Whistling noise on the engine room.
Old Jun 20, 2008 | 04:40 AM
hermtm2's Avatar
My I30, which is 139k on it, makes whistling noise at the 650 rpm which is normal. The A/C and radio is off, and the gear is on "D". Whenever I push the accelerater or turn A/C on, it is gone because they make rpm up.
The same problem was happened at the last year. At that time I cleaned up Throttle body, IACV, and Intake manifold collector by T/R cleaner. It was gone after that. However in this time it doesn't work. The T/R, IACV, EGR tube, intake manifold has alreday cleaned up and replaced almost all of the vacuum hoses. It is still there. I already look at the previous post, but I couldn't find a solution.
Thanks.
Old Jun 20, 2008 | 05:13 AM
snowboi1289's Avatar
It might be a vacuam leak.
Old Jun 20, 2008 | 07:40 AM
maximabebe's Avatar
Check your belt tension(s).
Old Jun 20, 2008 | 09:03 AM
maximase86's Avatar
I love lamp.
Nice...engine room. Make our cars seem like large yachts.
I would definately say it's the belt tension as well.
S
Old Jun 20, 2008 | 09:37 AM
hermtm2's Avatar
What do you mean the belt tensioner? I replaced the belt and ider pully at the last year. Should I replace them again? Let me explain more detaily plz.
Thanks.
Old Jun 20, 2008 | 12:41 PM
maximase86's Avatar
I love lamp.
My bad, my engrish comes out when I type. I meant belt tension and the belt tensioner. I would tighten it down and see if you still have the same issue.
S
Old Jun 20, 2008 | 01:43 PM
internetautomar's Avatar
mod or sell?
I looked at an altima that was doing that a couple days ago. I saw the hose to the vacuum canister was broken.
Old Jun 21, 2008 | 06:40 AM
hermtm2's Avatar
Can Anyone let me know locations of all the vacuum hoses? I think the vacuum hoses were replaced as far as I know. The sound makes nervous whenever the car was waiting for traffic signal.
Thanks.
Old Jun 21, 2008 | 07:21 AM
maximabebe's Avatar
Vacuum hoses include any of the hoses that run into the upper intake manifold.
seesole
Sep 14, 2015 12:38 PM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
bennuss
Sep 11, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
