TPS
Old Dec 15, 2007 | 09:51 PM
Olezhka's Avatar
TPS
I took it off and when I put it back on it gives me a high idle.
I tried adjusting it a few times and got it lower, but can't get it lower than 1000 rpms.
btw, I also cleaned the tb, mani, egr.
Old Dec 15, 2007 | 10:01 PM
JonBlz's Avatar
a.k.a. STuNtMAN
u have to adjust the throttle its a lilo screw on the tb when u do dat u have to mess wit the tps so u can get the right idle u want i had the same problem
Old Dec 15, 2007 | 10:07 PM
CRiME's Avatar
oem ftw!
sometimes when you clean the TB, that can bring up the idle too, it might take a while to lower itself. when you put the tps back, did you get it as close to 500 ohms as possible? resistance reading should be 500 idle, 4,000 WOT.
Just noticed you cleaned the UIM and egr tube, did you remove the manifold to do that? if so, check for vac leaks both at the UIM to LIM junction and where the EGR guide tube connects. spray carb cleaner in the general area and see if your idle goes up. if it does, you have a vac leak somewhere
Old Dec 15, 2007 | 10:17 PM
aznsap's Avatar
i think youre supposed to calibrate the tps when the engine is warm.
Old Dec 15, 2007 | 10:22 PM
CRiME's Avatar
oem ftw!
yea, that too. heat will effect the resistance. make sure the engine is warm when you adjust the tps.
Old Dec 16, 2007 | 08:51 AM
njmaxseltd's Avatar
Follow the procedure in the Chiltons manual to adjust the TPS.
You will need a ohm/volt meter to set that sensor up correctly.
Old Dec 16, 2007 | 01:02 PM
JtzMax's Avatar
Whatchyou say?
Why did you take the TPS off in the first place? Just to clean the TB?
follow the Chiltons and make sure to use a VOM.
p.s. nice bike mate!
Old Dec 16, 2007 | 06:36 PM
Olezhka's Avatar
lol I took it off becuase I'm a dumb *ss. K, I got a chilton's so i'll try to do it tomorrow.
Old Dec 16, 2007 | 07:24 PM
AndrewR2442's Avatar
When i took everything apart to do my cleaning i took the tps off like a dumbass. When i put it back on i didn't calibrate it the first time. I drove w/it for about 2 weeks and my car was constantly downshifting. PITA!!! So i reajusted it. It got really high idle when i was moving the tps around and even after i had secured it in again.
If that's what you were referring to.. it goes away. Mine's been golden for about a month now.
Old Dec 16, 2007 | 07:35 PM
Olezhka's Avatar
Yeah, thats what I'm having. And the idle is fine if iremove the tps.
k, I guess I'll adjust it some more tomorrow and see if it drops later.
dam sensors!!!
Old Dec 17, 2007 | 02:27 PM
Olezhka's Avatar
K, I adjusted the tps as much as I could and the idle went down to about 900rpms and then I adjusted the little screw on the TB and it went down to about 600rpms.
Let's hope it stays this way.
Thanks guys.
Old Dec 17, 2007 | 03:36 PM
Olezhka's Avatar
No, it didn't stay like that.
when I shift into drive it goes up to like 1000
and later when I had it in park today it was reving by itself. WTF
anyway I have a final to study forright now, so I'll get back to the car tomorrow.
Old Dec 17, 2007 | 04:28 PM
flyby's Avatar
my stupid pad is doing the same thing!!!!!!!!!! is it throwing ne codes??
Old Dec 17, 2007 | 08:26 PM
Olezhka's Avatar
It's giving me the 0403 code, that's for TPS.
Old Dec 17, 2007 | 08:56 PM
Kevlo911's Avatar
Kevlo for President
http://forums.maxima.org/showthread.php?t=547220
Next time this will get locked
Old Dec 17, 2007 | 09:18 PM
Olezhka's Avatar
Originally Posted by Kevlo911
sorry, next time I'll be more specific.
Roymg
Sep 3, 2018 05:10 AM
schmellyfart
Sep 25, 2015 04:47 PM
sake1bs
Sep 19, 2015 09:32 PM
nizmolee
Aug 22, 2001 12:34 PM
