whining noise from engine bay
Old Jan 22, 2007 | 12:03 AM
Mr.Duck's Avatar
so i am getting a whining noise coming from my engine bay, passenger side by the belts, first i thought it may be the alternator so i replaced that, but no luck, same noise is still there. i read a few things on here, and someone said to turn the AC on and see if it goes away, so i tried that and it kind of went away... but not all the way, anyone have any ideas?
Old Jan 22, 2007 | 12:19 AM
MorpheusZero's Avatar
Take off the supercharger.
Old Jan 22, 2007 | 08:59 AM
shiftnatredline's Avatar
Godzilla
Take a bottle of water with a sprayer, like a windex bottle or something, and start spraying hoses and stuff on that side. There is probably a vacuum leak or something. If you hear the noise go away for a second find where the hole is and wrap some tape around it if you can. Otherwise buy a new hose.
Old Jan 22, 2007 | 09:00 AM
Fr33way™'s Avatar
Wild for Width
AC compressor, idler pully, belts themselves.
Old Jan 22, 2007 | 10:07 AM
sky jumper
I'm betting AC compressor...
http://forums.maxima.org/showthread.php?t=506182
there's some links to video files in there that show you what a noisy AC compressor sounds like with ac on/off. if your noise doesn't subside completely when you turn the AC on then your bearing could be worse than mine, or maybe your clutch is slipping.
but I'm betting you have compressor noise. bypass the compressor with a 37" belt as described in the link and see if the noise goes away completely.
Old Jan 24, 2007 | 05:55 PM
frumundacheese's Avatar
the a/c compressor bearing could be bad causing it to squeel. like he said above.
Old Jan 24, 2007 | 10:07 PM
elemax's Avatar
also, you could take a piece of vacuum hose, like 1/8" or similar, while the engine is running hold one end in your ear and carefully touch the other end to suspected areas- like ac compressor, idler, ps pump, alt. listen for matching bearing noise.
Old Jan 25, 2007 | 07:06 AM
willard00's Avatar
this only works if you add a bit of soap. that way it will bubble where the hole is.
Old Jan 25, 2007 | 10:28 AM
Godzilla
the water will make the sound go away for a second though. at the shop we use brake clean..
Old Jan 25, 2007 | 07:53 PM
mtwoody13's Avatar
was the alternator you got a rebuilt or remanufactured one?
The Nissan dealership told me that the whining wouldnt go away until you replaced it with a new one.
Old Jan 25, 2007 | 09:24 PM
PHAT6's Avatar
I've got an air conditioning idler that's either loose or not bolted in correctly and it whines quiet a bit on start-up and when sitting at the lights apparently, though I can't hear it from the inside.
Either that or the AC pulley. I don't think the compressor would make a whine...
Old Jan 26, 2007 | 09:46 PM
konak85's Avatar
had the same thing. turned out to be the A/C compressor.
seesole
Sep 14, 2015 12:38 PM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
bennuss
Sep 11, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
