Cant replace antennae
Old Aug 25, 2007 | 03:43 PM
andrei3333's Avatar
I took out the silver nut and trying to unscrew the antennae now, its moving but its not unscrewing, like i can turn it but its still sitting in there its turning forever for no reason.
same goes for my replacement which came with a working motor, i cant get that one out of the motor as well, what gives ????
here is where i am at now
Old Aug 25, 2007 | 05:11 PM
andrei3333's Avatar
never mind, i got pissed and swapped out the whole motor with the antennae. it took much less time then trying to take out the old one and the new one from the motor.
any one know what a motor costs these days ? gota sell this one now
Old Sep 7, 2007 | 08:26 AM
wayne937's Avatar
According to my Haynes Manual all you have to do it remove the nut and the mount under it. Then while holding onto the antenna have some one operate the switch with the radio on and it should back right out. Installing would be the reverse.
Old Sep 7, 2007 | 04:03 PM
andrei3333's Avatar
i have a remote controlled mp3 deck and i tried doing that cause i read it in the FSM, nothing , the antenna moved and i tried pulling it out, but it never came out.
its ok, i dealts with it by swapping the whole motor, it actually worked out pretty good because the new motor was much quieter than my old one was.
Old Sep 7, 2007 | 04:31 PM
maxima985spd
now disconnect the antenna wire. it will get stuck during the winter now.
Old Sep 7, 2007 | 04:33 PM
SVI30's Avatar
Once you took out the top nut, just pull the antenna whip out. There is a nylon tail underneath the metal whip that has cogs that engage the gears in the motor. Pretty easy to do.
If the nylon whip breaks and leave a tail in the motor housing, then you have to take the motor housing apart to get that out. The entire antenna from a dealer cost about $200. The slanted cast metal piece is different between Max and I30. I had to reuse that piece on my new antenna.
Old Sep 7, 2007 | 04:41 PM
andrei3333's Avatar
2 hundred bones are u kidding me ? i got the perfectly working motor and the perfectly working antenna assembly for a whopping deal of 20 canadian dollars from some guy who crashed his max into a tree splitting it in half.
guess i got a good deal
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
