how do i swap 9004 bulbs to 9007's?
Old Oct 12, 2007 | 04:34 PM
maximacruizer's Avatar
hey i can't find the thread about this or it directs me to the wrong place. i wanna do the swap but is there wiring upgrade i have to do or any kinda mod i have to do? if somebody could let me know that would be much appreciated i wanna put 9007 bulbs in instead of 9004
Old Oct 12, 2007 | 04:46 PM
bigpulve+'s Avatar
You have to swap around the high and low beam wires and shave off one of the knubs on the bulb....IIRC
Old Oct 12, 2007 | 04:48 PM
pmohr's Avatar
No more Maximas...
... http://www.vqpower.com/v2/readarticle.php?article_id=70
Old Oct 12, 2007 | 05:37 PM
tvis's Avatar
I've done this mod.... kicks ***. I made new harnesses w/ relays for them too. Waaaaay better light output.
Old Oct 12, 2007 | 08:26 PM
Cdg2125's Avatar
make sure you make new harnesses. It creates more output.
Old Oct 12, 2007 | 09:01 PM
99Maxima929's Avatar
Has anyone done this using a 9007 HID kit? Would it make a difference and is it worth doing? Thanks.
Old Oct 13, 2007 | 09:36 AM
maximabebe's Avatar
I have....Just grab some 9007 harnesses from your local auto parts shop. I think I paid about $4 ea.
Old Oct 13, 2007 | 05:36 PM
ok... so instead of buying everything i need which will roughly cost $60 (all connectors wires ect... ) i just found this now just wondering will i have to modify anyting on this as im going from the 9004 - 9007 ? its cheaper this way! if somebody can quickly clarify it for me that would be great
https://www.jegs.com/webapp/wcs/stor...0002_746484_-1
Old Oct 13, 2007 | 05:44 PM
MOHFpro90's Avatar
How do you get $60 out of that? It shouldn't be that much...
Old Oct 13, 2007 | 05:53 PM
2 relays - $6x2 $12
2 9004 socket - 8x2 16
12 gauge wire 30' 9.50
2 fuse holders 2x3.5 7
some connectors 8
$52
+tax 13% $60
+ 2 9007 Xtravision $28+tax = 31.64 +60 = $92
so this is about a $100 upgrade from what i priced out unlessi buy the harness from Jegs
Old Oct 13, 2007 | 06:19 PM
Do you notice any difference on the light output at night?
Better, Worse or same? and on what degree? Just trying to find out if its worth doing.
Old Oct 14, 2007 | 04:20 PM
Cdg2125's Avatar
2 relays - $6x2 $12
some connectors 8
$52
+tax 13% $60
whoa damn where did you get that from ha. I paid $30 for all of the pieces of my harness. How did you get $92 from this? Where do you shop?
btw: to the other guys, you do not need a new harness for the 9007's. Switching the high and low beams wires will make the 9007 lights work but there is no point because the harness is supposed to be made to draw power from the battery for better light output. Using 9007 on stock harness won't give better light. You might think it does but they are still drawing the same power really. Yeah maybe 5w difference. Do a harness.
Old Oct 14, 2007 | 07:16 PM
maximabebe's Avatar
Well yea because I went from stock 9004 halogen to 9007 8000k high intensity. World of difference.
Old Oct 14, 2007 | 11:20 PM
maxim82's Avatar
im interested on how you did your connection, i heard that without any relays you can damage your headlight switch, dont know how true that is but i really dont want to take that chance. the sticky here on the org takes you to a diiferent thread and the on on vqpower doesnt show any relay connections. so let me know if theres a write up on how you did it, if not can you post something?
Old Oct 15, 2007 | 04:24 AM
tvis's Avatar
Fixed the link from the stickies.
http://forums.maxima.org/showthread.php?t=230510
I honestly don't think it'll do any harm to anything by going from 9004's to 9007's without an upgraded harness. The wattage increase is only 10w on the high beams which isn't a whole lot. If you ran some 90w/100w bulbs you'd definitely run the risk of frying/melting something though.
You will, however, get much better light output by installing a harness along with your 9007's, and I really think you actually kinda need one to get the full benefit of running the 9007's. I definitely saw this with mine. I had originally just installed the 9007's without the harness. The light pattern was better on both the low and high beams, but was no brighter. As soon as I got the harnesses done and installed, I turned the lights on and could immediately tell they were brighter.
For the harness, I think I'd go with what maximacruizer posted. I think I spent almost that much on my harness and I still had to make it!
I actually made mine with 4 relays for some reason. I used one relay for each of the low and high beams. Benefits of this? I dunno, I think it was probably just overkill
No pics of my set-up because 1. Wiring still needs to be cleaned up, and 2. I rear-ended a taxi in heavy traffic recently, so there's some unsightly duct tape holding my grill in place, and keeping my headlights aimed. Aside from my hood being bent up a bit on the driver side, you can't tell from the outside that I hit someone.
As for bulbs, I used the GE Nighthawks and they work great. A nice cheap alternative the the Silverstars that everyone raves about, yet seem to burn out rather quickly.
Old Oct 15, 2007 | 08:25 AM
Cdg2125's Avatar
Exactly. As I've said, you need to use a harness. It's just a waste to use 9007 bulbs in the stock harness. People do it to write it in their sig like they did a big upgrade. You're still really pulling the same power through your stock harness so the extra watts that the 9007's should get don't really make a difference. The harness only needs two relays, and how are you guys paying so much for the harness? You got ripped off or will. I made a harness and bought 9007's way less then $90.
Old Oct 29, 2007 | 01:03 PM
ThurzNite's Avatar
I did this conversion and would highly recommend against it. It's like putting HID's in stock housing. There's so much stray light. I'm sure I'm blinding the cars in front of me, including oncoming traffic as well as cars I'm following. Even after adjusting the headlights using "foglight" guidelines, there's still extra light that shines upwards. I'm gonna switch back to 9004 but retain my custom wiring harness.
Jae
Old Oct 29, 2007 | 02:53 PM
tvis's Avatar
Jae
I've had none such problems with mine. They're brighter, but most definitely not as bad as HID's in the oem housings.
Old Oct 29, 2007 | 04:56 PM
ThurzNite's Avatar
How can the beam pattern not change? The original housing's made for 9004. Are you telling me your 9004 bulbs are exactly the same as 9007 except the 9007's higher wattage?
Jae
Old Oct 29, 2007 | 06:33 PM
tvis's Avatar
http://www.suvlights.com/images/9004vs9007bulb.jpg
Jae
I never said that. I simply said that they are NOT as bad as HID's. HID's are waaaaaay worse in the oem housing. I know this because I've tried it and saw first hand.
On the topic of the 9007's, I highly doubt they're an annoyance to anyone. I've had friends driving in front of me, at me, behind me, beside me, below me, above me, around me, and even with me. No one has said a thing about my lights being any kind of annoyance.
What year is your car? (95/96 frosted lenses, or the 97-99 diamond cut?)
Old Oct 29, 2007 | 08:42 PM
ok so i made my harness hooked it all up and they work great... one question tho.. did everybody else's Daylight running lights stop working? if so awsome cuz i hated them anyways
Old Oct 29, 2007 | 08:49 PM
Cdg2125's Avatar
haha are you telling me that you messed up your running lights and didn't fix them? You know you need them on to be legal right? You can't just have headlights only...
pmohr's Avatar
No more Maximas...
Just because I know people are gonna come in here yelling we don't have DRL's, the Canadian maximas came with daytime running lights (per Canadian DOT, I imagine).
Old Oct 29, 2007 | 09:10 PM
tvis's Avatar
We don't have DRL's!
Old Oct 30, 2007 | 06:34 AM
I AM CANADIAN!! so my car has them don't tell me they don't if you plan on it... anyways so ya after i hooked it up i don't have DRL's anymore!! before the only way to bypass DRL was to pull the E-Break 1 click then start the car. but if i released the E-break it would turn them back on. I took my car out for a spin last night with the x-travision 9007's and i love it especially cuz i wired the high beams to the low beams nice and bright and no glare and i can see my beam pattern everywhere i go !!! even over top of street lights I love it!!!
Old Oct 30, 2007 | 04:34 PM
tvis's Avatar
Missed the joke?
Old Oct 30, 2007 | 06:51 PM
Missed the joke?
i think so
Old Oct 30, 2007 | 08:02 PM
tvis's Avatar
First it was....
To that I said...
tada!
Old Oct 30, 2007 | 09:45 PM
oh... i feel dumb now.. thanks alot.. j/k
Old Oct 30, 2007 | 09:54 PM
tvis's Avatar
Old Oct 30, 2007 | 10:12 PM
maxx0831's Avatar
how bad is the oem housing with 9004 HID KIT, i was plannin to put a 9004 hid kit in my oem housing but now I dont know.
Old Oct 31, 2007 | 06:18 AM
maxx0831's Avatar
can someone check this out and tell me if this is wut I would exactly need to do the 9004 to 9007 swap correctly and easy
http://cgi.ebay.com/ebaymotors/9007-...spagenameZWDVW
Old Oct 31, 2007 | 07:36 AM
ThurzNite's Avatar
Yes but, you're gonna hafta swap 2 wires (possibly 4, depending on how they wired it). Figure out which wires are the ground and low beam and swap them.
Also, as the thread already discussed, stock 4th gen housing is inappropriate for HID conversion. You'll hafta get creative with projector modding to make it work safely.
Jae
Old Oct 31, 2007 | 08:36 AM
maxx0831's Avatar
thanks, im probably just gonna do the 9004 to 9007 bulb swap NO HID then. I just want brighter lights on the road bc the 9004 bulb sucks on the road
Old Oct 31, 2007 | 08:46 AM
aporozco's Avatar
Stock Airbox Supporter #3
Is there somewhere besides ebay and the internet to find a harness. Did someone mention Autozone?
Old Oct 31, 2007 | 12:53 PM
ThurzNite's Avatar
http://www.4crawler.com/4x4/CheapTri...OnLineOrdering
I didn't use the switched ground harness that the website notes. You can buy all the parts you need at an autopart store, except maybe not the male harness that plugs into your existing harness.
Jae
Old Oct 31, 2007 | 01:32 PM
Jae
just take a 9004 bulb wrap the glass with paper towl and hit with hammer.. then pry the metal part outta the bulb
and ur left with 3 prongs
and 3 wires pull the prongs out then drill 2 holes just above where the prongs go thru and put a wire thru that new hole and attach to prong then re insert prong and fill with hot glue on both sides. not to much on the site that the original bulb connector has to plug into tho.. just enough to hold prongs in position
thats what i did for mine wire don't have to be thick its just the trigger wire for the relay anyways high and low beam don't worry bout the gound leave that prong out
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
Noela
Sep 26, 2015 08:22 AM
