lots of air noise
Old Mar 12, 2010 | 05:32 PM
Fenton3030's Avatar
lots of air noise
Getting alot of air passby noise from my driver door like the doors not closed all the way/the same flapping noise like having your windows cracked open on the highway. or theres a bad seal to the door can i buy the rubber peice around the door frame area from somewhere i think thats whats wrong because i see a decent sized tear in it and it seems to coming from that area.
http://i21.photobucket.com/albums/b2...le/cid_834.jpg
^PIC OF TEAR^
Old Mar 12, 2010 | 07:07 PM
Goomz's Avatar
yes that will create that whistling noise. you can order a replacement seal, or remove one from a junkyard
Old Mar 12, 2010 | 07:13 PM
Fenton3030's Avatar
order from where plz dont say dealership
Old Mar 12, 2010 | 07:15 PM
Fasteddie01's Avatar
There's also a TSB about Wind noise at many points and several solutions. Search for the TSBs and you'll find lots of answers , basically just add some self-stick foam in the noisy areas.
Old Mar 12, 2010 | 07:28 PM
Goomz's Avatar
perhaps you live near a local auto parts shop...not like pep boys, but an auto body parts shop...like http://www.continentalparts.com/
Old Mar 21, 2010 | 06:29 PM
Fenton3030's Avatar
okay didnt want to start a new thread for simple question soo...
is the engine known to be more quiet or loud
Old Mar 21, 2010 | 06:33 PM
maxfever1987's Avatar
i have that wind seal for $20 shipped if you like.
Umair
Old Mar 21, 2010 | 06:47 PM
Trini Boom's Avatar
There is an FSM for wind noise for the driver's side door. You may want to follow the fix in that first and see if it helps with your problem. If you don't have the FSM, search around the other member posts and you will get it.
Old Mar 21, 2010 | 07:39 PM
Goomz's Avatar
my engine sounds like a brand new car...i have 103k miles.
Old Mar 21, 2010 | 08:20 PM
Fenton3030's Avatar
Is it loud tho?
Old Mar 21, 2010 | 08:30 PM
Fenton3030's Avatar
Concerning the air noise i just noticed my driver door can be pushed in about a half an inch after the door is closed. the door can be locked and unable to open. but i can still push it in a little more. is that normal?
the driver isnt closing flush with the body
Old Mar 21, 2010 | 08:31 PM
Fenton3030's Avatar
post pics soon
Old Mar 21, 2010 | 08:43 PM
Goomz's Avatar
no, it sounds like a brand new car from startup to a 10 min warmed up idle. my only issue, which isnt bad is my ects needs to be replaced, my fans stay on constantly, but this isnt necessarily a bad thing.
Old Mar 21, 2010 | 08:44 PM
Goomz's Avatar
but i have an intake...sounds sick when under wot.
Old Mar 21, 2010 | 08:47 PM
Goomz's Avatar
that'll cause an air leak. does your dash light come on for the door being ajar when the door is "closed"? your car been crashed before? sounds like the door needs re aligning.
Old Mar 21, 2010 | 08:58 PM
Feldman's Avatar
in its stock form the maxima is stealthy quiet intake adds some noise as well as exhaust components obviously
It's more of a 5th gen problem but i know scottwax did a writeup on how to reduce highway wind noise because of a loose fitting seal. It involves 3m double stick foam strips don't remember the exact dimensions though i need to do it myself though when i get some free time
I think you on the other hand need to adjust your hinges. I think i did a writeup on how to do it a while ago. I can't really remember though
Old Mar 22, 2010 | 12:55 AM
aackshun's Avatar
Is it loud tho?
Do you have mods? If you're stock and your car is loud, something is loose/leaking.
If you have a Y-pipe+high flow cat and intake like moi, then your car will be "loud" compared to stock maximas, but not compared to other modified cars.
Wind noise eh? Did you also check the sunroof to see if it's not sitting flush w/ the roof? That's another source of wind noise on these cars also. But If I were you I'd play w/ the door some more to find out about that extra play.
Old Mar 22, 2010 | 01:55 PM
Fenton3030's Avatar
No door light when closed and yes i have been in a 30mphish I rear ended someone accident
How much is a realignment and can only the dealer/shop do it?
Old Mar 22, 2010 | 02:01 PM
Fenton3030's Avatar
as far as mods i Personally have done none. but the person i bought
it from had a CAI installed. i can hear and tell thats making some extra sound but my main concern is around with the belt area noise i cant remember if its always been that loud or what but im pretty sure its loose belt because the sound gets noticeably louder with revs and some times my the belt "slips" i guess would be the term. so i guess my PS belt is loose. im hoping thats all.
[ i hate noise lo]
Old Mar 22, 2010 | 02:03 PM
Fenton3030's Avatar
i was just tryin to get a comparison as to whether its a silent running engine or all have the noticeable belt area sound going on
and pics would basically be a waste cant really get a good before and after compare for when left alone an applied pressure to make flush
Old Mar 22, 2010 | 05:40 PM
Goomz's Avatar
well its recommended a body shop aligns it, thats not my dept.
Old Mar 22, 2010 | 07:51 PM
Fenton3030's Avatar
As long as it CAN be done
Old Apr 1, 2010 | 07:43 AM
Trini Boom's Avatar
There is no IF's about it. It can be done seeing that if you were in my area, the guy that painted over my car would have gotten it straight. I have seen that guy worked on an '04 TL which was damaged on every side excluding trunk and roof. All doors had to be replaced, quarter panels, fenders, hood, and bumpers and that car looked like it never got hit when he was done with it and the paint job was great!
Old Apr 1, 2010 | 10:37 AM
aackshun's Avatar
[ i hate noise lo]
You sure it's not your chain?
Mine makes a noise whenever I quickly rev the engine up...
Old Apr 2, 2010 | 02:57 PM
Fenton3030's Avatar
doesn't sound like a metallic chain noise tho im pretty sure its the belts because my power steering belt slips and has to catch sometimes when i start the car and pull out of my driveway.
Old Apr 2, 2010 | 02:58 PM
Fenton3030's Avatar
glad to hear it can be fixed because high speed driving it get annoying noisy cars and kind of an embarressing thing with me
pears
Sep 18, 2015 05:25 AM
lrb6805
Sep 17, 2015 04:49 PM
Bonka
Sep 14, 2015 11:18 PM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
