Center Console Bulbs
Old Mar 9, 2006 | 09:00 AM
meezer's Avatar
I have a couple of bulbs out on my center console (95SE) around the AC controls. Can anyone point me to a thread or resource on what bulbs I need to replace?
Thanks,
M
Old Mar 9, 2006 | 01:49 PM
JPMax's Avatar
What's next!?..
Do you mean the bulbs inside the AC control unit? manual or auto climate controls?
Only the dealer sells them. I think they're like $4-5 each. (need 3 or 4)
Old Mar 10, 2006 | 10:15 AM
dariod's Avatar
If it is the digital climate control bulbs then you need 4 bulbs and only stealership sells them at about $5 a piece. They are little bulbs with blue rubber casing on them and the brown base.
Old Mar 10, 2006 | 03:45 PM
Tim96I30t's Avatar
If you are taking it apart look around there are detailed threads with pics on this very subject, entire dash conversions to blue leds etc.
You can buy alot of leds and resitors way cheaper than going to the dealer at $5 bucks a piece.
Old Mar 10, 2006 | 04:26 PM
Trajiksmax's Avatar
Proud Maxima Owner
Just like Tim96I30t said, Check the stickies for the LED mods. Another option is to get the whole climate control from your local Salvage yard.
Old Mar 10, 2006 | 04:32 PM
dgeesaman's Avatar
Maintenance Monster
Don't replace the whole thing, that's nuts. If you can get the climate parts out of the dash, then you can change the bulbs in 3 minutes. There are about 5 of them in total, just buy a full set for $20 and replace them all at once. The trickiest part is figuring how to detach each connector without damaging them, and if you have a helper to hold the control so you can see the connector well, you'll have an easier time than I did.
Dave
Old Mar 10, 2006 | 09:32 PM
95GLEMAXX's Avatar
wah tabout the lights inside the cruise control switch, light dimmer switch and security light?....are they replaceable or do i need the whole switch in order for the lights to work again?
Old Mar 11, 2006 | 06:58 AM
dariod's Avatar
Yes you need to buy the whole assembly you are better of buying it from the local junk yard because I had a hazzard switch light burned out so I went to stealership to buy it and they told me I need the whole switch to buy and it costs $200 so I took one from the junk yard for $5 and it works.
gigabyte
Jan 6, 2017 06:05 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
Noela
Sep 26, 2015 08:22 AM
