Whose got the highest mileage?? Any issues?
Old Jan 12, 2008 | 09:59 PM
  #81
rm4628's Avatar
CLICK CLACK 1
145k in counting
water pump
alt,starter,trans
plugs,purge valve
Old Jan 13, 2008 | 07:01 AM
  #82
njmaxseltd's Avatar
142K on my 99.
A few tune ups, oil changes, brakes, tires, KS, exhaust system, wash, wax, DRIVE IT.
Old Jan 13, 2008 | 09:50 AM
  #83
diamondtcb's Avatar
129K - Starter, Alternator, CV Joints, Driver side window motor, Struts, Bose Head Unit
Old Jan 13, 2008 | 10:49 AM
  #84
icaghost's Avatar
151k - battery, shocks/struts, wheels/tires, connector for ac speeds 1-3, starter
Old Jan 21, 2008 | 11:20 AM
  #85
tallkid2201's Avatar
ive got 150k on my 97
replaced:
knock sensor
oil leak.........$800..... long story
starter
front struts
oil pressure switch
Old Jan 21, 2008 | 12:30 PM
  #86
guysohigh's Avatar
SimStones
279K
starter, alternator, cv joints, radiator,
Old Jan 21, 2008 | 05:19 PM
  #87
kaneda_77's Avatar
245k
Replaced:
Battery
Starter 2 times
Old Jan 21, 2008 | 05:24 PM
  #88
Product_Of_Korea's Avatar
oh let me think
1997 maxima gxe w/155k bought it in 2003 w/ 70k on it
-clutch -rear main seal
-tranny -A\c compressor just went(or atleast the pulley did)
-2 axles(drivers side) - Rear 02 sensor
-2 starters - Crankshaft pos is going
-altenator - i need a rear passenger cailper
-knock sensor - Wheel bearing
- my turn signal keeps flying off and i lost it so i havent replaced it yet
Old Jan 21, 2008 | 07:30 PM
  #89
one_mil_2010's Avatar
I see alot of people have rebuilt their trannys - I got a 99 5spd with 203,xxx - how do I know if I should rebuild mine? What are the symptoms of a bad tranny?
I've had mine since 165,000 and so far just changed
3 O2's
tires
oil and plugs
pcv
rear brake pads
I do have a CEL and it is running like crap, will get it fixed this spring
Old Jan 21, 2008 | 07:50 PM
  #90
Roadkill's Avatar
I just bought mine with 170k on it.
Thing is running like a champ!
99 SE 5psd
Old Jan 21, 2008 | 08:15 PM
  #91
MaximaMark123's Avatar
132.000
My 240 Z and Nissan Van went over 200,000 with normal maint. My Maxima, 1996, I just replaced the struts and drive shafts. No other probs.
Old Jan 22, 2008 | 08:36 AM
  #92
97maximaman's Avatar
Wow you guys drive alot. I have a 97 with 136k, 125k when i got it 3 years ago.
Master and Slave clutch cylinders
Rear brakes
CPS
Full exhaust
Both CV axles
2 o2 Sensors
If you wanna cut down the miles i have a good tip, do what i do. Tell all you friends your car broke down and you need a ride to work...now do that for 3 years straight. If there dumb enough they'll drive you everyday.
Old Jan 22, 2008 | 02:02 PM
  #93
ThurzNite's Avatar
97 with 215k. Issues? None currently, excecpt that I want a *real* luxury sport sedan.
Dr J
Old Jan 22, 2008 | 07:28 PM
  #94
Mabidor's Avatar
220K
1997 GXE auto. Bought new.
Starter-2006
Both drive shafts-2006
Front struts-2006
Radiator-2007
Speedometer head-2007
Currently driving with bad KS and P0440 leak in evap system (just came up last week).
Bad radio LCD display.
Old Jan 22, 2008 | 08:10 PM
  #95
Sounbwoy's Avatar
Awright, I'll bite too...
285,xxx - bought used with 65,650 miles in 1999.
ALL original except for tranny replaced 100,000 miles ago, halfshafts, two clutches, radio, radiator, FTSB, 5th Gen 17" wheels. KS, two O2 sensors, t'stat, Flowmaster 40 Series, starter
EDIT: forgot the infamous EGR valve tube cleaning...
Old Jan 24, 2008 | 07:11 AM
  #96
LeVeL's Avatar
185xxx, replaced too many things, biggest being the tranny
Wanna see a truly clean high mileage car? http://www.acurazine.com/forums/show...3&page=1&pp=25
Old Jan 24, 2008 | 07:21 AM
  #97
No way, either something is wrong or that car was totally rebuilt. Im sorry but i just dont believe it, if the paint wasn't dulling then the engine should have grease or the seats should be cracking or the wheel wells should be disgusting, the steering wheel should be peeling. Even if the owner babied it thats just not possible, i say the car was rebuilt!!
Old Jan 24, 2008 | 09:43 AM
  #98
kbosse's Avatar
'97 SE Auto
Bought it with 150,000 three years ago for about $5,000. Now has 225,000. I drive about 80 miles a day all highway. No major problems. I still get about 26mpg and it is as quick as when I bought it. Best $5,000 I ever spent.
Here's the list:
-Both Front Axels and boots
-Starter
-2 Alternators (still having problems)
-Battery
-Drivers rear caliper
-Trans Pan Weld Repair, Someone left a wheel in the middle of the road, I could not swerve to miss it, punched a whole in the trans pan.
-Knock Sensor
-Crank position sensor
-Radio
-EGR Valve
Currently has some small problems.
Old Jan 24, 2008 | 09:53 AM
  #99
Crusher103's Avatar
200k on the auto
4th gen starter problems
pass. lower control arm
rear calipers oddly went at the same time
Bose-self explanatory
4th gen mt
no problems yet bought it 5 months ago but things we were told
idle control sensor
the trunk decided when it wants to open
Old Jan 24, 2008 | 10:42 AM
  #100
DrTySOUFMaX23's Avatar
221k
just recently changed the alty for the first time and starter as well other than that....still runs like a champ!
Old Jan 25, 2008 | 04:42 PM
  #101
jazzman's Avatar
256K ... replaced water pump + radiator... new Raxles... battery... front suspension rebuilt with Nissan parts and Illumina suspension kit ... O2 sensor... still runs great!
Old Jan 25, 2008 | 06:38 PM
  #102
Batxel's Avatar
blah
210K
-both front o2 sensors (125k)
-knock sensor (130k)
-axles (147k)
-camshaft position sensor (149k)
-starter (151k)
-evap vent control valve (170k)
-transmission/clutch (original made it to 203k) -was locked out of gears 1 and 2 but was able to drive it to the tranny shop :P
I believe I have an exhaust leak some where, it's rusted out pretty badly, but I'm not touching it till inspection time.
This car was somewhat troublesome for me but it has always got me from point A to B.
Old Jan 25, 2008 | 09:43 PM
  #103
cditto's Avatar
95 with 265k miles
basic maintenance and tune-ups only other than IAC valve. Still running strong with no problems...but I bought it used so not sure what was done prior to me.
Old Jan 25, 2008 | 09:49 PM
  #104
aih98max's Avatar
scoobystoned...
wow...another milage thread.
163K bought 3 years ago with 127K
So far all ive replaced has been:
CV Axles
Front Rotors & Pads
thats about it, plus a few tiny things like one stupid EVAP sensor.
Old Jan 26, 2008 | 05:38 PM
  #105
ptatohed's Avatar
Licensed to Spell
Originally Posted by maximaserg
I have 136 000
Major issues:
-Changed starter
- changed main engine mount
Whose?
Old Jan 27, 2008 | 04:19 AM
  #106
Armelius's Avatar
285k miles.
Changed starter three times. Brake master cylinder. Rear wheel bearing.
Needs windshield (sort of pitted). Radiator support (rusted). Hood repaint. Hell, the whole car needs a coat of paint. EGR needs cleaning or replaced. Besides wear and tear items this car still gets 31 highway and 27 in city.
Still trying to figure if I should put some money in it and where to put it.
Old Feb 3, 2008 | 03:02 PM
  #107
komik's Avatar
96 5 Spd SE - 236,000 miles
I just bought it a week ago. It runs strong aside from a miss in cylinder 2 (waiting on coil pack). I think it needs a passenger side axle and some minor front end work. Otherwise it's great.
Old Feb 3, 2008 | 04:11 PM
  #108
fat_kid's Avatar
i'm with you, 300k on a stock clutch, I don't think so.
Old Feb 4, 2008 | 11:10 AM
  #109
Dark_man_x's Avatar
lol im at 420 K on a stock clutch.
Old Feb 4, 2008 | 01:49 PM
  #110
tcf_dk's Avatar
96 auto with 325,000. No major issues except normal wear and tear.
Old Feb 4, 2008 | 02:25 PM
  #111
Crusher103's Avatar
Prepare to be flamed
Old Feb 4, 2008 | 02:59 PM
  #112
ghrycan's Avatar
142k on my 98 5 speed
Knock sensor, tires, and just regular maintenance. but pretty sure my synchros are worn, or something is wrong with my tranny, cause it's rather hard to shift.
Old Feb 4, 2008 | 06:30 PM
  #113
AllMaxxedOut's Avatar
159K on 98 auto (maintenance done regularly; rebuilt tranny/vb mod w/ 40K).
Old Feb 12, 2008 | 07:19 PM
  #114
trueppp's Avatar
300K on 95 5spd, stock clutch, new alternator, 02 sensors, y-pipe(stock broke at 275), brake + gas lines, steering rack slightly leaking (1/4 of PS fluid a YEAR), 10% loss on leakdown, tranny STARTING to get rough, need new TPS....
Old Feb 15, 2008 | 12:00 PM
  #115
Trinispice's Avatar
1996 170,000
Starter
Lots of sensors, lol -Knock, Crank, Throttle, all went bad, not just because I wanted too.
Clutch
Front Axles - Both
Old Feb 15, 2008 | 01:24 PM
  #116
UnknownRacer's Avatar
94 maxima.. 178,000miles..
alternator..lol
Old Feb 15, 2008 | 01:47 PM
  #117
ajcool2's Avatar
alternator..lol
Interesting. I'm at 177 and mine is going also.
Old Feb 15, 2008 | 01:57 PM
  #118
JonBlz's Avatar
a.k.a. STuNtMAN
i have 182k now and im S/C'ed
issue:
belt squeaking have to change it, it gets annoying
Old Feb 16, 2008 | 10:33 AM
  #119
al river's Avatar
96 max se
208 k
repairs:
o2 sensors
water pump
i hope that"s it for now!
Old Feb 17, 2008 | 09:55 AM
  #120
Ilovemy98max's Avatar
98 max with 92,500miles shes a baby
