Is my dealer trying to gouge me?
Old Apr 1, 2006 | 10:27 AM
Coochie Coach's Avatar
I took my '97 to the dealer as it was pinging and the check engine light was on.
I've always done most of my own work, but I've got a lot going on these days and decided just to let the dealer do it.
He called to say it showed codes for a bad 02 sensor and a bad knock sensor. The price to replace these would be just over $1,000, and it would take him a few days to get the parts.
I picked up the car in the meantime. Looking around here, it doesn't seem like it should anywhere near $1,000 to do this job.
Am I missing something?
Old Apr 1, 2006 | 10:35 AM
matty's Avatar
They are charging you that much because they factor in the time to take off the Upper and lower intake manifolds to replace the knock sensor, when in fact you can replace it through the side if you have small enough hands. Purchase the $250 worth of parts and do all that your self
-matt
Old Apr 1, 2006 | 10:47 AM
Trajiksmax's Avatar
Proud Maxima Owner
Old Apr 1, 2006 | 11:04 AM
86maxima96's Avatar
I Broke OT
definintely tryin to drain every penny out of you. what kind of dealiership doesn't have O2 and knock sensors in stock?
Old Apr 1, 2006 | 11:16 AM
the_3d_man's Avatar
yeah I could answer that question before I even opened the thread... do it yourself. Use a saturday morning and invite a friend over.
Old Apr 1, 2006 | 11:20 AM
95bluse's Avatar
Not sure why your car is pinging if the knock sensor is bad. When your sensor is bad, your ECU automatically retards the ignition, to PREVENT pinging. The O2 sensor (if it's the rear one) can be left like that, since it's just a monitor for the CAT & doesn't affect performance. Mine has been intermittently tripping the cell for that past 3yrs, sometimes it just stays off for 6months
Your dealer is trying to use you to put his kids through college
Old Apr 1, 2006 | 11:23 AM
tikiboom's Avatar
I need an intervention
you could get a knock sensor and an o2 sensor(depending on whether its front or rear) for less than 200 shipped.
Knock sensor is easy enough to change if you dont mind a few drops of blood in your engine bay and i think o2 sensor you just unscrew and unplug.
Old Apr 1, 2006 | 11:29 AM
Maxima880's Avatar
Look at it this way. If you do it yourself, you'll be earning about $400/Hour working for yourself. Pretty powerful incentive.
Old Apr 1, 2006 | 11:34 AM
Scooobay's Avatar
knock sensor = 72 bux offa ebay + cheap shipping
02 sensor = 50 - 100 offa ebay or the org. + cheap shipping
Dealership = tryina to buy those new rims he ssaw inna magazine....with your money.
Old Apr 1, 2006 | 12:02 PM
wikidminds's Avatar
your dealer isnt really tryin to gouge u per se........he is trying to rip u a new @$$ hole!!!!!
do it urself. not that hard to do.
Old Apr 1, 2006 | 12:20 PM
njmaxseltd's Avatar
You more then likely don't even need the knock sensor.
The KS code usually always comes as a ghost code with emissions related error codes. Replace the O2, clear the error codes and see if the KS comes back. (I doubt it will) If it does, replace the KS as well.
Your local auto parts store will have O2's for your car for around 75 bucks.
Depending where it's located on your exhaust system, install takes about 1/2 hour. Make sure you get an OEM type that comes with the wiring harness and correct plug for your cars harness. It's just plug and play that way.
Old Apr 1, 2006 | 12:52 PM
Thanks, all. :thumb
Is there any qualitative differences between the Denso, Bosch and NTK 02 sensors? Looks like they all come ready to plug in.
Old Apr 1, 2006 | 12:58 PM
Maxima880's Avatar
I just bought a Genuine Nissan for $103. It's stamped Bosch.
Old Apr 1, 2006 | 01:23 PM
maltonboy's Avatar
Yeah i also have same question regarding O2 sensor, Which company manufactures these OEM O2 sensors and do our O2 sensors have a 3 hole plug adapter.......
Old Apr 1, 2006 | 04:24 PM
Motorhead52's Avatar
$1000 is a HUGE RIPOFF. You can change these things in your drive way in less than 45 min and thats if you don't know what your doing.
Old Apr 1, 2006 | 04:27 PM
D-Bo's Avatar
Droppin logs
Answer to this question is nearly always YES!!
Old Apr 1, 2006 | 04:54 PM
The local Kragen had a Bosch 02 sensor for $90. Clipped right in.
Interestingly, I called two other parts stores first, and they didn't have it in stock.
Thanks again, all. Hopefully I won't have to do the knock sensor, too. It doesn't look like fun, but I can see how it can be done without pulling the manifold. I'm surprised there isn't a special wrench for reaching in there. Kind of like how there used to be a special wrench for reaching the distributor lock bolt on a GM engine. Guess the knock sensors just don't go out that often.
I've seen a Snap-on ratchet with a long, upward curving handle with a flexible joint at the head that ought to be perfect for this.
Ahhh, here it is.
http://buy1.snapon.com/catalog/item....re&dir=catalog
Old Apr 4, 2006 | 11:17 AM
maxima1380's Avatar
Save some $$$$ and do it your self
Old Apr 4, 2006 | 11:40 AM
1995WhiteMaxima's Avatar
PLUS 10000000 and "WORD"... Don't be replacing sensors that aren't even busted! The o2 will continually trip the HS...besides, crawling under the car and replacing the rear o2 is work enough...haha.
Old Apr 4, 2006 | 12:08 PM
DR-Max's Avatar
You can save your money for the KS, replace it yourself. Use a long rachet extension + u-joint. There was a good how-to on this method but the link no longer works. There's another how-to in motorvate.ca , the method is a bit different and a painful one.
For the O2 sensors, shop around first, there are shops that would do it for a lot less. No need to let the dealer you.
Old Apr 4, 2006 | 12:22 PM
maxgtr2000's Avatar
KH3 by popular demand
Now why would the dealership try to stiff you?
Old Apr 4, 2006 | 01:58 PM
darklegend06's Avatar
I just replaced my sister's O2 sensor for the rear manifold and a coil pack, took me about 30 min to do everything (including the time to jack up the front end of the car) I got the O2 for $75 and one coil pack for $100, wasn't bad from the dealer. They know my face now so they give me discounts. I'm happy with my dealers and their parts department. Oh and I got a free brandnew hub cap for my mom's 98 altima.
Just do it yourself. Very easy. If you have the tools and time.
Old Apr 4, 2006 | 06:30 PM
Rooster286's Avatar
Don't ever trust the stealership for routine BS stuff like a KS. I had my car at a dealer near my work, to check on the engine. The noticed my brakes were worn and only wanted 1050.00 to replace my pads and rotors. It's a wonder they stay in business doing work at such great prices. All about the customer I guess
Old Apr 4, 2006 | 07:15 PM
maximaman10's Avatar
The knock sensor won't trigger the CEL. It is a ghost code. It will effect the performance by retarding the timeing to prevent engine knock. Do you have a standard emission or 50 state,( California )? It is easyer to change the standard than the 50 state.
Old Apr 4, 2006 | 07:57 PM
ScottV's Avatar
Yeah, just do it yourself...good luck!
Old Apr 4, 2006 | 08:16 PM
7/94 95 Max's Avatar
what a joke..i worked at a Nissan Dealership parts countere for almost 2 years and always had O2 sensors and knock sensors in stock. Its a basic stock order that dealerships always do. If you have a long magnetic stick you can change out the knock sensor in 20 minutes and thats if your an absolute spaz. I watched my mechanic do it at the dealership and he did it is 2 minutes thats no lie. Now thats a 2 hour job that he gets paid for and he did it in two minutes. and the O2 sensor is a joke..they are charging way too much..pay for the parts and do it yourself. Good luck
Old Apr 4, 2006 | 08:23 PM
PLUMMAXSE's Avatar
Ahhh, here it is.
Changing the KS is easy!!
I did it with a 12inch extension a u-joint,12 mm socket and rachet. Use the money you save by not letting the dealer rip you off and buy you some tools
D Mason
Jun 21, 2016 04:43 AM
mpbclutch33
Dec 26, 2015 11:11 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
AboveDaCloudz
Oct 8, 2015 11:25 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
