NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
Old Sep 17, 2009 | 05:53 PM
  #4721
missexclusive99's Avatar
Bar/Piece behind bumper/under headlights.
I just got a '97 Maxima and while I was replacing the bumper I noticed this. I knew the car had gotten into an accident but I just don't know how to fix this. There was a big dent in the bumper and fender. When I took off the old bumper, I noticed there is a bar or piece that connects from under one headlight to another and it is bent which causes the driver side headlight to be higher than the other. Here's some pics.
http://i25.tinypic.com/nd6aec.jpg
http://i26.tinypic.com/10ye1du.jpg
http://i25.tinypic.com/261bwwy.jpg
So what do you guys think and what is that part called? Can it be banged out back into place or should I just buy a new one (if so, how much would it cost?) Thanks
Old Sep 18, 2009 | 06:03 PM
  #4722
metalgod3082's Avatar
Originally Posted by metalgod3082
Basically when I first start my car the a/c blows nice and cold but when I start driving it starts to get warmer and kinda gets that smell of the defroster going on. But then when I stop at a stop light the defroster smell goes away and it gets nice and cold again. I was reading around and thinking maybe its a vacuum leak thats causing the defroster to kick on while accelerating. I had someone check the refrigerant charge and they said it was fine. Any ideas what could be wrong or things I could check for?
Anyone have any ideas?
Old Sep 19, 2009 | 10:20 AM
  #4723
pewterss's Avatar
Could be the ignition switch. Next time you turn the key and nothing happens, jiggle it and see if the Max starts then.
Well what do you know that actually worked. When I jiggled the key after turning and nothing happened, the car started right up. That was perfect, thank you. I guess I know now that I may be needing a new ignition switch... wonderful. Thanks Wizard.
PewterSS
Old Sep 19, 2009 | 05:58 PM
  #4724
haydeno's Avatar
When recharging AC, how much PSI should it be when its full?
Old Sep 19, 2009 | 06:04 PM
  #4725
pmohr's Avatar
No more Maximas...
If you're doing it properly, you'll have put in 1.43 lbs of refrigerant.
Old Sep 19, 2009 | 10:15 PM
  #4726
dominicanboi025's Avatar
i am connecting an aftermarket radio, im almost done but when i connect the dashboard lights to the power its powered on but when i turn on the headlights it shuts off, the fog lights when i connected them to the power supply the dashlights dont work aat all do you know what this could be?
Old Sep 19, 2009 | 11:21 PM
  #4727
haydeno's Avatar
Well its not empty, just topping off to get cold again. How many psi is that on low end?
Also, Can you identify what #1 is and where I could find it? Cant find anywhere and mine are warped and torn.
Old Sep 20, 2009 | 05:44 AM
  #4728
Spectacula's Avatar
i have a 98 maxima. When my car sits for a few hours is starts right up but when i turn if off and try to turn it back on it doesnt start. it doesnt turn over. i recently replaced the battery and starter. i tested the alternator and its good. what can it be?
Old Sep 20, 2009 | 08:34 AM
  #4729
ugafanz's Avatar
buying a max ??
Ok , so me and my wife are obviously new to the site and had a couple questions for some maxima ownwers. We are looking to buy a maxima and there are two different ones we are looking at. One is a 96 5-spd ( but it has cooling problems). The other is a 92 that looks fairly good being a 92. the 96 is only a thousand dollars and the 92 is like 1500. To make a long story short are the performance part for the 92 going to be harder to find since its older ? I really just want some honest solutions. Like for example if the 92 has some kind of underlieing problems v/s the 96. which is more likely to be quicker and cheaper to fix up , etc...
Thanks in advance.
Old Sep 20, 2009 | 08:41 AM
  #4730
pmohr's Avatar
No more Maximas...
Thanks in advance.
...do you not think it would be more logical to ask about a 3rd gen in the 3rd gen subforum?
Old Sep 20, 2009 | 08:45 AM
  #4731
pmohr's Avatar
No more Maximas...
Do you know exactly how much is in there now? If so, then do some simple math and add that much refrigerant.
I won't help with adding refrigerant from a can and judging by pressure, as that is in no way an accurate method. Do it the proper way or don't do it at all, really.
Did you not try a dealer, or a Nissan parts site?
54329-39U00, $9.27 each at Courtesy
Old Sep 20, 2009 | 09:16 AM
  #4732
ugafanz's Avatar
Sorry man ! I wasnt tring to ask only about the 92 . I was wondering about the 96 also. Ill take the other questions to the 3rd gen forums sorry. I was wanting to know about both but somehow how more questions about the 92 came out , lol. My fault..
Old Sep 21, 2009 | 07:37 AM
  #4733
streetbeats713's Avatar
will this work on my car?
I have a 96 nissan maxima s.e will an condenser/radiator fan assembly work from a 97 maxima? thanks
Old Sep 21, 2009 | 08:22 AM
  #4734
yoshiyosh's Avatar
Originally Posted by yoshiyosh
i did the manual TCM diagnostics and no long judgement flickers were there. soo according to the page with the TCM JF codes it said 0505. which basically is telling me nothing with the transmission is wrong, but here i am with ECU code saying i have a trans range sensor malfunction. the only long JF was the first one but the page explained that's supposed to happen.
There is no such thing as '0505' for the TCM check, either you use a GST and don't pull any codes, or you do the manual TCM diagnostics and don't get any long judgment flickers.
hoping someone can still help me with my problem?
Old Sep 21, 2009 | 08:51 AM
  #4735
watson's Avatar
For this picture, the first bolt at the top that secures the strut. Does it have to be tight? Everytime I try and tighten it the strut just spins feely. Is that normal? When I drive it sounds like something is loose could that be it?
[/quote]
Old Sep 21, 2009 | 12:16 PM
  #4736
More than likely those parts will work just fine.
Old Sep 21, 2009 | 12:21 PM
  #4737
Originally Posted by watson
For this picture, the first bolt at the top that secures the strut. Does it have to be tight? Every time I try and tighten it the strut just spins freely. Is that normal? When I drive it sounds like something is loose could that be it?
That is definitely not normal. This is more than likely the source of the problem.
Old Sep 21, 2009 | 12:35 PM
  #4738
watson's Avatar
How would I go at fixing that? The Tokico Illuminas state that any tool used on the shock will void the warrenty and I cannot tighten the Strut nut at the top without using a tool to hold the strut.
Old Sep 21, 2009 | 12:38 PM
  #4739
You need a tool to hold the strut.
Old Sep 21, 2009 | 02:15 PM
  #4740
Spectacula's Avatar
anybody know?
Old Sep 21, 2009 | 02:29 PM
  #4741
pmohr's Avatar
No more Maximas...
anybody know?
It could be many things. When you say 'turn over' are you (incorrectly) referring to cranking?
Old Sep 21, 2009 | 06:46 PM
  #4742
#11 AND #12
Where can I get #11 and #12 on this picture and for cheap?
and also, when I turn my car on I think some sort of belt squeaks really loud until I press the gas a few times while in park and it goes away. What is that and what do I have to do/how much do I have to pay to fix that?
TY
Old Sep 21, 2009 | 06:51 PM
  #4743
B_Eaze's Avatar
If its still under warranty see if they'll replace it, if not wrap the hell outta the piston with somethin and go for it
Old Sep 21, 2009 | 07:10 PM
  #4744
B_Eaze's Avatar
TY
For the part (11) go to Courtesyparts.com, everythingnissan.com or a junkyard
belt issue, get some anti squeal grease from an auto parts store....http://www.youtube.com/watch?v=bJzpT...2C64F&index=15
Old Sep 21, 2009 | 07:57 PM
  #4745
Spectacula's Avatar
yesss
Old Sep 21, 2009 | 09:54 PM
  #4746
TY
Junkyard, someone parting out a car here, Dave Burnette from Southpoint Nissan if you want it new.
Old Sep 21, 2009 | 09:59 PM
  #4747
watson's Avatar
Do you know what the tool is called?
Old Sep 22, 2009 | 01:23 PM
  #4748
Fenton3030's Avatar
Power steering Noise
When I start up my car i get this Loud winding noise-from the passenger side wheel area. Ive been told its my power steering belt, and that its loose. How do i go about tightening it.
Auto 1996
Old Sep 22, 2009 | 03:24 PM
  #4749
B_Eaze's Avatar
Auto 1996
Old Sep 22, 2009 | 03:38 PM
  #4750
Nismo32's Avatar
yay no more codes only the 1101 for the transmission but that can wait. so now my next issue, when i move the steering wheel (L( <- and -> )R) there is a clicking noise first i thought it was a rock or a nail stuck onto the wheel but i wasnt, when i start driving the car and making a left or right turn it clicks ill post some videos of it uploading to youtube. what can it be......
Old Sep 22, 2009 | 04:06 PM
  #4751
B_Eaze's Avatar
Probably one of your axles if its only when your turning. try to see which side its coming from and replace it
Old Sep 22, 2009 | 04:09 PM
  #4752
Nismo32's Avatar
okay so here it is this is the only good sound clip i got the other ones you can barely hear it http://www.youtube.com/watch?v=mVHpdVx0DLg
also i had a leak in my front valve cover so i replaced the gaskets for it and the leak is still there
what is going on.
Old Sep 23, 2009 | 07:22 PM
  #4753
so..my mom bought me wax for my car. i figured great, make my car nice and shiny...little did i know it was for red cars. so now the rubber around the windows and all the scratches turned pink. the car is shiny, but my car has pink on it too. how do i get it off? =/
Old Sep 23, 2009 | 10:21 PM
  #4754
watson's Avatar
bump
Old Sep 23, 2009 | 11:38 PM
  #4755
Fenton3030's Avatar
Auto 1996
I know how to tighteb the ac/alternator belt but the power steering is on the other belt
Old Sep 25, 2009 | 01:11 AM
  #4756
northernlightscu's Avatar
Emissions issue
ok i dont know where to begin i bought a 95 maxima after only a thousand miles the engine bearing went. I have what my dad swore at the time was another 95 at the house with a blown tranny. over the last two weeks my friend who is a mechanic and I have gone about ripping out two motors and putting the motor from the maxima with the blwon tranny into the maxima i just bought. now come to find out that maxima we used as the replacement motor was a 94 therefore OBD1 well everything else including wiring harness and such are OBD2. now my question this. is the motor swap now even feasible and what will it take i need ths ca rback on the road asap to go to work and college without reling on other people for rides, i also live in conneticut and the emmisions law says any 95 and older gets the snake up the tailpipe, well anything 96 and above gets plugged in. i cant legally pass emissions if my "95" maxima is plugged in but it will pass for the snake. am i safe or is that law just a technicality and any garage will plug in an OBD2 car?
Old Sep 25, 2009 | 03:09 AM
  #4757
pmohr's Avatar
No more Maximas...
So you're trying to swap in an engine from a 3rd gen? ...why? That's rather pointless, when a VQ is so cheap.
If it's older than '96, everywhere will put it on the rollers. That's just how it is.
Old Sep 25, 2009 | 03:15 AM
  #4758
pmohr's Avatar
No more Maximas...
what is going on.
Did you use RTV on the valve cover gasket, or just throw it on without reading any instructions?
Have you taken a look at it yet?
Old Sep 25, 2009 | 07:29 AM
  #4759
professorQ's Avatar
so i found out that i my e-brake does not work. meaning that when i pull it, the back tires still spin as if it isn't engaged. guy at the inspection place told me this without even looking (which amazes me). so my question is where can i get a good brake kit (calipers, rotors, pads, fluid) for my 95 SE??
also my whole center console doesnt work (clock and bose). when I bought it (3 weeks ago) it didnt work and i assumed it was because the car is 14 years old. So how would i go about fixing the clock??? as for the stereo...would it be wise to buy an aftermarket or just get a different HU?
thanks for the help
Old Sep 25, 2009 | 08:54 AM
  #4760
see id love to go out and buy a new engine but iv allready spent a ton on parts and bought the car for $1800 i have very little money left and i need this car back up and running now because if i dont i cant get to my job or school. now is this even a feasible project to switch the 94 motor into the 95 or is this a waste of effort
