i30 died while breaking
Old Jun 3, 2006 | 05:43 PM
Mr.Duck's Avatar
ok so my sister was driving the 96 i30t, and was turning into our street when the moron in front of her slammed on their brakes so they could get into the gas station, well my sister slammed on her brakes and abs kicked in, well than the engine just died, and it wont start again... any ideas?
when i try to restart it, it turns but and sounds like it wants to start, but it just doesnt, could it be the alternator...
ecu codes= p0446 or 0903 EVAP Canister vent control valve umm..
Old Jun 3, 2006 | 06:30 PM
Black Maxima
Check your battery voltage. If it's under 10 Volts it might be your alternator. Also, check your dash lights. If your Brake and Battery lights are on it's your alternator.
Old Jun 4, 2006 | 07:50 AM
TurTLe*'s Avatar
i think that code has nothing to do with the engine no starting. Check cranking voltage if its near 14v. An easy way is to get one those jumper boxes and leave it on there. If it cranks and starts then you know whats up there. Because if you have a bad alt, once you take off the box car should die. And if the box is fully charged and it still wont start then its none of your battery,starter, alt.
Old Jun 4, 2006 | 11:16 AM
clive's Avatar
100% chingon
Collision cut-out device has operated. Fuel pump is shut off. Reset it.
Old Jun 4, 2006 | 02:42 PM
Mr.Duck's Avatar
what!??! how do you do that?
Old Jun 4, 2006 | 03:20 PM
howitzer's Avatar
borrow an auto-tap and reset it i think.
Old Jun 4, 2006 | 03:41 PM
TurTLe*'s Avatar
OoOoo i rememer these on fords. wasn't there a physical reset switch somewhere.
Old Jun 4, 2006 | 05:55 PM
Black Maxima
WTF...I've never heard of something like that before.
Old Jun 4, 2006 | 06:26 PM
TurTLe*'s Avatar
its design for when a car thinks its in a accident it shuts off the fuel pump so then you won't blow up and/or leak fuel everywhere.
i had no clue nissan's did them as well. i just thought it was one of ford's failed plan. but there should be a fault saying that the sensor was triggered in the ECU .
Old Jun 5, 2006 | 12:18 AM
whitegold's Avatar
so.. we have one of these kill switche somewhere?
Old Jun 5, 2006 | 06:23 AM
Kevlo911's Avatar
Kevlo for President
Reset ECU? Nvr heard of it. One would think it would go off if the air bags go off. I didn't know we had this feature.
Old Jun 5, 2006 | 06:30 AM
speed racer's Avatar
That is strange. Can't you just reset the ECU to trick the car that it wasn't in an accident.
Old Jun 5, 2006 | 07:02 AM
clive's Avatar
100% chingon
I don't know where it is on the Max but there must be one. As far as I know, it is a Fed mandated requirement on all gasoline-equipped vehicles. I know where it is on my Sentra. Even my UK 1972 Triumph TR6 sports car had one, because it had fuel injection (running at 110 psi pressure!)
Old Jun 5, 2006 | 10:40 AM
Mr.Duck's Avatar
umm... so than what can i do?
Old Jun 5, 2006 | 01:04 PM
Maxima_Joe's Avatar
4th Gen Parts King
I honestly don't think we have any fuel cut switch. I looked in the fsm as well and there is nothing. I would try spraying some starting fluid(ether) into the tb to see if it starts. That will telll you if theres a fuel problem.
Old Jun 5, 2006 | 01:25 PM
clive's Avatar
100% chingon
Good grief. If there really is no inertia cut-out device on the Max, I am going down to the junkyard and taking one off the first Ford that I find. It's wired in line with the fuel pump fuse normally.
I suggest you check your i30 fuel pump electrical line. Got volts? Or not?
Old Jun 5, 2006 | 06:06 PM
Mr.Duck's Avatar
argh, looks like i will be towing the car to a shop, i tried jumping it, and that didnt work, so yeah..
James92SE
142
Jan 2, 2024 09:23 AM
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
maxima297
Sep 30, 2015 03:32 PM
uttadms31
Sep 30, 2015 05:24 AM
