Who's Really Interested In A 3" 4th Gen Catback?????
No! Neither! This is a MES (Mandrel Exhaust System) list were working on! I and the Org helped creted a 3rd Gen catback and we'll help them create a 4th Gen line as well! You in? I would suggest you read thru most of the reply so far so you have a better idea about wghat we're doing! We do need 10 people, I'll say combined to get MES to start prototyping a 2.5"/3" catback for our cars....2.5" aluminized steel tubing kit $125/ 3" aluminized steel est'd $195....come on and join us! I'm rockin a crush bent 2.5" with a 2.5" x 22" long Cattman resonator and a noisy a$$ 13" Flowmaster 40 that's kinda on the noisy side of my personal sound spectrum! Ckeck it out and let us know yes or no....Thx
What size are you interested in anyway? The 2.5" tubing is $125....3rd Gen is $195 for it's 3" so I can say that'll more than likely be the same price for the 4th since the layout and cars are relatively the same size! So either jump on the wagon or get left behind...Im not babysitting on this group buy....Either you're interested or you're not.....it's a freaking low a$$ price and either you want it or you don't!
hell mine was rattling and had to put a block of wood in between in to weld it permanently in place so it wouldnt rattle anymore. The stock exhaust is well designed. My exhaust guys said it was probably crushed for a reason so dont mess with it. I was going to add in a new length of pipe to avoid that. I would like to see what torque numbers are before and after removing that crush. It looks like bad design but what you said makes sense
@CMax03 put me on the list for this MES tubing kit. I'm fine with aluminized steel for now since I'm looking to run a 2.5 inch straight pipe set up anyway, but I'll want a 3 inch once I get into my boost build...hopefully this takes off and they'll have a stainless set up available by then.
The only restrictive part of the stock exhaust is the pre-cats and the cat really, its pretty well designed with no sharp bends that I recall on the b-pipe. Once you get up to about 250hp then you can increase the size because you NEED to as opposed to wanting to or for sound purposes. With a Y-pipe and high flow cat the stock system isn't bad unless you plan on going high HP.
I never once said it was too expensive, just wanted to know a set price on the kit before I commit. Are our options only aluminized steel at the moment or will stainless steel be an option? Also, what are we looking at time frame wise? Going to put my 2.5" set up for sale since Ill be going to a 3" with this group buy.
Op, is everyone set on getting the kits through mes or are we open to options here? Vrs makes some nice kits and there around the same price. Im sure theyd be willing to work out a group buy with us.
http://www.vrsexhaust.com/index.html
The price for the 2.5" aluminized steel is set.....The first production catbacks will be aluminized steel 2.5" tubing kit, then the SS and 3" will be available....I've already setup a list that's gonna be with MES and Josh from Mes is whom I worked with before getting a catback made for the 3rd gen community....in which I bought two (2) of....Again I'm pretty sure that the prices will be identical to the 3rd gen since the routing and length are almost identical...Josh emailed my and I posted it on this thread pg 2, reply 45.....
Well MES is interested in a 2.5" and 3" catback for our 4th Gen Maxima(s) we need ten (10) People, we have 3 as of now, maybe 4!!!!
Here's what MES said regarding this 3" Exhaust:
Good to hear from you. Do you have a 95-99 model yourself?
Yes, we would be interested in helping.
We would need to get 10 people ready to buy... We would only make this as a "tubing kit" to start and based off interest/sales would we then possibly consider building a bolt on system.
We would need some guys interested in 2.5 inch Aluminized to make the first few test fits. Then we can produce the system in 3 inch. Yes, we can eventually build the system in Stainless also, but we would need to get several systems out there in Aluminized Steel first to gauge fitment.
Keep me updated on the thread and we'll try to make this happen for you guys.
Josh
Mandrel Exhaust Systems
(p) 305-378-9337
(e) info@mandrelexhaustsystems.com
(w) www.mandrelexhaustsystems.com
(p) 305-378-9337
Cool, Im in for a 3" kit. Heres the updated list for the gb.
1.........Jessica1988
2.........Reallyslowrio
3.........ReLLik *(3")
4.........emdot *(3")
5.........J2FRESH *(3")
6.........CMax03
7.........WesCTR
8.........Nselca2 (3")
9.........
10........
6.........CMax03
7.........WesCTR
9.........
10........
We're moving right along faster than I originally thought with part I, part II will be the defining moment once the payments are required to MES....other than that I really appreciate the participation from you 4th Gen orgers...the way it's moving we should have 10 ppl well within 3 weeks.....from the origin!
Do you mean unfortunately????? Do you mean ypipe or headers since they're forward of the cat? If you're interested please respond if not, don't! Thanks! We only need 2 more Maxima freaks....!!!!!!
I'm in for 3" Stainless.
6.........CMax03
7.........WesCTR
9.........boneebone *(3")
10........
6.........CMax03
7.........WesCTR
10........
I thought 3" stainless won't be available until after this first run?
3" stainless will be done after the aluminized 2.5" and 3"...ok thanks for jumping on the wagon....We're one short in phase one.....thanks guys we'll be there shortly!!!
I'll also be playing around with a mocked up Magnaflow 12646 for my Cattman 3" in the resonator section only (flanged) on the 5.5G....http://www.magnaflow.com/02product/s...=main&id=10019
6.........CMax03
7.........WesCTR
10........RowlTyde205
6.........CMax03
7.........WesCTR
Sure will Rod....I'll probably recieve the tubing kit first and install it with picture and literture with Josh to make sure all is good! I will post pics and video it for you....You're and exhaust video ***** in a good way Rod!
Next step is MES contacting me......I'll be do a test fit once the exhaust is shipped b4 anyone else recieves theirs and once fitment is confirmed everthing is a goer!!!! Let's see what Josh has in store for us! That's say about 30 days til pay time guys!!!! Yall ready????
Well Guys Josh just emailed me regarding their side of this 4th Gen Catback experience:
I will stay in touch.
CMax03,
I'm glad to hear your finding people interested in the system...
We started the process afew days ago actually... and hope to have a system ready for you to test fit by next week.
Once you have confirmed the test fit... we can finalize the group buy for everyone else to purchase.
Josh
(p) 305-378-9337
(p) 305-378-9337
This is awesome folks it's becoming a reality and I'll be all over it once it gets here, just remember the paying portion will be coming next folks so please start setting your money up to be available for your catback within the next 2 weeks please! Anything is possible folks and we've done part one with 10 people on the interest list next is fitment and verification then it on to the ordering stages, Thx for yalls participation and patience......
