Changed battery cables & fuses & still no power?
Old Nov 12, 2012 | 10:36 AM
kapp241's Avatar
I'm at a loss trying to figure out what's going on with my 99 SE-L. 173,000 miles. Good battery, starter and everything was re-connected right & tight. Anyone care to guess what the problem could possably be?
Old Nov 12, 2012 | 11:00 AM
[s3]'s Avatar
How's your main battery fuse?
Old Nov 12, 2012 | 11:07 AM
max_dreamer's Avatar
+1... doesnt take much to kill that guy... its the fuse in the center of the long rectangle box. Screw in type. typically a 140, but a 120 is ok. iirc.
Old Nov 12, 2012 | 11:09 AM
Amerikaner83's Avatar
what was your original issue? Have you been immobilized?
Old Nov 12, 2012 | 11:18 AM
po8pimp's Avatar
Sounds like it could be alarm related. Happened to a buddy of mine, took forever to figure it out. Check the fuses and make sure you hooked everything up correctly. Most important ensure you have a good ground.
Old Nov 12, 2012 | 11:21 AM
[s3]'s Avatar
Alarm just makes the car unable to start, it won't disable the car to the point where you can't even get power to anything.
If you turn the key to ACC/ON and nothing lights up, it's a power/short/fuse problem.
Old Nov 12, 2012 | 11:24 AM
po8pimp's Avatar
My friends SUV didn't have any power except on the alarm light.
Old Nov 12, 2012 | 11:33 AM
[s3]'s Avatar
Sucks to be him
Old Nov 12, 2012 | 03:23 PM
kapp241's Avatar
It doesn't appear to be blown.
Old Nov 12, 2012 | 03:27 PM
kapp241's Avatar
The car started shuttering and died out on my girl. Went to help her and tapped on the battery wires and it started right up. Now absolutely nothing. I'm gonna take the battery to get tested again at somewhere other than walmart. I think that's the issue.
Old Nov 13, 2012 | 12:29 PM
DBear's Avatar
Check for corrosion up inside the covering of the battery cables too.
Old Nov 13, 2012 | 02:08 PM
mrjasonlyrics's Avatar
Sounds like this is a job for a certified electrician man. Get it to someone who can diagnose it properly
Old Nov 14, 2012 | 10:29 AM
bobflood's Avatar
+1 on this. The cables can corrode INSIDE the insulation - they look fine but don't work well.
Old Nov 16, 2012 | 08:14 AM
CMax03's Avatar
Check your fusible links! They're located @ the positive battery post terminal!
Old Nov 16, 2012 | 08:51 AM
Max_Gator's Avatar
I think he might want to take a few simple steps before doing that....
Old Nov 16, 2012 | 09:10 AM
asand1's Avatar
What are your symptoms?
What circuits work?
What circuits don't work?
What was the last work done before the problem?
what were the circumstances during the event?
We need info, or all we can give you is speculation.
tsi6001
Oct 3, 2022 10:23 PM
maxinout93
Aug 20, 2015 02:17 AM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
RealityCheck
Aug 5, 2015 06:18 AM
