95 Auto transmission not changing gears after solenoid replacement
Old Jan 25, 2013 | 07:54 PM
delacruz_17's Avatar
EDIT:
FIXED
So I was able to fix this issue of 1103, P0731 . Turned out to be the A33 TPS. On the inside of the A33 TPS the little spring clip was knocked out of place. I since put it back in place. The TPS alone was causing the 1103, P0731 .
Issue fixed.
I changed the automatic transmission solenoids and my car is not changing out of 1st gear:
It is as if the transmission is not even trying to change gears. As if the transmission computer thinks my car I have the car is 1st rather than in "D".
I am getting a CEL but I have not checked it yet. However from my understanding the CEL will not report issues on the automatic transmission side, or so I think.
I checked the transmission fluid level and the level is normal.
Any ideas anyone?
Old Jan 25, 2013 | 09:53 PM
DennisMik's Avatar
You can get a CEL for auto trans problems, they are in the P07xx group. But the auto trans self diagnostic will give you more problem codes than the CEL codes do.
I have read various threads from guys that have replaced the solenoids and it seems there are 2 things you can mess up during re-assembly. One is a spring and the other is some small part not seated properly. But that's all I can tell you, I never memorized it.
Old Jan 26, 2013 | 08:02 AM
jholley's Avatar
Where the 4 lip seals and spring seated in the AT before you reinstalled the VB?
VBlipsealsandspring.jpg?t=1359215896
Was the manual valve shaft lined up correctly?
Old Jan 26, 2013 | 09:59 AM
The manual shaft was correctly installed. The seals as well though I will double check tomorrow.
The spring as well was correctly installed.
Old Jan 28, 2013 | 08:22 AM
So the CEL is giving me 1103, P0731 .
Can someone please confirm using the video I linked above if my car is actually stuck in 1st gear or 2nd gear:
The code the CEL is throwing 1103, P0731 sounds as if the car should not ever be in first gear to begin with.
PS: When I changed all five solenoids I made sure the manual valve was installed correct:
I also have since also physically checked all five solenoids with a multimeter and all five solenoids are working correct.
I have also checked the inhibitor switch and show that it is working correct.
EDIT:
FIXED
Issue fixed.
Old Jul 23, 2024 | 06:11 AM
Hard2love$'s Avatar
08 fully loaded ax with cvt trans
2008 Nissan Maxima 3.5 se I put a used transmission in the car, the check engine light was on, and popped a code for torque converter solenoid. I had my mechanic replace the solenoid on the transmission, and now it will not do ANYTHING! It was at least working before replacement. WHAT DO I DO? I am a single mom and I have dumped my entire savings into fixing my car.
sadekmh
Feb 2, 2013 07:50 AM
dadswieser
Aug 24, 2012 03:53 PM
ThreePointO
Aug 17, 2009 12:30 PM
Rider
May 15, 2009 11:18 PM
made in china
Nov 13, 2008 09:19 AM
