs etc. Its like someone says "yes" and others "no", its very difficult to have one opinion. If thats your point its ok, everyone can says it but you can put a d2r on the car and the results will be the same.
Best Regards,
Old Feb 9, 2006 | 02:39 PM
the problem was i had my red and black wires switched. i guess they change when you do the 9007 conversion?
but anways, i put the red on the right, black in the middle and BAM, we have sunlight
Old Feb 9, 2006 | 02:45 PM
Mxrider52's Avatar
I support for what?
Yep you have to switch out the wires glad it works good now
Old Feb 9, 2006 | 06:02 PM
Tatanko's Avatar
Bacon Lover
So I was right then about the 9007 conversion being the problem...
But you told me the kit was made for 9007, which is why I couldn't figure out what the problem was.
Anyway, glad to see you got them working. Now go and make yourself a homemade glare shield
Old Feb 9, 2006 | 07:14 PM
HomerMAC's Avatar
Donating i30 Owner
reminds me of when i was isntalling the wires for the cd changer thats gonna go with the oem navigation im working on... i was wondering why it wouldnt turn on.. then i realized.. i didnt plug it in....
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Mochedda
Dec 15, 2015 11:27 AM
Vistance
Sep 17, 2015 05:17 AM
MidnightMaxima_22
Sep 12, 2015 06:02 AM
