4TH GEN GURUs!!! - still have WARM CRANKING ISSUES.....please help $$$ reward
Old Aug 31, 2008 | 12:48 AM
  #161
Originally Posted by vqmaxman
I was stating this all along that you might have had the problems because the spacers were installed on wrong,well the silicone was smeared on so that It just fell into the hole of the injectors way. The good thing Is that It was not that serious,if you had to take the whole engine apart and go on up that would have been some serious time and money. Good luck and enjoy the mods now.
I think spending 4 to 5 months and $2000 on random parts is pretty serious...... could've been supercharged for 2k.
Old Sep 2, 2008 | 08:02 PM
  #162
spadez911's Avatar
sounds like you have a vacuum leak somewhere, or it could be a bad 02 sensor causing this.
Old Sep 2, 2008 | 08:06 PM
  #163
Major FAIL.
RTFThread before you post please..........the problem has been solved.
Old Sep 2, 2008 | 08:37 PM
  #164
ROCKART's Avatar
wants an I35
lol wait wait. wait. wati. awit
still <3 in here
Old Sep 4, 2008 | 11:30 AM
  #165
TJ_Max's Avatar
Paradox Systems Vendor
Good stuff fellas, my only question would have been an explanation for why the goop had a worse affect when the car was warm. But I thought about it and figured start enrichment on a cold engine (open loop) is very high. The PCM dumps a lot more fuel to start a colder engine than it does a warmer engine.
Old Sep 4, 2008 | 11:42 AM
  #166
ROCKART's Avatar
wants an I35
it was the fact that the RTV was collecting gas from the injectors.
when i turned the car off and went into a store for 20 minutes or whatever, and came back out, all the gas the RTV had collected was dripping down into the cylinder.
when i would go to start it up after, the engine would choke, as if flooded with fuel, and the tailpipe would shoot out a tuft of black smoke.
however if the car sat for 5-6 hours, all the gas the RTV had collected and let drip down, evaportated, and i would have a perfectly normal start.
Old Dec 11, 2008 | 07:28 AM
  #167
heynow's Avatar
Wow, i'm glad that you've finally managed to solve the problem.
So i guess it's safe to say that if anyone has the same issue and has done all the usual maintainance, should look at a possible leaky injector?
Old Dec 11, 2008 | 10:40 AM
  #168
Not following you here. Re-read the post above yours. The excess RTV was the problem.
Old Dec 11, 2008 | 12:01 PM
  #169
heynow's Avatar
uhhh...i read post. lol, sorry. What i mean is that a leaky injector can cause the same problem as gas dripping from the RTV in this case.
Old Dec 11, 2008 | 12:40 PM
  #170
Yes, most definitely.
Old Dec 11, 2008 | 03:13 PM
  #171
ROCKART's Avatar
wants an I35
yes. and its not usually the injector that leaks - its the biggest of the three o-rings that deteriorates and allows excess gas into the cylinder.
i think each set of o-rings for each injector was $3 from dave b.
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
gustavison
Oct 4, 2015 06:50 PM
97_GXE
Sep 15, 2015 06:47 AM
Violator
Sep 9, 2015 10:14 AM
