aftermarket coil problems
Old Oct 11, 2011 | 07:23 PM
supergondi's Avatar
so i notice some hesitation on my 98 se sometimes on acceleration usually right after i start it when i hit 3k but it doesnt happen all the time. so i changed the plugs and noticed #3 plug had some powdery white substance on it just the part that sticks out the combustion chamber. i grabbed a couple new coils from work and changed the one out started it and 2mins later yellow light and p 1320 ignition failure so i went to the next coil after clearing code same thing except this time the tach jumped to 4500 key on engine off and stayed there after i removed key i dont have plastic over the gauges so i zeroed the needle out by hand went back to the original coil and it works fine again no light there was no light in the begining either i just thought that one coil may have leaked or melted a bit but i guess not. any members have any thoughts??
Old Oct 11, 2011 | 07:25 PM
tigersharkdude's Avatar
What kind of coils did you use? For ignition coils it's OEM or BUST
Also what kind of plugs did you use? NGK or BUST on plugs
Old Oct 11, 2011 | 07:35 PM
supergondi's Avatar
i feel the same ngk or bust but i work at a napa ny warehouse and ive had good luck with everything else so i went with those too and i will bow to the forum they are trash ill stick to used oem ones my success rate is way better.
Old Nov 4, 2011 | 02:39 PM
edwardh1's Avatar
my mechanic (store front, employs 3 other mechanics) tried a napa coil that cured the miss but turned on the check engine light. he took it back, got oem from nissan, end of problem. too much stuff from china
PH98I30
20
Mar 25, 2020 03:44 PM
Mar 12, 2020 12:06 AM
gustavison
Oct 4, 2015 06:50 PM
ballerchris510
Sep 11, 2015 05:29 PM
slowlifer
Sep 8, 2015 05:53 AM
