HID fog light wiring
Old Feb 14, 2012 | 07:28 PM
bksmax11203's Avatar
What's up everyone, I've searched and searched, but I can't find the write up on how to wire in hids to the factory fogs so they can be switched on with the factory fog stalk. I know there's one on here because when i had my old 95 se i used it to do the conversion. Can someone please post it up or let me know if they know how? Thanks
Old Feb 14, 2012 | 07:31 PM
Kevlo911's Avatar
Kevlo for President
Use the factory wires as the trigger for the relay...
If you aren't using a relay, just use the factory wires
Old Feb 14, 2012 | 08:59 PM
RA121625's Avatar
Positive --> Positive
Negative --> Negative
Not too difficult, or am I missing something here?
Old Feb 14, 2012 | 09:07 PM
Yea i know, but i cant remember how/ where the factory harness splices into because i know your suppose to cut them off and splice the wires into something but i cant remember.
Old Feb 14, 2012 | 09:36 PM
I'll take a look at it. I wanted to see if i can find the write up before i ripped fogs out, but hopefully it is that simple. I just can't remember for the life of me what the hell i did before to wire them up.
Old Feb 14, 2012 | 10:25 PM
ShocknAwe's Avatar
With the kits nowadays it cant be hard at all. Post pics when your done, Im curious to see how they turn out because I have the same fogs as you do IE the big ugly ones
Old Feb 15, 2012 | 04:52 PM
SandyMax96's Avatar
Ok, so you want to wire them into the factory wire harness? I really don't get what it is that you wish to do.
HID kits already come with the ballasts, that you simply just plug and play into the existing connections, no? And in any case, it shouldn't be too hard, unless you are trying to let them run independently from the headlights, in which I would suggest that you just splice the fog light wire directly into the wiper blade wire and tap it off.
Old Feb 15, 2012 | 07:42 PM
by sat i'll have the time to do it, and what i'm doing is installing the hids, but you have to splice the power wire into the vehicle fog light wire to give it power when you flip the switch. This allows you to have your hids in your fogs, and switch them on with the oem stalk switch. I'll post some pics and the steps i took when i'm done.
Old Feb 15, 2012 | 08:23 PM
You shouldn't need to splice anything..
Old Feb 16, 2012 | 08:25 PM
SandyMax96's Avatar
Redundant, but again, only when doing the Independent Fog light rewire is the only time you would need to splice :nods:
Old Mar 4, 2012 | 05:39 PM
youmeill's Avatar
Old Mar 4, 2012 | 07:18 PM
installer's Avatar
hey you can swap the trigger wire for the stock relay for the fog turn on to the turn on output of the parking light relay in the under hood relay/fuse box ive done this befor half hour job
Dennis Twohy
Oct 1, 2015 06:01 PM
EuroDriver
Sep 14, 2015 06:08 PM
robtroxel
Sep 1, 2015 08:12 AM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
