Bad missfire only below 2000 RPM?
Old Mar 31, 2008 | 09:50 AM
rcintorino's Avatar
Bad missfire only below 2000 RPM? [Solved]
96 SE/5spd Black, CEL P0302 Cylinder #2 Miss fire only below 2000 RPMs
I'll be honest, I searched a little bit, not too much, I haven't checked spark plugs yet, I'm going out to do an injector sound test after I post this.
I've read the flashing check engine light means cylinder misfire, which supports my p0302 cylinder #2 miss fire code I get.
below 2000 RPM's only SOME OF THE TIME is the missfire like a completely missing cylinder, other times it acts like a low compression cylinder. over 2000 RPMs it runs smooth and true though, which is what confuses me.
Now I read on the forums that it would probably be a clogged injector?
My dad said it might have something to do with the exhaust leak I have on the EGR tube. Can anyone Support or Deny that?
I've also read that the 99 coils go bad, but they say the 96's are rock solid. I just wanted to eliminate them. can anyone support or deny that they can't fail intermittently? I would think they would go and never come back.
I've had the car about 4 months, I believe the previous owner only used regular, I only use super (I've gotten better gas miliage with super, had a knock sensor problems when I got it)
Fuel filters been replaces, knock sensors been replaced, EGR-C control solenoids been replaced, evap vent control valve been replaced. water pump as well.
I know they shouldn't have anything to do with the current problem, just giving a little history.
I've never had to deal with a clogged injector before so I'm not sure sure how it acts. could it really be a clogged injector? is there anything else it could be? I'm a bit short on cash and I'm looking for the cheapest, most direct route to fix the problem.
Would a high pressure injector cleaning fix it? I'm not talking about the bottled crap, I'm talking about the professional snappon type injector cleaning.
I know I should've actually done some testing first, but it's a bit hard for me because I'm either at work, at school, or driving the 50 miles in between to get to either one of those places. and I don't have any work lights to work at 1AM when I get home from work so.
Old Mar 31, 2008 | 10:39 AM
99BlackMaxMS's Avatar
Check the coils first, as those are most prone to make your car misfire.
Old Mar 31, 2008 | 12:05 PM
Snypa's Avatar
coils/sparks.
Old Mar 31, 2008 | 12:09 PM
Tatanko's Avatar
Bacon Lover
I had this problem (though nowhere near this severe) when one of my coils wasn't tight because it wasn't making very good contact sometimes.
Old Mar 31, 2008 | 02:32 PM
A99MAXIMA's Avatar
I've had bad spark plugs do this to me in My 2000 Silverado
Old Apr 3, 2008 | 07:30 PM
rcintorino's Avatar
It was a coil pack, I replaced the coil pack and it got a lot better, although the car still doesn't feel right. I think at 200,000 miles, I should replace them all.
Old Apr 3, 2008 | 07:41 PM
vqmaxman's Avatar
Ok, You just replaced the coil,so what Is It doing now?
Old Apr 4, 2008 | 05:23 AM
rcintorino's Avatar
It's still running ruff, so I'm going to give it a tune up (spark plugs, etc.) and if it's not any better I'm going to replace the coils.
QueensMAX
Sep 15, 2015 04:14 AM
Maxxx10
Sep 13, 2015 03:16 PM
ballerchris510
Sep 11, 2015 05:29 PM
ballerchris510
Sep 10, 2015 09:35 PM
slowlifer
Sep 8, 2015 05:53 AM
