why is this blinking?
Old Nov 16, 2001 | 06:17 PM
alloutmax's Avatar
my airbag light is slowly blinking when i'm driving, anyone know what it is and what to do about it, thnks guys
Old Nov 16, 2001 | 06:46 PM
Micah95GLE's Avatar
Do you mean after start-up, it keeps blinking?
Old Nov 16, 2001 | 06:53 PM
NiMax's Avatar
Re: why is this blinking?
If the airbag light is on and keep blinking then it indicates there is problem with the airbag system. The manual said to have the nissan mechanic check the airbag system asap.
______
95 SE
Old Nov 16, 2001 | 08:45 PM
Ravq's Avatar
There is a procedure for reading the codes. The Chilton manual states: On the 1995-98 models, drive the vehicles over 20 mph for at least one minute. Turn the ignition OFF, Ground the 4 terminal of the data link connector under the dashboard (next to fuse block), then turn the ignition ON. The codes will appear as flashes of the ABS lamp on the dashboard. Here is a translation chart:
# of LED flashes - Malfunctioning part
12-Self diagnosis could not detect any malfunctions
45-actuator front left outlet solenoid valve
46-actuator front left inlet solenoid valve
41-actuator front right outlet solenoid valve
42-actuator front right inlet " "
51-actuator rear right outlet " "
52-actuator rear right inlet " "
55-" rear left inlet " "
56-" rear left inlet " "
25-Front left sensor (open-circuit)
26-" " " (short-circuit)
21-Front right sensor (open-circuit)
22-" " " (short-circuit)
35-Rear left sensor (open)
36-" " " (short)
31-Rear right sensor (open)
32-" " " (short)
18-Sensor rotor
61-Actuator motor or motor relay
63-solenoid valve relay
57-power supply (low voltage)
71-Control unit
Warning lamp stays on continuously- Control unit power supply circuit or warning lamp bulb circuit or control unit or control unit connector or power supply to solenoid valve realy coil
Lamp stays on during self diagnosis - Control unit
Lamp does not work before engine starts - Fuse, warning lamp bulb or warning lamp control unit
Lamp does not come on during self diagnosis - Control unit
Old Nov 16, 2001 | 10:46 PM
Sonic's Avatar
It is also in the 4th gen stickys...
Old Nov 17, 2001 | 05:57 PM
Dave Holmes's Avatar
Somewhere in there do I stop the car and put it in park? Or do I have to have really fast hands/good hand-eye coordination?
Old Nov 17, 2001 | 07:49 PM
Dasyce's Avatar
Wait a second. My '01 accord airbag light blinks when ever my passanger decides to lean forward, then sit back. I belive this is due to it reconizing a passenger in the seat. (Part of side airbag)
May be it's the same for maxima's equipped with Side airbages.
Just Trying to help!!
Old Nov 17, 2001 | 08:00 PM
Ravq's Avatar
Don't know try it both ways.
Roymg
Sep 3, 2018 05:10 AM
BrandonCause
Sep 14, 2015 10:41 PM
dcardello
Sep 3, 2015 11:44 PM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
