Ok, maybe its the calipers..
Alright so I bought a 98 Maxima SE Automatic with 124,370 on the clock at purchase.. right off the bat It needed a new brake hardware kit up front and new pads, these pads were replaced with Semi-Metallic pads.
After I got the brakes done; I got the car home and
*Changed the fuel filter to a 300ZX style
*Changed the PCV Valve
*Dropped in x6 NGK Laser Platinum Plugs
*Drained/Refilled ATF and Replaced Gasket/Trans Filter
*Oil Changes are made every 3K habitually.. Im using Castrol Full Synthetic 10W-30 and or Mobil 1 Full Synthetic 10W-30
*Installed a Short Ram Intake
*Tire Pressure is kept at Factory Standards 32PSI/29PSI
*Cleaned Throttle Body/IACV and Replaced Gaskets
*Alignment was done early April 2008
*Car idles at normal temperature at ~500/600RPM
The clock is reading 130,8xx now and I am basically averaging 300 miles to a full tank of 91-93 Octane. When I did calculations on the previous two tanks I had gotten 19MPG. I am wondering if this would be considered normal for a straight city machine with little to no highway driving.
Only problems I seem to have now is a code for the; Evap Vent Control Valve,Small Evap Leak (P1448) and a severely corroded muffler (Layers are peeling away from main structure of muffler, and car smells rich when standing behind it. Also, my brakes squeal when they are lightly applied at full pressure they are quiet.
I would like to know how to check for properly functioning injectors and if there is a way to check for frozen calipers.. Search didn't fetch me anything maybe I just didn't word it right
Sorry for making this so long.. but I figured I better give all the info
To check for frozen calipers go on to a steep hill and put it in nuetral and jack up the ebrake, it you roll back ebrake is dead. If not your fine.
Another way is jack up the rear end, crank the ebrake, and spin the wheels
Alright, thanks.. I will have to jack it up and check this out, once this terrential downpour of rain stops in my area. Just jack it from the rear beam there, or is there a designated spot. Im guessing if the wheels spin the calipers are frozen when car is in N with Ebrake applied? How would I check the action on the front calipers?
Anything else I can possibly look over that maybe I haven't gotten too yet.. having a helluva time finding the Evap Vent Control Valve that attaches to the canister which is throwing that P1448.
Exhaust also smells quite rich when outside the car, muffler show signs of obvious age. Flex Section on the Y-Pipe is starting to splinter, and everything has a rustic look to it. I know I should get some exhaust work done, but I don't think I can afford a Y-Pipe and custom work from the local shop to complete the system at the moment. Car Payments
![Mad](https://maxima.org/forums/images/smilies/mad.gif)
Here's the correct way to check for frozen calipers!
For rears: Put car in P and jack rear end. (E-brake OFF) If the wheel spins freely then you're fine.
For fronts: Put car in NEUTRAL with the E-brake ON! Jack the front end and spin the wheels.
After I changed my rears, the pads would touch the rotors somewhat, but didn't lock up like before.
Alright so I bought a 98 Maxima SE Automatic ...........................
*Installed a Short Ram Intake................................
First of all you need to inspect or determine if it's a frozen/sticking piston or sticking guide pins! The inboard pad will be worn more if it's a sticking piston, where as the outboard pad will be worn if it's sticking guide pins! The guide pins should slide easily with hand pressure with the calipers removed! You can press the piston back in with a C clamp even if it's slightly sticking...the truth is how the inner pad is worn more than the outer! A Caliper seal kit and some cleaning will usually fix this, but some folks prefer a rebuilt caliper.....
godlyone
77
02-01-2013 11:37 AM
MaximA VlaD
09-19-2008 09:19 AM
