The boost is loose!!
Old Oct 18, 2006 | 06:05 AM
  #41
buttonhook's Avatar
Originally Posted by Flava_24/7
imageshack, photobucket, cardomain, etc.......
You can use either of those to host them for free.
they are blocked from the computer I'm on. but you are right I do need a real pic as my sig. I may try to take one this weekend
Old Oct 18, 2006 | 06:31 AM
  #42
buttonhook's Avatar
Ive also read good things about the Vortech SFMU, you should be able to gain some by tuning with it.
Its not untill you start making more boost where you need to start really tuning, you will be needing bigger injectors by then.
Well I have a 2.87" pulley but I'm not going to put it on. the thing about the super fmu is that I'm running rich at the lower rpms. with the super fmu I could lean it out at lower rpms and richen it up at the upper rpms. so I would get good safe power.
Old Oct 18, 2006 | 06:42 AM
  #43
Flava_24/7's Avatar
Boosted Panda
With the 2.87 pulley your definately going to need some bigger injectors, and then something to control there flow rate.
What plugs are you running and at what gap?
Old Oct 18, 2006 | 10:06 AM
  #44
buttonhook's Avatar
I'm never going to run the 2.87" pulley I don't think I will need it.
I'm running 1 step colder with a 36 gap
Old Oct 20, 2006 | 01:36 PM
  #45
buttonhook's Avatar
proof is in the.......well picture!
ok everyone I now have real pictures of the thing posted!
Old Oct 20, 2006 | 02:21 PM
  #46
MDeezy's Avatar
where
I can host a pic for your sig if you want. send me a PM or e-mail mdeezy@gmail.com
I'll upload it to my photobucket, and wont touch it so the link will always be good.
Old Oct 20, 2006 | 03:00 PM
  #47
Flava_24/7's Avatar
Boosted Panda
Originally Posted by MDeezy
where
On the first page, he just posted up the URL.
But here it is......
buttonhook,
Are you going to do the CAI? You should consider it.
Old Oct 20, 2006 | 04:05 PM
  #48
buttonhook's Avatar
buttonhook,
I thought about it but space is tight as you can see. I'll have to see what it is like once the weather heats up again. I may just custom fab a heat shield and seal the filter off from the engine bay. then it can pull cool air from the fender well
Old Oct 20, 2006 | 04:15 PM
  #49
buttonhook's Avatar
that looks fine! but I still need to repaint the new front calipers
Old Oct 20, 2006 | 04:17 PM
  #50
MDeezy's Avatar
http://img.photobucket.com/albums/v7...l/IMAG0066.jpg
http://img.photobucket.com/albums/v7...l/IMAG0065.jpg
those are the pics you sent me full size uploaded should you need to pass that around.
might want these for your sig.
let me know if you want text on it with your mods or something. I'll add it in.
Old Oct 20, 2006 | 04:23 PM
  #51
buttonhook's Avatar
the first one looks the best I would like to get the mountains in behind me though. across the top of that mountain is the "Dragon" or "deals gap" 317 curves in 11 miles!!
Old Oct 20, 2006 | 04:32 PM
  #52
MDeezy's Avatar
with a semi suble depth of field
Old Oct 20, 2006 | 04:36 PM
  #53
buttonhook's Avatar
looks good!! hey I used to live right out side of atlanta. kennesaw/actworth I worked for the DOT
Old Oct 20, 2006 | 04:41 PM
  #54
MDeezy's Avatar
. . . I worked for the DOT
Old Oct 20, 2006 | 04:48 PM
  #55
buttonhook's Avatar
and those crusers are not that fast..........but the radio is!
no really it sucked big time!! If you ever wanted to know what it is like to be hated just work there!!
I'm now a teacher and much happier if that tells you something.
Old Oct 20, 2006 | 11:43 PM
  #56
Flava_24/7's Avatar
Boosted Panda
Space is tight with any SC on the VQ, but trust me the CAI is worth it. I ran the pancake filter for a while, but once I cut the hole and did the CAI the SC really woke up. It needs some fresh air to really make good boost. I gained about .5-1.0 of boost from doing it. I was really suprised that it made that much of a difference, but it did.
Old Oct 22, 2006 | 07:59 AM
  #57
buttonhook's Avatar
you just run it down in to the pass. fender well?
Old Oct 22, 2006 | 08:29 AM
  #58
eclypsecl's Avatar
what's the gas mileage like on a supercharged maxima?
Old Oct 22, 2006 | 02:51 PM
  #59
Flava_24/7's Avatar
Boosted Panda
Yup. You have to cut a hole so that the piping can go from the blowers inlet to the inner fender.
Old Oct 23, 2006 | 05:55 AM
  #60
buttonhook's Avatar
I havn't ran a tank through it yet but it don't seem too different yet. But I have been on it alot this tank.
Old Oct 23, 2006 | 05:56 AM
  #61
buttonhook's Avatar
Mine had a hole there when I moved the overflow tank.
Old Oct 23, 2006 | 06:47 AM
  #62
4DRSpeed's Avatar
Project Ruby......
congrats on the S/C.
BTW did Joey fall off the face of the earth? Haven't seen him around.
Old Oct 23, 2006 | 07:34 AM
  #63
Flava_24/7's Avatar
Boosted Panda
Yeah but that hole is pretty small.
Old Oct 23, 2006 | 07:37 AM
  #64
From the looks of it, your filter at the blower appears to be too small and you're not giving the blower all the air it can handle. I would see how many cfm that filter is rated at and see if it is up to snuff with the demand of the blower. Better yet, just hold off until you do the CAI. Definately a worthwhile mod.
Old Oct 23, 2006 | 10:49 AM
  #65
buttonhook's Avatar
no he is around.
  #66
buttonhook's Avatar
almost 3" across
Old Oct 23, 2006 | 10:51 AM
  #67
buttonhook's Avatar
according to the K+n paper work that filter will flow 820 cfm I'm not sure what the blower needs but it seems like that shoud be enough
Old Oct 23, 2006 | 10:54 AM
  #68
820!!! Wowsers.. That's more than enough. Cool.
See ya in the BAN Log Mr. Gay!!!
Old Oct 23, 2006 | 11:06 AM
  #69
buttonhook's Avatar
weird thing is I ordered it directly from K+N and they were out of stock I waited 3 weeks and then it just showed up on day. and the good thing is I didn't have to relocate the fuse box.
Btw whom ever removed mr. gay Thank you!!!
Old Oct 23, 2006 | 11:50 AM
  #70
Minimalmaxima's Avatar
Man I am jealous.
Old Oct 23, 2006 | 12:38 PM
  #71
Flava_24/7's Avatar
Boosted Panda
almost 3" across
Mine was much smaller then that, I actually had to cut it to be 3"
Old Oct 23, 2006 | 01:04 PM
  #72
buttonhook's Avatar
My 3" intake pipe almost will fit in there a 2.5" would for sure
Old Oct 23, 2006 | 01:05 PM
  #73
buttonhook's Avatar
Originally Posted by Minimalmaxima
Man I am jealous.
why?
those are nice rides too.
I just did a little at a time!
Old Oct 23, 2006 | 06:15 PM
  #74
maxgtr2000's Avatar
KH3 by popular demand
That's his name! I rode in his car, it was pretty quick. If I knew turbo was going to be the hassle it is to me to get it going/installed I may have went S/c.
Old Oct 23, 2006 | 06:27 PM
  #75
4DRSpeed's Avatar
Project Ruby......
ya the car was definetly quick. Kept up with a Trans Am M6 with bolt ons.
Old Oct 24, 2006 | 04:48 AM
  #76
buttonhook's Avatar
now it's all mine at least the supercharger is
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
MichMaxFan
Sep 30, 2015 09:18 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
