phantom grip lsd good or should i get a real one?
Old May 3, 2006 | 05:31 PM
nfo184's Avatar
is phantom grip worth it for $350??? or should i get Quaife ATB
(Automatic Torque Biasing) Differential for $1400 thats a lot better???
Old May 3, 2006 | 09:11 PM
MorpheusZero's Avatar
With LSDs you usually get what you pay for. If there's a diff out there for $350 then it's probably a good value, but yes the Quaife/torsen diff will be significantly better, especially around corners. Whether or not it's 4 times better... well, depends on how much you value money. It will never wear out, will significantly improve handling and instantly bias the torque, whereas a viscous LSD will take awhile to firm up and grip, won't improve handling all that much (but it will improve acceleration out of corners) and has a possibility of being.. crap, since it seems like they're a bit of a noname company. A clutch pack LSD also has its share of disadvantages, especially for FWD cars, which is why the phantom grip is most likely viscous.
Old May 4, 2006 | 12:13 AM
NismoMaxman2's Avatar
The only 4.5 gen in da 956
I have the Phantom Grip LSD... havent had any issues.. I got it for drag racing..
Old May 4, 2006 | 12:16 AM
NISMOPower's Avatar
Heard that Quaife doesn't make lsd for maximas anymore, is that true???
Old May 4, 2006 | 12:20 AM
I think so.
Old May 4, 2006 | 08:40 AM
Tim96I30t's Avatar
Get an I30 VLSD and drivers' side axle to make it work, they no longer make the quaife you can only get it used.
Old May 4, 2006 | 09:48 PM
Nealoc187's Avatar
SLOW
The phantom grip is not a viscous, it works by basically using 4 strong springs between two plates that press outwards against the spider gears in your stock diff, making it more difficult for the spider gears (and in turn the axles) to spin independently of eachother (the limited slip effect). It's worth about what you pay for it, or less. The phantom grip will damage your spider gears and leave metal shavings in your transmission if you still get 1 wheel spinning with it installed. when both wheels are spinning at same rate though, it does no damage. I have not driven a car with a phantom grip installed so I don't know how well it actually works first-hand, though I have taken transmissions with them apart, and I have installed them in a couple transmissions.
Old May 4, 2006 | 09:51 PM
So it's basically like a clutch pack except without the clutch? FTL... find a freakin Quaife or a VLSD.
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
dcardello
Sep 3, 2015 11:44 PM
crazyespn
Sep 3, 2015 01:30 PM
