what paint to use for painting fog light lens?
Old Feb 17, 2006 | 09:28 AM
maximus_96's Avatar
I remember reading some of you painted your fog lights yellow. I got the CE fogs last night. Right now they're white and I want yellow fogs. Instead of buying yellow bulbs, I'm thinking of painted the lens yellow. What paint did you guys use?
or maybe I can use the yellow capsule. anybody know if the yellow H3 capsule fits in the CE fog lights?
Old Feb 17, 2006 | 09:37 AM
86maxima96's Avatar
I Broke OT
nismos14 is the man you want to talk to about painting. he painted the outside and also used a clearcoat. you mentioned capsules. even though we have an H3 bulb, I believe the H6 capsule is used because it isn't so tight on the bulb. also, you probably only need to go one or the other. you don't necessarily have to do paint AND capsules. the capsules create very yellow light, and paint can be a nice yellow as well.
Old Feb 17, 2006 | 10:01 AM
natty99's Avatar
or, go to www.lamin-x.com and put some yellow (or blue yeah!) protective film over them. I'm sure if you double the thickness you may get a nice yellow light output. Plus, easier to install and replace/fix than painting. Obviously more expensive, but I personally think painting the lens is hack...
Old Feb 17, 2006 | 10:23 AM
maximus_96's Avatar
this is for the Custom Maxima projector fogs...not the stock ones. i'd imagine putting a flat piece of film over a round projector lens will be lots of trouble.
Old Feb 17, 2006 | 10:42 AM
natty99's Avatar
i mean if the degree of curvature is severe, then yeah, you get those PITA wrinkles....I'm obviously not familiar with the CE ones, but if the curvature is shallow, no, it shouldn't be a problem, it's vinyl, it stretches. but do as you will, good luck with the project
Old Feb 17, 2006 | 05:45 PM
TLMNICK's Avatar
There is lens paint that you can get...I did mine, followed by a clear coat, and its holding up very well.
Old Feb 17, 2006 | 08:13 PM
nismos14's Avatar
§è~® f®ÈÄk
There you go bud, the info you need is in this thread
http://forums.maxima.org/showthread.php?t=454320
This is the paint I used
http://www.eautoworks.com/html/ord-A...int-1-5650.htm
and I bought a can of clear coat from Wal-mart and used that after.
6 -7 coats of the yellow then 3 - 4 of the clear coat.
The Frye
Sep 2, 2021 11:03 AM
mvm062
Nov 30, 2020 09:00 AM
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
