HID Retro Issue
Old Mar 7, 2011 | 11:55 PM
matty's Avatar
HID Retro Issue
I have had my HID Retro for a good amount of time without a problem. They are FX35 Projectors; Ballasts and ignitors in a stock housing. For some reason, when it rains, I am losing one headlight. After they dry out, they both start working again. It seems to switch from one to the other.
Anyone have a similiar issue with a fix ?
Im thinking taking out the Ballasts and sealing them up
-matt
Old Mar 8, 2011 | 09:36 AM
imports_only1's Avatar
if you're using matsu****a gen. 3 ballasts from nissan/infinity, if wet, they won't turn on but when they dried up, they work again. philips, densos, and osrams....if they get wet, they're dead for good.
Old Mar 8, 2011 | 05:14 PM
Yup the gen III's are notorious for that.
Old Mar 9, 2011 | 11:41 AM
matty's Avatar
Is there any fix ?
Old Mar 9, 2011 | 01:18 PM
Originally Posted by matty
Is there any fix ?
don't let it get wet!
Old Mar 9, 2011 | 01:42 PM
Akiyukio's Avatar
I have those ballasts in my Maxima for a while now. What I did was electrical tape it to death, and overlapped each layer downwards (Like the shingles on your roof) so that water could not go in unless the top piece of tape was leaking. I left a small hole near the bottom of the ballast so that any water that did get in, could easily drain out instead of collecting.
Old Mar 9, 2011 | 03:14 PM
Yeah most people do that as well to make sure they're sealed off from water/moisture.
Where are they mounted BTW?
Old Mar 10, 2011 | 06:45 AM
Akiyukio's Avatar
Driver side is mounted under the fuse box, the little area between the fender, the battery, and under the fuse box.
As for the passenger side, I think I have mine either under the coolant reservoir, or slightly in front of it. It has been some time since I have installed the system, so I would have to go check.
Last edited by Akiyukio; Mar 10, 2011 at 06:46 AM. Reason: I can't spell "battery"...
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Vistance
Sep 17, 2015 05:17 AM
MidnightMaxima_22
Sep 12, 2015 06:02 AM
mpbclutch33
Sep 8, 2015 06:21 PM
