Remote starters
Old Sep 25, 2001 | 06:20 AM
2DMax's Avatar
Remote starters
Anyone have a remote starter on a 5-spd?
Winters get a little cold around here....
Old Sep 25, 2001 | 08:42 AM
kaniksu's Avatar
I believe that remote starters only work on automatic trans. I hope I am wrong though as I would love to have one for my car.
Alec
Old Sep 25, 2001 | 08:49 AM
Ravq's Avatar
You can get one installed on a manaul but you need some sort of clutch bypass device to do it properly. I have seen it done and I believe you have to always be sure the car is in N when parked otherwise the car might jerk. A lot of shops/installers are wary about doing them on manual transmissions due to risk of liability.
Old Sep 25, 2001 | 09:09 AM
Daniel B. Martin's Avatar
Inhibitor relay bypass instructions
Originally posted by Ravq
You can get one installed on a manaul but you need some sort of clutch bypass device to do it properly. ...
This is the way to circumvent the no-crank safety circuit. Use this information at your own risk!
1) Raise the hood.
2) Just in front of the battery you should see a black plastic relay box. This is relay box #2. There is a good photo of it in the Haynes manual on page 12-4.
3) Snap off the relay box cover.
4) There are two rows of relay sockets, four in each row. Your relay box may have some blank sockets, depending on which options are installed. Look at the row of relays closest to the battery. The second from left socket should have a blue relay installed, and that is the Inhibitor Relay.
5) Remove the Inhibitor Relay and save it for a rainy day. Fashion a short jumper and insert it in socket positions 3 and 5. The positions are numbered on the base of the relay, but they are hard to read. Terminals 3 and 5 are the pair which are most distant from each other.
6) WARNING! With this jumper installed the no-crank safety interlock is disabled. Your 5-speed Maxima will crank and start without stepping on the clutch.
Old Sep 25, 2001 | 09:54 AM
2DMax's Avatar
Re: Inhibitor relay bypass instructions
Hummm....thanks, seems real easy.
Old Sep 25, 2001 | 10:04 AM
TILLEYS99's Avatar
Lives in a 11sec maxima
Re: Re: Inhibitor relay bypass instructions
You can do a remote start but youll probably have to do it your self most shops wont touch that I worked at 3 shops as an installer and none of them would do it but its not impossible its the same as an automatic wiring harness the only thing on a max to bypass is the ones with the square keys because the key must be within a certain distance of the ignition or the car wont start but Ive bypassed that on mine so I could use a remote start.
Old Sep 25, 2001 | 10:28 AM
Re: Re: Re: Inhibitor relay bypass instructions
The Inhibitor Relay bypass deals with the clutch pedal safety interlock. That is a separate topic from the Nissan Vehicle Immobilizer System which uses a "chipped" ignition key. NVIS was standard equipment on the '99 Maxima. If you know how to bypass the NVIS please post instructions here. Some Maxima owners -- me included -- live in places where car theft is not a problem, and the NVIS is a nuisance.
Old Sep 25, 2001 | 10:41 AM
TILLEYS99's Avatar
Re: Re: Re: Re: Inhibitor relay bypass instructions
Ill have to look and see I cant remember exactly where I put the little module that is in the key it has to be at the perfect spot or it wont work it took a while to work that part out but if you take the key theres a little piece of plastic that would face the ignition you can use a needle and pry the plastic out and you have a chip that comes out with it you must fasten tat to the ignition if its at the wrong place on the ignition it wont work it took me a couple tries till it worked. Is tat true that 99 were the only years that have that.
Old Sep 25, 2001 | 10:45 AM
pianoman41's Avatar
Most newer remote start systems will work on manual transmission vehicles. The install will cost extra as they have to install the clutch bypass and they also put in a circuit to verify the tranny is in neutral *and* the e-brake is activated before the system will start the car. I have seen one of these installed on a 5-speed Maxima and they work fine. You do have to activate the system each time you get out of the vehicle if you want to remote start it the next time, but I'm sure it becomes a habit once you're used to it.
Old Sep 25, 2001 | 10:55 AM
"Chipped" keys
... Is tat true that 99 were the only years that have that.
TTBOMK all '99-up Maximas have the NVIS as standard equipment. That means a spare key must be obtained from a Nissan dealer for $70. A $2 hardware store key can be used to open the trunk but not drive the car.
Old Sep 25, 2001 | 11:01 AM
TILLEYS99's Avatar
Re: "Chipped" keys
if you take the chip out of the key and fasten it to the ignition you wont need that $70 key for the ignition.
Old Sep 25, 2001 | 12:31 PM
SuDZ's Avatar
Five Speed Car Starter
Hmmm. Maybe I will look into this. I have a brand new Car starter that works for about 400 feet still in the package. It comes with a video and stuff so maybe I will. I thought since I had the 5 speed I would just sell it. Might still but gives me options.
SuDZ
Old Sep 25, 2001 | 12:48 PM
ericdwong's Avatar
As an additional safety step, I would do this if you disable the clutch start inhibitor. I found out that the 5 speed in a Maxima will emit a 5 volt signal when the thing is in gear and send a ground signal when it is in neutral (or it might have been the other way around, I'll have to test). Anyway, wire up a 5 volt relay from Radioshack so that if the car is in gear, it will "open" the clutch inhibitor circuit, thus not allowing the car to crank when it is in gear. As an additional safety step, I would also wire up another relay off of that to the "remote start disable" input of the remote starter that is usually used when the hood is raised. I might put one of Autoloc's units on. I might even put a remote start on my motorcycle :-)
Old Sep 25, 2001 | 01:23 PM
Kevlo911's Avatar
Kevlo for President
i think I30Cerfio has a remote starter on his 5-speed
Old Sep 25, 2001 | 02:58 PM
mb1's Avatar
mb1
http://www.crimestopper.com/vectorsystems.html
This alarm was designed to work with both an automatic and a manual transmition car.
Old Feb 28, 2003 | 09:00 AM
tweaked's Avatar
Hello all,
I know this is an old thread but I have a 5sp with no clutch started disable relay. (ie I can start the car without depressing the clutch) So I looked under the hood for the Starter Inhibitor Relay in the relay box #2. There is no relay and no connector in the bottom of the box where the relay should be. How can this be? Could the previous owner have change from auto to 5sp transmission? What am I missing. I would like to install the relay before me (or my wife ) start the car without depressing the clutch and I have to fix the bumper again!
Thanks for any help you can provide,
Stephane
Old May 20, 2003 | 06:31 AM
Prodeje79's Avatar
Hey there!
I am looking to get some exact details for self installing a Matrix RS3. I have to use this alarm since I work at Best Buy and get a good deal on one.
I want to SAFELY install remote start for my 5speed. Did anyone get exact details for this yet? EricDWong? :>
Any help on making sure I can still use my Trunk release and Window roll down feature would be awesome.
Any other tips or recommendations would be appreciated!
Thanks!
Old May 20, 2003 | 08:06 AM
vabeachmax's Avatar
I didn't know there was a safe way to do that?
Old May 20, 2003 | 08:25 AM
Prodeje79's Avatar
Did you read the whole thread?
Pianoman said "Most newer remote start systems will work on manual transmission vehicles. The install will cost extra as they have to install the clutch bypass and they also put in a circuit to verify the tranny is in neutral *and* the e-brake is activated before the system will start the car. I have seen one of these installed on a 5-speed Maxima and they work fine. You do have to activate the system each time you get out of the vehicle if you want to remote start it the next time, but I'm sure it becomes a habit once you're used to it.
Check out EricDWong's post as well....
Also, i know for a fact the Compustar has a safe feature as well. I was going to get this alarm but I do not get a best buy discount on it...
It can be done, I just want exact details so I can do it.
Old May 20, 2003 | 08:33 AM
vabeachmax's Avatar
I just kinda skimmed through it, I guess I missed that. I never heard of it being 100% safe so thats why I asked. No harm, no foul. Good luck with this project.
Old May 20, 2003 | 01:11 PM
delio's Avatar
it can be done... trust me
Old Jun 22, 2003 | 04:14 PM
Show Maxima's Avatar
to end this debate of hearsay and thoughts, I have the avital 6500, i installed it on my 1st car a diesel jetta 5 spd, then installed it on my accord 5spd. Here is the scenario, any remote starter should work on a auto/5spd. regardless. the only thing a remote starter does is get in between the key and the starter and 'simulates the key being there and starts the car. in a 5 spd, the remote starter wires directly to the starter, so the alarm directly powers up the ignition of the vehicle, and the alarm itself powers the starter. it bypasses all of those pesky safety features. i now have an auto max, with the alarm installed. no problems. in both of the previous 5 spd cars, once the alarm was installed, i never had to depress the clutch again... remote starting or not....as the system now ran through the key to the alarm to the starter by passing the above said systems. any questions just ask.
Old Jun 23, 2003 | 08:31 AM
Prodeje79's Avatar
I still would like more exact details on how to wire the neutral sensing saftey option.
Also, how do I keep my factory roll down the front windows, exactly?
thanks
maxima297
Sep 30, 2015 03:32 PM
msellas
Sep 23, 2015 09:16 PM
ToTheMax305
Sep 23, 2015 09:11 PM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
