A/C problem. Compressor won't turn on
#41
I had a similar issue, but it was with ground on the A/C fuse under the hood. Something went out... and the only way I could get the A/C to work, was to ghetto rig it (I had a wire touching one point to the other) You'll hear a click, when the compressor comes on. You can tell when its working cause you'd normally be getting warm air... once you "hard wire" it. It should start blowing cold air. its not the smartest way to fix it.(cause your can short soo many other things).. but it works for a while.. ( I had run a switch to it, cause if you dont remove it... you'll leave the compressor on, even with the car off), soo... ????? just my 2 cents..
Raul
Raul
