Help installing Ultimate/hks ignition
Well i bought these used..and they didnt come with instructions..and its either i really suck at using the search or it doesnt work. Cause i cant come up with anything..
if you all could send/post up a how to install it be nice. Or the 96 ecu diagram.
also for the ignition wiring, please...
ultimate as in eu? eu here http://www.vqpower.com/v2/articles.php?article_id=26
Why the HKS ignition? The VQ ignition system is very good as it is. I know of many 500+whp cars with a stock ignition systems (and have only seen problems from aftermarket systems).
Search works just fine for me
http://forums.maxima.org/4th-generat...tion-help.html
http://forums.maxima.org/4th-generat...-ignition.html
http://forums.maxima.org/general-max...n-upgrade.html
http://forums.maxima.org/west-coast/...-ignition.html
http://forums.maxima.org/all-motor/3...win-power.html
well i bought it..might as well put it to use..
so i might as well just put it on the same time i put my GU on
Alternatively, you could actually search for the damn information:
There's an easy way to raise your spark voltage - my voltage-booster thingie:
It's an automotive laptop power supply with switch-selectable outputs. I use 16 volts to the coils. You need to find the one wire that feeds battery voltage to the coils, open it up, feed the battery to the "boostar" and connect the output to the coil connection. Hey, presto, no more sparks blowing out! About $50.
Oh yeah, plugs - the 4th gen stock ignition needs help when boosting or spraying - the spark blows out unless you close down the gap a bunch. I was closed down to .030 when racing with a 150-shot setup. I found a notebook power supply that let me raise the voltage going to all the coils - I used 16 volts - and then opened the gap back out to .035. I hear the later gen cars have enough spark for boost or spray - I guess you use the stock gap, right? Ignition misfiring at high load and RPMs is sneaky - your top end drops off, but when I jacked up my voltage, I picked up 2MPH in the traps.
Did you even read anything I posted?
shilov
02-19-2024 09:40 PM
MaxLife17
06-27-2019 01:37 PM
mikeg75
11-30-2015 05:12 PM
