Fog light projector retrofit?
Old May 4, 2007 | 09:34 AM
m00njal's Avatar
Sorry guys, I'm new to the whole headlight scene, but has anyone attempted to retro projector fogs into our stock housings/? If not, or if so, where can I go to find more information on this? I'm looking to retro my headlights and was figuring to do both lights at once if I could. Thanks !
Old May 4, 2007 | 09:35 AM
Kevlo911's Avatar
Kevlo for President
It's very hard. One or two members have done it. I have done one side but not the other.
Tatanko has done it
Old May 4, 2007 | 09:37 AM
m00njal's Avatar
Bump
Check out these universal projectors? Comes with all wiring too, I have a friend's max which didn't come with fog lights, what about looking into these? beats paying $150 for a set of OEM fogs?
http://cgi.ebay.com/ebaymotors/ACURA...spagenameZWDVW
Hard you say huh? hmmm
Old May 4, 2007 | 09:44 AM
WhiteA32's Avatar
I sure wouldn't want a rock hitting those and shattering them....
Old May 4, 2007 | 10:01 AM
m00njal's Avatar
ah dang, you're right
what would I do without this forum? =P
But retro'ing into our housings, I just think our housings look ugly, AND one of mine are cracked anyways =P
HMMMM
Old May 4, 2007 | 11:43 AM
Sthmem's Avatar
Originally Posted by m00njal
Bump
I like those. I wouldn't want a rock to hit those and break them, but what if you put a piece of plexiglass in front of them to protect them?
I was thinking of getting OEM fogs but I really like those. Maybe put a 3K HID kit in them
Old May 4, 2007 | 04:57 PM
Tatanko's Avatar
Bacon Lover
Originally Posted by Kevlo911
Tatanko has done it
Check the sig.
Old May 4, 2007 | 09:38 PM
Cdg2125's Avatar
You retrofit them into the fog. Don't just use them as a fog light, custom fit them in. I actually like those for a custom fog job. Not sure if they will fit the fog tho. Pat, what projectors did you actually use for your fogs?
Old May 5, 2007 | 02:20 AM
m00njal's Avatar
ya, they look really good, I was thinking the plexiglass idea too! Just no one knows the quality of these yet =P
Old May 5, 2007 | 06:01 AM
mikey chalupa's Avatar
I think the plexiglass shield would definitely work. It would keep the fogs from cracking. You could even smoke the plexiglass to give it a nice look. I'm gonna order them and see what they look like and how big they are. I don't think these could be retroed into stock fogs.
Old May 5, 2007 | 06:39 AM
Tatanko's Avatar
Bacon Lover
They are Hella H3 units, off of an Audi I believe. If I had to go back and do it again, I would make it more worthwhile though and swap in maybe H7 MDX projectors or something.
You would be surprised what fits. My H3 units barely took up half the space inside.
Either way, the projectors in that ebay auction are garbage. I had a set very similar to that at one point and they are absolute trash. They have 0 output and don't even look that good. Take the time, find something halfway decent (at the very least, some sort of OEM projector) and retro it into the stock housings. I'm issuing you a challenge, though: find a way to make new lenses for the stock fog housings to get rid of the lines
Old May 5, 2007 | 09:31 AM
[/QUOTE]
I'll take that challenge. I'm sure I can find someway to do it. I wasn't gonna use the fogs to actually use for lighting. I would just use them for the look. I was sure that the putput on these would be garbage. I have an even better set that I ran across last night. Check these out:
http://hidplanet.com/i/bosch_mini.jpg
I was gonna retro these into the stock fogs. I know a guy that can mold plastic for me. SO i think that will be my first stop enroute to my challenge victory. LOL.
Hey if I get some made then you can have a set for free tatanko .
Old May 5, 2007 | 09:50 AM
Tatanko's Avatar
Bacon Lover
I look forward to your victory. If it will benefit the community, a challenge is always in order I would gladly pay a sum for some new lenses, however plastic is not going to cut it. Keep in mind the sheer heat produced by these things. Take the bulb out once after it has been on for a while and you'll get the idea. It has to be able to withstand heat combined with the polar opposite of cold in the winter. Plexiglass maybe? Still up for the challenge?
The projectors you linked to are about as good as it gets for an H3 halogen unit. Very similar in design to mine, if maybe a tiny bit better. They would be a good choice, but I would still see if you can get maybe H7's or H11's for the same price on ebay.
http://cgi.ebay.com/ebaymotors/HID-P...QQcmdZViewItem
Those would be a good choice. I would double-check the given dimensions with how you would want to mount them in the housing to make sure they wouldn't stick out too far in the back and run into anything.
Old May 5, 2007 | 11:55 AM
It wasn't gonna be just some run of the mill cheapo plastic. The place that I mentioned does plastic molding for Nissan products. Plexiglass would probably be the best thing to use, even though it would be quite a bit more difficult. But if everything was easy then every one would do it.
The projectors that I linked might be the best because of their size. THe one's you linked have a huge lens on them and they aren't enclosed either. The lens is 2.75 inches. That would take up all of the stock housing. That's the same size I run in my headlamps and it was a very tight fit.
Old May 5, 2007 | 12:26 PM
Tatanko's Avatar
Bacon Lover
Good to hear. I hope to see a well-done end product, and hopefully I can get a set then as well.
The projectors aren't enclosed, no, but just make a shroud for them. It's quite easy and inexpensive. I have E46 bixenons in my headlights, and they're 3" Honestly, once you have the fog lights apart and have the reflectors out, you'll be surprised just how much space there is. It is essentially a wide-open, thin-walled plastic shell with a glass lense on it.
Old May 5, 2007 | 09:54 PM
FantasyGod's Avatar
Polycarbonate is the best since it's UV resistant.
Old May 6, 2007 | 07:33 AM
Tatanko's Avatar
Bacon Lover
I don't know enough about it, but would it take the high temperatures of the bulbs?
Old May 6, 2007 | 02:07 PM
Tatanko's Avatar
Bacon Lover
Well, like I said, all you have to do is look around. I'm pretty sure I'm picking up a set of really nice H7 projectors for only $35 shipped
Good output already, and H7 is the absolute best halogen projector to use HID bulbs in (the focal point is almost identical) should I decide to go that route later. Goodbye H3 projectors, hello H7 projectors
Old May 7, 2007 | 11:14 AM
2kprlmax's Avatar
I know you are looking for 4th gen but from what I heard the glass part messes up the pattern. As you can see on the 2k the glass is clear. Dr.Roy did a set and I have them now on the car.
Here is a pic:
here is my cut off:
Old May 7, 2007 | 02:11 PM
MorpheusZero's Avatar
Originally Posted by 2kprlmax
here is my cut off:
10char
Old May 7, 2007 | 05:23 PM
2kprlmax's Avatar
I know the left fog is not leveled.
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
rnb754
Sep 14, 2015 11:39 PM
Maxie40
Sep 14, 2015 11:28 AM
Maxima30
Sep 7, 2015 06:13 PM
