SFCs on eBay...
Originally Posted by natty99
I think the point you're missing is that when you use a two-post lift, the chassis flex/stretch, whatever you want to call it, is that of an unnatural, unloaded state. Weld on SFCs when the car is suspended in this state, and you pretty much help to 'lock' the chassis in that flexed, unnatural postion. When you drop the car and put it under load, the car will not sit naturally as the SFCs are preventing the car's chassis from flexing back to that natural, loaded position.
to get good shots from the floor. Sorry for any confusion. Most muffler shops should have a four post lift available.
Originally Posted by hacim105
Well the best way is with the wheels loaded, but I think you can get away with a 4 post lift as shown in the pics on page 2. Just by no means use a 2 post lift.
Sorry for my stupid post. I was assuming 4 post meant the points that the car was lifted at, not the actual amount of posts in the ground that lifted the car.
Thank you for the correction. This definitely puts me in a predicament though because when I buy a set I don't have a clue where I'm going to get it installed. Every place I've checked so far only have 2 post lifts.
even with the SFCs on....
Alright guys I have an update for you. We here at Truax Motorsports have made a decision there isnt going to be a stage 1,2 or 3. They are simply going to be subframe connectors this will include our cross brace and x bracing. This way its easier for all parties considered. The clearance should not be an issue. NCSU_MAX your set has been upgraded at no charge to you. (thanks for sticking your neck out and being the first guy) The other set on ebay thats now for sale will also be upgraded for what it goes for. Think of this as an introductory price. Heres some pics.
The cross pieces are half inch tubular steel.
we will be listing more sets on ebay tomorrow night.
Thanks,
Truax Motorsports
Thanks,
Truax Motorsports
Originally Posted by XeroX
yes i understand the concept im just saying that i dont think the max on a 2 post lift will be put on "enough" of an unnatural unloaded state to prevent the chassis from flexing back...Even if it could, the chassis on the max is so flimsy i could probably even c it stretching back to normal
even with the SFCs on....it wasn't the concept that I was trying to explain to you. My point is, if in fact the chassis does "stretch", when it is on a two post lift, it won't stretch back fully to the natural, loaded state when dropped. How can it? I don't see your logic. If the chassis is so "flimsy", how could it stretch back to normal when the SFCs are resisting the very movement afforded by that "flimsiness"?
Originally Posted by Kevlo911
Anyways, someone should donate money to the kevlo mod fund so I can buy some things
is it wrong to believe that even if you WERE able to to get that much flexing in the frame before you welded these on a 2 post lift that the welds would break? Flame if you want, i learn alot on the org. teach me some more!
I dont know really, im sure your right. I have just noticed from just jacking up the max, that there is alot of movment in the frame, i hate to make it sound like ic the max "bending" when i jack it up, but i dont know how else to describe it...this is what i mean when i say "flimsy" with so much movement, i couldnt c how the frame could be held in a unloaded position with these SFCs enough to prevent you from closing the doors...
Is there a way that maybe you can switch the direction of the bolts for this center peice? I realize ground clearance shouldnt be sacraficed that much with these, however, i could c those bolts being hit on the ground....this could be a PITA getting the nuts off if that were to happen if and when you want to take the SFCs off...Wouldnt hurt if you could just flip them over....Just an idea....
heres a new link.
http://cgi.ebay.com/ebaymotors/Nissa...spagenameZWDVW
Thanks for all your interest.
They face down for exhaust clearance. So how about this idea instead We just use a slightly shorter bolt.
heres a new link.
heres a new link.
just an idea 2 thro out there...Seriously tho! would you be willing to set up a GD?
Funky_monkey58
I'm a sponsor, and I've done plenty of group deals on here... Let me know if you want to try to work something out with me.
Thanks,
Mike
Blackmaxx96@yahoo.com
Thanks,
Mike
Originally Posted by NCSU_MAX
SFCs are in and appear to be very high quality pieces. I plan to have them welded on this thursday or so and will report back with reviews/pictures/etc. asap.
sounds good. and just to clarify, this was just stage 1, right?
actually its all 3 stages I guess. From what I understand theyve decided to sell everything as a package so not only am i getting the bars that run parallel with the car but also the X bracing (see page 3 pics).
This is excellent. Does anyone know how the 1x2 rectangular 11 gauge steel they're using compares to circular DOM tubing in strength? The rectangular looks nicer and is easier to weld tabs to but I suspect it's not as strong.
The cross bracing looks a little thin for my tastes but its better than nothing. The main "stage 1" part is more important anyway.
Funky_monkey, how much would you guys charge to install a set for me if I drove up to your shop? One last question for you, do you have any close-ups of the rear-most part? Is it actually welded to the rear subframe?
VQuick As of right now I dont really want to get into the habbit of installing these here at our shop. I do have a guy i could line you up with in this area thoug.
And on the 4th gen i didnt attach the rear most tab to the rail.
Hmmm, so has anyone gotten these shipped in an installed ? I am extremely curious about how much it has helped with frame flex and how noticeable it is? After spending $200-500 on parts that help the frame vs spending none of that and just over a grand for really good suspension setup, its all ideas to play with, please dont flame, im still a learning noob also =)
mOOnjal heres a link to a review
http://forums.maxima.org/showthread.php?t=517733
VeeQueue
Nov 11, 2002 03:11 AM
VeeQueue
Oct 30, 2002 07:53 PM
Dan 93 SE
Mar 1, 2002 01:15 PM
Kvou812
Feb 17, 2002 09:52 PM
