97 max start issues
Old Feb 19, 2006 | 09:47 AM
mxzmax's Avatar
97 max start issues
ok i got my 97 maxima and its throwing a 0701 and 0303 it cranks and cranks then finally starts and doesnt run good until it warms up, once it warms up it runs fine.
Old Feb 19, 2006 | 09:49 AM
mxzmax's Avatar
anyone that could know where to start any info would be grately appriacated
Old Feb 19, 2006 | 10:02 AM
tikiboom's Avatar
I need an intervention
This is straight out of the stickies:
0303
Diagnostic Trouble Code 0303 indicates a problem with the front Oxygen Sensor on the left cylinder bank. The left bank is also called the front bank. It is cylinders 2,4,6. A normal signal sweeps back and forth between 0.2 volts and 0.8 volts. This malfunction was detected when the Engine Control Module received a signal from the sensor which was a constant value of approximately 0.3 volts.
Possible causes include ...
- Harness or connectors (the sensor circuit is open or shorted).
- Defective Oxygen Sensor
0701
http://forums.maxima.org/showthread....highlight=0701
Old Feb 19, 2006 | 10:16 AM
mxzmax's Avatar
yes i dont care about the 0303 im sorry and i already read the 701 post
Old Feb 19, 2006 | 11:00 AM
njmaxseltd's Avatar
0701 - Multiple cylinder misfire
Figure out the misfire first, clear the error codes then see if the O2 code comes back.
Old Feb 19, 2006 | 11:01 AM
mxzmax's Avatar
ok i will ill get back to ya
02PearlSE
Oct 7, 2015 02:12 AM
official_style
Aug 29, 2015 10:10 AM
homewrecker
Aug 24, 2015 08:56 PM
maxinout93
Aug 20, 2015 02:17 AM
Balkins
Aug 12, 2015 06:39 AM
