replaced ks but still have cel
Old Dec 20, 2007 | 10:12 AM
bigwee's Avatar
I just replaced it about 5 min ago but i still have a check engine light. I wrapped the ks in duct tape and had some gunk from the tape so i wiped it down with chorox wipes and installed. Did i ruin the ks but taping then cleaning it? It doesnt seem any faster with the adv timing so im guessing its not fixed.
Old Dec 20, 2007 | 10:18 AM
bpk01's Avatar
Did you reset your ECU?
Old Dec 20, 2007 | 10:25 AM
bigwee's Avatar
I didnt think 4th gens needed that?
Old Dec 20, 2007 | 10:34 AM
ROCKART's Avatar
wants an I35
the knock sensor will never cause a CEL. the cel is on from something else. that is why it didnt disappear when you replaced your KS.
and you didnt feel a difference after replacing it?
did you sand/clean the grounding points?
how did you know it was faulty to begin with?
and waht the hell is chrox? and why did you put duct tape around the KS?
Old Dec 20, 2007 | 10:36 AM
bigwee's Avatar
I had the codes scanned, it was the only code. Ill try the sanding...clorox and to keep the sensor from damaging.
Old Dec 20, 2007 | 10:39 AM
91parkave's Avatar
WTF? reset your ECU drive for a little and see if it comes back read the stickies to follow the procedure of resseting the ECU
Old Dec 20, 2007 | 10:41 AM
Snypa's Avatar
are you +ive about the knock not causing cel?
Old Dec 20, 2007 | 10:42 AM
ROCKART's Avatar
wants an I35
yes. quite.
Old Dec 20, 2007 | 10:46 AM
91parkave's Avatar
if the knock sensor dosent cause a code then why is there a knock sensor code in the ECU??
Old Dec 20, 2007 | 10:51 AM
ROCKART's Avatar
wants an I35
its called a ghost code. it piggybacks in on other codes. a dead KS alone will not trip the CEL. you only see it when something else triggers the ECU.
Old Dec 20, 2007 | 11:22 AM
bigwee's Avatar
well i reset the ecu and it stayed off the whole ride but turned on after i restarted the car.
Old Dec 20, 2007 | 11:27 AM
ROCKART's Avatar
wants an I35
what other codes is it showing ?
Old Dec 20, 2007 | 11:50 AM
bigwee's Avatar
Dont know Im going to have to try reading the codes
Old Dec 20, 2007 | 11:53 AM
ROCKART's Avatar
wants an I35
just go to autozone. 5 mins they will do it for free. i guarantee you have another code.
Old Dec 20, 2007 | 12:34 PM
bigwee's Avatar
oh ok i didnt know they did it for you. I sanded the grounds and took it back out and it gets up and goes a little better. So hopefully that was it. But i have to run out to autozone now.
Old Dec 20, 2007 | 01:49 PM
Double E's Avatar
It's going to be a little while till the car reacts to the new KS. Before I changed it, I even got the light reset and it came back after a week. Again, it only showed the KS code.
After changing it, mine took 2 weeks of routine driving for the light to go out.
I've mentioned this before and the results/knowledge of others appears contrary to this ...but the only code AutoZone gave was for the KS. As stated above , it cleared and a week later it came back, still was for the KS. Then I changed the KS. I suppose your results may vary.
Old Dec 20, 2007 | 01:54 PM
ROCKART's Avatar
wants an I35
i felt the difference immediately after driving with the new knock sensor.
MAKE SURE YOU ARE USING PREMIUM GASOLINE. if that still doesnt fix ur lag, it could be several other things (fuel filter, throttle body/IACV, dead plugs, etc.)
and in the stickies for 4th gen it states clearly that the KS will not trip the CEL.
http://forums.maxima.org/showthread.php?t=385898
it starts on post #27
Old Dec 20, 2007 | 02:23 PM
bigwee's Avatar
It gave me codes 1302, 0707, 0201. On the 0201 says "ignitor circuit malfunction (No. 5)". Does that mean to check spark plug, harness, or ignition coil 5?
Old Dec 20, 2007 | 02:33 PM
Cdg2125's Avatar
did you replace the ks harness? Nobody ever thinks to replace it. That was the problem for me. KS was fine. the harness was the issue.
Old Dec 20, 2007 | 02:34 PM
bigwee's Avatar
wouldnt the harness come on as a ks fault?
Old Dec 20, 2007 | 02:40 PM
rxm6's Avatar
Do this:
Make sure you are running 91 and take the KS and touch it to the intake plenum and leave it there. It's now grounded/bypassed. Then start your car, wait for the idle to settle, put on your emergency brake, and put the car in drive (if you have an auto). If your Drive idle is 600 then your KS is working properly. If the Drive idle is 550 or lower than 600, then your KS is no good and you need a new one. Or, if you have you own code reader, once you bypass the KS, the code should either clear or on next startup clear (without and ECU reset).
If you bypass your knock sensor and you have a SES light, check to make sure all the connections you took off were put back. I once spent a whole day trying to figure out a SES light (which was an EGR code) and I even bought Seafoam to clean out the EGR from the plenum. Only to figure out later that I had unplugged the little green connecter right at the entrance to where the KS is and hadn't put it back together. It was a dark day in my mechanic history and I decided from then on to always have a cup of coffee right before attempting any mechanical operation.
Old Dec 20, 2007 | 02:41 PM
rxm6's Avatar
Yes...that was my issue as well.
Old Dec 20, 2007 | 03:03 PM
kzoosho's Avatar
Where can you get the harness from.
Old Dec 20, 2007 | 03:56 PM
bigwee's Avatar
http://www.courtesyparts.com/Merchan...Category_Code=
Old Dec 20, 2007 | 09:59 PM
Cdg2125's Avatar
thats what i said. the ks code is a ks code. It can be anything wrong with the ks or the harness or anything. Go to nissan its $15 dollars...
PH98I30
29
Feb 10, 2025 12:03 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
