NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
Old Mar 1, 2009 | 07:59 AM
  #2801
Jeffp's Avatar
Heh Kun_man - Where would I find the breather tubes?
Originally Posted by Kuhn_man
what you could try to do is see if any of the breather tubes that would go into your gas take to provide air so that way there not to much of a problem with vaccume when your car is on...see if any of those are pluged and it also could be something in your fuel pump as well...maby a bearing goin bad or something
Old Mar 1, 2009 | 10:12 AM
  #2802
Rob_0126's Avatar
New Powersteering Noise
Just had a Cardone powersteering put on, along with a new pressure hose.
Theirs a low howl/groan coming from the new ps pump. I hear it moreso inside the car.
I asked the mechanic, he said it's a little bit of air, and it will go away eventually.
I was wondering how long, because Ive driven over 100 miles, and it's still there. Ive even popped the top of the reserve, and did a few full turn lock to lock to see if it would bleed, and it's still there.
Any ideas?
Old Mar 1, 2009 | 11:44 AM
  #2803
Kuhn_man's Avatar
Originally Posted by wcs1885
How do I do that? I'm not real car savvy. I only know how to change my oil & check some basic stuff under the hood. So what would I need to do to check on the speakers?
take off the door panels, there are clips on the bottem of the door that just pop off, all you really need is a philips screwdriver and something to pry with...then it just kinda wiggles off for the most part...its really strait forward...once the panel is off there should be 4 screws that hold the speaker on unscrew them and it should almost fall out from there you can check the wiring out at the speaker point if that doesnt seem to be the problem then it might be behind the dash...and if so let me know and i can tell you how to take that apart as well ok...good luck, hope it works out
Old Mar 1, 2009 | 11:53 AM
  #2804
Kuhn_man's Avatar
well from what ive seen on other cars because i havent look on my car yet, is that it should be somewhere on near the top of the gas tank all it really is is just a small tube that you see leading to nowhere thats connected near the top of the tank or where the hose goes to when you fill your tank up
Old Mar 2, 2009 | 11:22 AM
  #2805
jmr1138's Avatar
Sunroof glass molding
Hello.
I have a '97 GLE. The plastic molding that goes around the top of the glass sunroof has become brittle and cracked in a couple of places. My first indication was that it sounded like a window was cracked open slightly while driving. Apparently the molding also serves to hold the rubber seal in place. The sunroof operates just fine and the rubber seal does not appear to be damaged. It's just that plastic molding that is the problem.
From what I can tell the molding is not sold separately from the glass....but I don't want to spend $600+ labor just to fix that molding.
Has anyone else encountered this problem and/or have a suggestion?
TIA!
Old Mar 2, 2009 | 12:27 PM
  #2806
memphisballer's Avatar
Originally Posted by jmr1138
Hello.
TIA!
My wife drives a '95.A problem with hers was that the sunroof cables broke and left a gap to where air was getting in.The cheapest fix is to find a used one in a junkyard and replace it all in one piece.It seems like a pain but once you remove the Dome lights,A,B&C pillars,Sun visors then the headliner just falls down and the roof itself is held up by screws and its got a few drainage hoses attached.two person job as well.
Old Mar 2, 2009 | 07:37 PM
  #2807
Leo_Koneval's Avatar
Hi I know this is probably a silly question but, I want to make my car sound louder, not extremely loud, I just want that noticeable rumble that doesn't wake every neighbor in the morning.
I know that straight pipes makes the car louder, but I wanted to know if just a muffler alone can do the same job. Like everything is stock except for the muffler and maybe the exhaust tip but I know that the tip doesn't affect sound that such.
Old Mar 2, 2009 | 07:53 PM
  #2808
pmohr's Avatar
No more Maximas...
Yes, you can make it louder by changing the muffler.
Have you looked through the exhaust sound clips sticky or youtube?
Old Mar 3, 2009 | 02:26 PM
  #2809
Rob_0126's Avatar
Originally Posted by ChiknNutz
Hi all just found this site and this is my first post. I just picked up a 1995 Maxima with 220k on the clock, so have some stuff to do. This will strictly be a daily driver, but I do tend to go OTT on stuff, so what the heck. One thing I need to do is replace the struts...looking at either the KYB GR-2 or Tokico HP. I've found them online at various places for about $300 for the set. Are there any of these "group buys" going on for either of these? These seem to be the most popular low-end options from what I can tell (and I don't want OEM, but a bit better). Thanks much.
Just had monroe sensatrac struts and moog strut bearings put on my 95 max, 112k miles. I dont know much about the comparisons, seems they are ok, and high ($99 a pop)
Old Mar 3, 2009 | 02:47 PM
  #2810
OzarkSE's Avatar
Hey guys -
I got the car towed to a shop, but they've been having trouble finding the problem as well. They now have spark, but they said the car is dumping fuel into the cylinders like it's WOT. He suspects there might be a shorted injector, but has to pull some data off the engine to check the parameters. When he pulled the plugs he said they were just soaked with fuel. He was at a loss to why it's not running now, but at least he told me that he's going to cut me a break on the rates since he's having such a hard time with it - which I was relieved to hear. I thought I would ping back here to see if anyone might have some idea why it's not firing at the right time (the CPS code is now cleared) or dumping too much fuel.
Originally Posted by OzarkSE
I had the guy run my obdII reader on it and it pulled a code p0335, iirc, cps problem - so you're right... but it looks like there's no charge getting to the terminal (per factory manual test) when ignition is 'on'. I suspect he whacked the harness when taking the crankshaft bolt off when changing the harmonic balancer... but it looks like a real *$)(% to fix it.
Old Mar 3, 2009 | 05:45 PM
  #2811
ironwork's Avatar
intake question
first and foremost i have heard nothing but good things about this forum and its members and i cant wait to get involved with this community. with that being said i recently bought a 1995 maxima from a family member put only 10,000 miles a year. long story short took great care of it. i am 29 and just getting into the tuner scene so i am limited on my knowledge so please dont flame me for my stupid questions. i am a bodybuilder and we go to town on noobs and trolls, on my forum lol. like this long post lol. i just put a cone air filter on my car with a maf adapter. the stock airbox has a tempeture sensor on it. there was a rubber plug on the airfilter tube and i set the sensor in that. its not snug but not loose. do i even need this sensor or can i can it all together
  #2812
Jaeinda97's Avatar
Hey im not really to sure if anybody did this in there max but i literally wanna change every light bulb in my max to a nice royal blue color.. Only problem is that i dnt and cant find the bulb size for anything such as: door, map, speed odmeter, window switches, bumper lights, license plate, and anything else that i cant remember the headlights and fog i already kno i need HID's.. Just everything in between i need the help with. Thanks alot
Old Mar 3, 2009 | 05:57 PM
  #2813
90s*kid's Avatar
P0136
Hi,
I've searched the forums and found some useful on code P0136 for my Maxima 97' GLE. I just wanted to know if anyone has a rundown on changing it? tips? exact location? tools? exact oxygen sensor need? I've been told it's not hard to do at all unless the part is rusted on...let me know.
Old Mar 3, 2009 | 06:14 PM
  #2814
ironwork's Avatar
bump
Old Mar 3, 2009 | 06:26 PM
  #2815
valveguy's Avatar
Front Abs Sensors
I just bought a 98 SE auto for my son. It has an intermittent abs light. We changed both axles over the weekend (2 torn outer boots). While we were in there, I noticed someone had spliced in a new sensor. It may not be the problem, but I will be changing it anyway. However--when I compared it to the other side (drivers side), I noticed it is different. On the drivers side there is a bolt holding the sensor to the "knuckle", or hub. The FSM clearly shows a bolt holding the sensor in place. On the passenger side there is no bolt, nor a threaded hole where a bolt would attach. There is a "nub" for the hole on the sensor bracket to rest, however. My question(s) is--is it likely the knuckle has been replaced, and someone machined a hole in the knuckle for the sensor? (I could/should check my other son's non-abs '96) Should I worry about it?---and just put the new sensor in (with a little RTV) and forget about it? Or should I drill and tap a hole, and add a bolt like the drivers side?? Thanks.
Old Mar 3, 2009 | 06:41 PM
  #2816
90s*kid's Avatar
Map lamp size
---------------- Listening to: VA - Beginning Of The End-When She Made Me Promise via FoxyTunes
I'm not for sure what the size is?
Old Mar 3, 2009 | 06:43 PM
  #2817
pmohr's Avatar
No more Maximas...
bump
Did you seriously just bump after a half hour? This is a forum, not a chat room. Have some damn patience. Seriously, there have only been 2 other posts since your question.
In any case if you don't use the IAT, you'll get a code. Whether or not you care about that, that's up to you. Either leave it dangling, find a way to fit it in the proper place, or get rid of it, it's all up to you.
Old Mar 3, 2009 | 06:52 PM
  #2818
pmohr's Avatar
No more Maximas...
Get rid of the 'listening to' crap. No one cares.
http://forums.maxima.org/4th-generat...ight-bulb.html
http://forums.maxima.org/4th-generat...98-maxima.html
Old Mar 3, 2009 | 06:55 PM
  #2819
pmohr's Avatar
No more Maximas...
Hi,
Search around, you'll find a few good threads on O2 sensor replacement.
In any case, it's just the rear one by the converter. O2 sensor socket or a wrench, all you need.
Old Mar 3, 2009 | 07:00 PM
  #2820
pmohr's Avatar
No more Maximas...
Have you searched the forum or looked through the stickies? Last I looked, there was a list of all the bulb sizes around here...
Old Mar 3, 2009 | 07:06 PM
  #2821
petro2342's Avatar
Anyone looking for what size bulbs you need for your car take a look here:
http://www.sylvania.com/ConsumerProd...de/default.htm
Hope that helps some of you.
Example of a 1997 max:
http://www.sylvania.com/ConsumerProd...RG-Results.htm
Old Mar 3, 2009 | 07:10 PM
  #2822
ironwork's Avatar
lol ahhhhh o.k as i said i have it sitting in the rubber insert on the new air filter tube from my understanding that is the correct place. what i wanted to know is if its nessesary to have it on at all . as far as engine performance will my car idle diffrent etc etc. my CE light is on now amyway ill reset when i need a inspection that im not worried about i have friends. why wouldnt you included the CORRECT PLACE in your post your more worried about my bump. my apologies i am on a **** load off bodybuilding forums sorry if thats a no no around here guy. thanks for you help.
Old Mar 3, 2009 | 07:12 PM
  #2823
petro2342's Avatar
Resetting it when you do inspection wouldn't help you pass. Fix your problem then go to inspection.
Old Mar 3, 2009 | 07:21 PM
  #2824
ironwork's Avatar
thanks for the reply bro. do i really have a problem though from my understanding its personal prefrence if it dosent effect the car. and i set it in the new air filter. im just wondering if it has to be inside the tube or is it fine where it is. i just got a oill change and plugs car runns stong it will pass inspection no problem. my mechanic just checked it out. car is fine
Old Mar 3, 2009 | 07:26 PM
  #2825
pmohr's Avatar
No more Maximas...
Well the correct place is obviously in the intake plumbing.
According to the FSM, the IAT isn't used for any sort of engine control, but some members have noticed that it may have an effect on how the engine runs.
Have you checked the codes? As has been said, resetting the codes won't help at all if your testing station uses OBD-II checking.
Again, you could let it dangle next to the filter, or find a way to put it in where it should be.
Long story short, if you got an intake, you got the wrong one. The rubber insert is for the 97-99 style IAT, not the 95-96.
Old Mar 3, 2009 | 07:28 PM
  #2826
petro2342's Avatar
Yea I too had a cone air filter installed and left the IAT dangling, but never pulled a code. So make sure you pull the code and let us know what it means.
You can find this by going down under the dash where your pedals are. On the right side you have to remove the kick panel or w/e its called and find your ecu (electronic control unit) there. There will be a dial which a flat screw driver will help you pull the code. Turn it all the way to the right gently and wait 1 or so second. Then turn it left. Your CEL (if its on) will flash xx long xx short fast flashes. Thats how you pull the code.
If you are confused take a look at this link:
http://vbxmaxima.8m.com/ecu.html
Old Mar 3, 2009 | 07:33 PM
  #2827
pmohr's Avatar
No more Maximas...
If at all possible, a bolt securing the ABS sensor is the best way to go. Otherwise, it'll bounce around and set off the ABS light, as you've seen.
Courtesy shows the knuckle to be the same for both ABS and non ABS vehicles, so it could be an aftermarket part for non-ABS vehicles.
Old Mar 3, 2009 | 07:39 PM
  #2828
ironwork's Avatar
yeah i know how to pull the codes i appreciate your help. i have it sitting on the intake tube now idles fine i was just wondering if it was a big deal . thanks for your time.
Old Mar 3, 2009 | 07:44 PM
  #2829
ironwork's Avatar
cant see how that is possible getting a wrong intake it was special orderd from my cousin who works at his step dads auto part store. but ill take that into consideration. like i said theres a rubber plug where i assumed it went thats where i put it. so im fine. im not really worried about the CE codes as long as it runs good and it is. then i am o.k it has to be better then leaveing it dangling. thanks for you time as been said i have connections inpections will never be a problem. especially since its a 95. just curios how can you pinpoint i have orderd the wrong intake if i didnt tell you what brand or style i got. theres a million out there. i also reasearched this topic and some people choose to leave it dangling with no problems i thought that this was a maxima forum that i might get better insight ie results. maybe someone who actually did this before . and went through the same issues by the way its a sai so now you dont have to guess.
Old Mar 3, 2009 | 07:52 PM
  #2830
timbrooks77's Avatar
How are the turbo guys running there downpipe and where should I tap in to get oil feed for a turbo? pics would be great.I have been reading and reading on here ...TONS of info I have learned alot. Thanks
Old Mar 3, 2009 | 07:53 PM
  #2831
pmohr's Avatar
No more Maximas...
Just because it was special ordered doesn't mean it can't be the wrong one.
If it's got a round rubber bung for the IAT, then it's the wrong one. It should have a 2 bolt hole bung as the stock IAT is.
Old Mar 3, 2009 | 07:57 PM
  #2832
petro2342's Avatar
I don't know how it is in NY, but down here if a inspector see's a CEL / SES you fail right away. I dunno if I misread anything or not, but what was the code you pulled?
Old Mar 3, 2009 | 07:59 PM
  #2833
pmohr's Avatar
No more Maximas...
cant see how that is possible getting a wrong intake it was special orderd from my cousin who works at his step dads auto part store. but ill take that into consideration. like i said theres a rubber plug where i assumed it went thats where i put it. so im fine. im not really worried about the CE codes as long as it runs good and it is. then i am o.k it has to be better then leaveing it dangling. thanks for you time as been said i have connections inpections will never be a problem. especially since its a 95. just curios how can you pinpoint i have orderd the wrong intake if i didnt tell you what brand or style i got. theres a million out there. i also reasearched this topic and some people choose to leave it dangling with no problems i thought that this was a maxima forum that i might get better inight ie results.
Again, round rubber plug == 97-99 style IAT, two bolt hole bung == 95/96 style IAT.
Old Mar 3, 2009 | 08:01 PM
  #2834
pmohr's Avatar
No more Maximas...
You can T off of the OPSU, that's what most do.
Have you looked through the setups in the FI section? There are a lot of pics of up/down pipes in there.
The downpipe really depends if you do a forward or reverse Y.
Old Mar 3, 2009 | 08:05 PM
  #2835
pmohr's Avatar
No more Maximas...
SAI? Do you mean SRI? That says nothing about brand or model, but it doesn't matter.
Many people just have the IAT dangling (or have had the same problem with having the wrong intake), have you searched around to find out anything about this? As I've said, it may or may not have a noticeable effect. For you apparently it doesn't.
And post replies, don't just keep editing your post, makes it much harder to track and reply.
Old Mar 3, 2009 | 08:06 PM
  #2836
ironwork's Avatar
i didnt pull anything yet bud ill do it tommorow. i have connections with inpections theres way around CEL. it can be done . to my knowledge 1995 and older have more leineant inspections my mechaninc who looked at it a couple days ago said it will pass without a doubt
Old Mar 3, 2009 | 08:09 PM
  #2837
petro2342's Avatar
i didnt pull anything yet bud ill do it tommorow. i have connections with inpections theres way around cel. it can be done . to my knowledge 1995 and older have more leineant inspections my mechaninc who looked at it a couple days ago said it will pass without a doubt
Again, why not just solve your CEL issue instead of bypassing. It could be more serious than you think. See, when I pull codes and I get something like 0102 I would erase it cause I worked on the car and it never came up before. But if its the first time fix it!! Car will thank you.
Old Mar 3, 2009 | 08:11 PM
  #2838
ironwork's Avatar
i meant sri i actually had it written out first then changed it lol. anyway it idles fine it ran fine i guess im o.k if need be ill take the whole rubber peice out and fit the sensor inside if it becomes a problem. again thanks for your time.
Old Mar 4, 2009 | 12:37 PM
  #2839
Jaeinda97's Avatar
Thanks alot for the site this really helped me out for the bulb sizes.. Petro2342 and to pmohr im going to search more in the forum about this idea and thanks for ur reply to me also..
Old Mar 4, 2009 | 01:21 PM
  #2840
Kuhn_man's Avatar
your car will run fine without it
