anyone with conzult or similar here?
Old Aug 3, 2008 | 02:35 PM
allensteiner21's Avatar
i got a cable just like the conzult from blazt.biz, but from someone else and i have scanning\logging software with it - which i can share. everything works as a scan tool but when i start the engine i lose connection with the ecu so i can't do real time logging. anyone have anything on that? i'm wondering if the cable's bad
Old Aug 3, 2008 | 03:10 PM
pmohr's Avatar
No more Maximas...
Is it just while starting? That's expected.
Have you tried connecting the cable (or starting up the software) with the engine already running?
Old Aug 3, 2008 | 03:36 PM
yeah and with no luck. i've read that some ecu models don't let you use a scantool while running but i don't remember if it was about 95 or what. i've also tried two different softwares...i can't remember if a regular scantool works while the engine's running or does it have to be off with the key in "on" position only
Old Aug 3, 2008 | 03:39 PM
pmohr's Avatar
No more Maximas...
The A32 ECU will allow scanning with the engine running with no problem (yes, this includes the '95).
Old Aug 3, 2008 | 03:54 PM
i haven't read your first reply well. i've left the cable connected when i started the car so that might be the prob. thx, i'll try it again.
Old Aug 5, 2008 | 11:59 PM
still not working...i thought it might be the chip board or the cable that came with it but the guy i got it from told me to try and use a different power and ground sources. i'm also thinking that maybe the issue lies in the serial 2 usb cable but i'll have to try to find out.
anyways - the fsm and 3 separate nissan techs told me that the ddl connector has 5 leads - tx, rx, clock, power and ground. i have a 6th one in spot #4. i bet i'm not the only one but maybe someone knows wtf it's for? the techs told me it probably doesn't do anything, which shows how good montana dealership mechanics are...
Old Aug 6, 2008 | 06:07 AM
f550maranello2's Avatar
its probably the serial to usb converter...not all of them work.. if its for simple rs232 communication then they are ok.. but i noticed that when u try to get more complex they dont work.. i think its an addressing issue... get a laptop w a serial port..
Old Aug 6, 2008 | 06:12 AM
IlyaK's Avatar
The Golden One
My brother has some software...it's not CONSULT...but I believe it's ScanTool and it runs fine while running, but every now and then it will drop the connection.
Old Aug 6, 2008 | 06:37 AM
internetautomar's Avatar
mod or sell?
no "conzult" just a snap-on scanner here
Old Aug 6, 2008 | 04:13 PM
i got a new serial 2 usb today and still nothing. i was recommended to hook the ground and 12v to a different source and i'll try that. so does anyone know what the 6th lead on the ddl is for???
Old Aug 6, 2008 | 06:32 PM
KRRZ350's Avatar
Pin 4 of the consult port is for the abs control unit, but your throwing me off when you keep saying dll, I thought you bought a consult cable?
Old Aug 6, 2008 | 06:45 PM
isn't the technical name for the concult plug DDL? thx for the expanation with the 6th connector.
Old Aug 6, 2008 | 06:57 PM
pmohr's Avatar
No more Maximas...
CONSULT, or OBD-II? OBD-II is DLC, CONSULT is really just...the CONSULT connector, as it's a Nissan proprietary connector. It's a DLC as well, I suppose.
The FSMs refer to it as 'Data link connector for CONSULT':
Old Aug 6, 2008 | 07:05 PM
i saw it somewhere as "dedidated data link" or now that i think of it "direct data link"
James92SE
142
Jan 2, 2024 09:23 AM
gigabyte
Jan 6, 2017 06:05 PM
D Mason
Jun 21, 2016 04:43 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
ajahearn
Sep 19, 2015 03:03 PM
